对于最新的稳定版本,请使用 Spring Security 6.4.3! |
身份验证事件
对于每个成功或失败的身份验证,一个AuthenticationSuccessEvent
或AuthenticationFailureEvent
,分别触发。
要侦听这些事件,您必须首先发布AuthenticationEventPublisher
Spring Security 的DefaultAuthenticationEventPublisher
适用于此目的:
Java
Kotlin
public AuthenticationEventPublisher authenticationEventPublisher
(ApplicationEventPublisher applicationEventPublisher) {
return new DefaultAuthenticationEventPublisher(applicationEventPublisher);
fun authenticationEventPublisher
(applicationEventPublisher: ApplicationEventPublisher?): AuthenticationEventPublisher {
return DefaultAuthenticationEventPublisher(applicationEventPublisher)
然后你可以使用 Spring 的@EventListener
支持:
Java
Kotlin
@Component
public class AuthenticationEvents {
@EventListener
public void onSuccess(AuthenticationSuccessEvent success) {
@EventListener
public void onFailure(AbstractAuthenticationFailureEvent failures) {
@Component
@EventListener
fun onSuccess(success: AuthenticationSuccessEvent?) {
@EventListener
fun onFailure(failures: AbstractAuthenticationFailureEvent?) {
虽然与AuthenticationSuccessHandler
和AuthenticationFailureHandler
,这些都很好,因为它们可以独立于 servlet API 使用。
添加异常映射
默认情况下,DefaultAuthenticationEventPublisher
发布AuthenticationFailureEvent
对于以下事件:
例外 |
事件 |
发布者会执行精确的Exception
match,这意味着这些异常的子类不会同时生成事件。
为此,您可能希望通过setAdditionalExceptionMappings
方法:
Java
Kotlin
Map<Class<? extends AuthenticationException>,
Class<? extends AbstractAuthenticationFailureEvent>> mapping =
Collections.singletonMap(FooException.class, FooEvent.class);
AuthenticationEventPublisher authenticationEventPublisher =
authenticationEventPublisher.setAdditionalExceptionMappings(mapping);
return authenticationEventPublisher;
val mapping: Map<Class<out AuthenticationException>, Class<out AbstractAuthenticationFailureEvent>> =
mapOf(Pair(FooException::class.java, FooEvent::class.java))
val authenticationEventPublisher = DefaultAuthenticationEventPublisher(applicationEventPublisher)
默认事件
您还可以提供一个 catch-all 事件,以便在出现任何AuthenticationException
Java
Kotlin
authenticationEventPublisher.setDefaultAuthenticationFailureEvent
(GenericAuthenticationFailureEvent.class);
authenticationEventPublisher.setDefaultAuthenticationFailureEvent(GenericAuthenticationFailureEvent::class.java)
