Spring Boot Application
This section includes topics relating directly to Spring Boot applications.spring-doc.cn
Create Your Own FailureAnalyzer
FailureAnalyzer is a great way to intercept an exception on startup and turn it into a human-readable message, wrapped in a FailureAnalysis. Spring Boot provides such an analyzer for application-context-related exceptions, JSR-303 validations, and more. You can also create your own.spring-doc.cn
AbstractFailureAnalyzer is a convenient extension of FailureAnalyzer that checks the presence of a specified exception type in the exception to handle. You can extend from that so that your implementation gets a chance to handle the exception only when it is actually present. If, for whatever reason, you cannot handle the exception, return null to give another implementation a chance to handle the exception.spring-doc.cn
FailureAnalyzer implementations must be registered in META-INF/spring.factories. The following example registers ProjectConstraintViolationFailureAnalyzer:spring-doc.cn
org.springframework.boot.diagnostics.FailureAnalyzer=\
com.example.ProjectConstraintViolationFailureAnalyzer
If you need access to the BeanFactory or the Environment, declare them as constructor arguments in your FailureAnalyzer implementation.
Troubleshoot Auto-configuration
The Spring Boot auto-configuration tries its best to “do the right thing”, but sometimes things fail, and it can be hard to tell why.spring-doc.cn
There is a really useful ConditionEvaluationReport available in any Spring Boot ApplicationContext. You can see it if you enable DEBUG logging output. If you use the spring-boot-actuator (see the Actuator section), there is also a conditions endpoint that renders the report in JSON. Use that endpoint to debug the application and see what features have been added (and which have not been added) by Spring Boot at runtime.spring-doc.cn
Many more questions can be answered by looking at the source code and the API documentation. When reading the code, remember the following rules of thumb:spring-doc.cn
  • Look for classes called *AutoConfiguration and read their sources. Pay special attention to the @Conditional* annotations to find out what features they enable and when. Add --debug to the command line or the System property -Ddebug to get a log on the console of all the auto-configuration decisions that were made in your app. In a running application with actuator enabled, look at the conditions endpoint (/actuator/conditions or the JMX equivalent) for the same information.spring-doc.cn
  • Look for classes that are @ConfigurationProperties (such as ServerProperties) and read from there the available external configuration options. The @ConfigurationProperties annotation has a name attribute that acts as a prefix to external properties. Thus, ServerProperties has prefix="server" and its configuration properties are server.port, server.address, and others. In a running application with actuator enabled, look at the configprops endpoint.spring-doc.cn
  • Look for uses of the bind method on the Binder to pull configuration values explicitly out of the Environment in a relaxed manner. It is often used with a prefix.spring-doc.cn
  • Look for @Value annotations that bind directly to the Environment.spring-doc.cn
  • Look for @ConditionalOnExpression annotations that switch features on and off in response to SpEL expressions, normally evaluated with placeholders resolved from the Environment.spring-doc.cn
Customize the Environment or ApplicationContext Before It Starts
A SpringApplication has ApplicationListener and ApplicationContextInitializer implementations that are used to apply customizations to the context or environment. Spring Boot loads a number of such customizations for use internally from META-INF/spring.factories. There is more than one way to register additional customizations:spring-doc.cn
  • Programmatically, per application, by calling the addListeners and addInitializers methods on SpringApplication before you run it.spring-doc.cn
  • Declaratively, for all applications, by adding a META-INF/spring.factories and packaging a jar file that the applications all use as a library.spring-doc.cn
The SpringApplication sends some special ApplicationEvents to the listeners (some even before the context is created) and then registers the listeners for events published by the ApplicationContext as well. See Application Events and Listeners in the “Spring Boot Features” section for a complete list.spring-doc.cn
It is also possible to customize the Environment before the application context is refreshed by using EnvironmentPostProcessor. Each implementation should be registered in META-INF/spring.factories, as shown in the following example:spring-doc.cn
org.springframework.boot.env.EnvironmentPostProcessor=com.example.YourEnvironmentPostProcessor
The implementation can load arbitrary files and add them to the Environment. For instance, the following example loads a YAML configuration file from the classpath:spring-doc.cn
import java.io.IOException;
import org.springframework.boot.SpringApplication;
import org.springframework.boot.env.EnvironmentPostProcessor;
import org.springframework.boot.env.YamlPropertySourceLoader;
import org.springframework.core.env.ConfigurableEnvironment;
import org.springframework.core.env.PropertySource;
import org.springframework.core.io.ClassPathResource;
import org.springframework.core.io.Resource;
import org.springframework.util.Assert;
public class MyEnvironmentPostProcessor implements EnvironmentPostProcessor {
	private final YamlPropertySourceLoader loader = new YamlPropertySourceLoader();
	public void postProcessEnvironment(ConfigurableEnvironment environment, SpringApplication application) {
		Resource path = new ClassPathResource("com/example/myapp/config.yml");
		PropertySource<?> propertySource = loadYaml(path);
		environment.getPropertySources().addLast(propertySource);
	private PropertySource<?> loadYaml(Resource path) {
		Assert.isTrue(path.exists(), () -> "'path' [%s] must exist".formatted(path));
		try {
			return this.loader.load("custom-resource", path).get(0);
		catch (IOException ex) {
			throw new IllegalStateException("Failed to load yaml configuration from " + path, ex);
class MyEnvironmentPostProcessor : EnvironmentPostProcessor {
	private val loader = YamlPropertySourceLoader()
	override fun postProcessEnvironment(environment: ConfigurableEnvironment, application: SpringApplication) {
		val path: Resource = ClassPathResource("com/example/myapp/config.yml")
		val propertySource = loadYaml(path)
		environment.propertySources.addLast(propertySource)
	private fun loadYaml(path: Resource): PropertySource<*> {
		Assert.isTrue(path.exists()) { "Resource $path does not exist" }
		return try {
			loader.load("custom-resource", path)[0]
		} catch (ex: IOException) {
			throw IllegalStateException("Failed to load yaml configuration from $path", ex)
The Environment has already been prepared with all the usual property sources that Spring Boot loads by default. It is therefore possible to get the location of the file from the environment. The preceding example adds the custom-resource property source at the end of the list so that a key defined in any of the usual other locations takes precedence. A custom implementation may define another order.
While using @PropertySource on your @SpringBootApplication may seem to be a convenient way to load a custom resource in the Environment, we do not recommend it. Such property sources are not added to the Environment until the application context is being refreshed. This is too late to configure certain properties such as logging.* and spring.main.* which are read before refresh begins.
Build an ApplicationContext Hierarchy (Adding a Parent or Root Context)
You can use the SpringApplicationBuilder class to create parent/child ApplicationContext hierarchies. See Fluent Builder API in the “Spring Boot Features” section for more information.spring-doc.cn
Create a Non-web Application
Not all Spring applications have to be web applications (or web services). If you want to execute some code in a main method but also bootstrap a Spring application to set up the infrastructure to use, you can use the SpringApplication features of Spring Boot. A SpringApplication changes its ApplicationContext class, depending on whether it thinks it needs a web application or not. The first thing you can do to help it is to leave server-related dependencies (such as the servlet API) off the classpath. If you cannot do that (for example, if you run two applications from the same code base) then you can explicitly call setWebApplicationType(WebApplicationType.NONE) on your SpringApplication instance or set the applicationContextClass property (through the Java API or with external properties). Application code that you want to run as your business logic can be implemented as a CommandLineRunner and dropped into the context as a @Bean definition.spring-doc.cn
