Jackson JSON
Spring 提供对 Jackson JSON 库的支持。
JSON 视图
Spring MVC 为 Jackson 的序列化视图提供了内置支持,
,它们只允许在Object
.若要将其与@ResponseBody
或ResponseEntity
controller 方法,你可以使用 Jackson 的@JsonView
注解激活序列化视图类,如下例所示:
Java
Kotlin
@RestController
public class UserController {
@GetMapping("/user")
@JsonView(User.WithoutPasswordView.class)
public User getUser() {
return new User("eric", "7!jd#h23");
public class User {
public interface WithoutPasswordView {};
public interface WithPasswordView extends WithoutPasswordView {};
private String username;
private String password;
public User() {
public User(String username, String password) {
this.username = username;
this.password = password;
@JsonView(WithoutPasswordView.class)
public String getUsername() {
return this.username;
@JsonView(WithPasswordView.class)
public String getPassword() {
return this.password;
@RestController
@JsonView(User.WithoutPasswordView::class)
fun getUser() = User("eric", "7!jd#h23")
class User(
@JsonView(WithoutPasswordView::class) val username: String,
@JsonView(WithPasswordView::class) val password: String) {
interface WithPasswordView : WithoutPasswordView
@JsonView 允许视图类数组,但您只能为每个
controller 方法。如果需要激活多个视图,可以使用复合界面。 |
如果您想以编程方式执行上述作,而不是声明@JsonView
注解
将返回值用MappingJacksonValue
并使用它来提供序列化视图:
Java
Kotlin
@RestController
public MappingJacksonValue getUser() {
User user = new User("eric", "7!jd#h23");
MappingJacksonValue value = new MappingJacksonValue(user);
value.setSerializationView(User.WithoutPasswordView.class);
return value;
@RestController
fun getUser(): MappingJacksonValue {
val value = MappingJacksonValue(User("eric", "7!jd#h23"))
value.serializationView = User.WithoutPasswordView::class.java
return value
对于依赖视图分辨率的控制器,您可以添加序列化视图类 添加到模型中,如下例所示:
Java
Kotlin
@Controller
public class UserController extends AbstractController {
public String getUser(Model model) {
model.addAttribute("user", new User("eric", "7!jd#h23"));
model.addAttribute(JsonView.class.getName(), User.WithoutPasswordView.class);
return "userView";
@Controller
class UserController : AbstractController() {
fun getUser(model: Model): String {
model["user"] = User("eric", "7!jd#h23")
model[JsonView::class.qualifiedName] = User.WithoutPasswordView::class.java
return "userView"
