对于最新的稳定版本,请使用 Spring Security 6.5.0! |
可观察性
Spring Security 与开箱即用的 Spring Observability 集成以进行跟踪;尽管配置收集指标也非常简单。
描图
当ObservationRegistry
bean 存在,则 Spring Security 会为以下对象创建跟踪:
过滤器链
这
ReactiveAuthenticationManager
和 -
这
ReactiveAuthorizationManager
引导集成
例如,考虑一个简单的 Boot 应用程序:
Java
Kotlin
@SpringBootApplication
public class MyApplication {
public ReactiveUserDetailsService userDetailsService() {
return new MapReactiveUserDetailsManager(
User.withDefaultPasswordEncoder()
.username("user")
.password("password")
.authorities("app")
.build()
ObservationRegistryCustomizer<ObservationRegistry> addTextHandler() {
return (registry) -> registry.observationConfig().observationHandler(new ObservationTextHandler());
SpringApplication.run(ListenerSamplesApplication.class, args);
fun userDetailsService(): ReactiveUserDetailsService {
.username("user")
.authorities("app")
.build()
fun addTextHandler(): ObservationRegistryCustomizer<ObservationRegistry> {
return registry: ObservationRegistry -> registry.observationConfig()
.observationHandler(ObservationTextHandler());
fun main(args: Array<String>) {
runApplication<MyApplication>(*args)
以及相应的请求:
?> http -a user:password :8080
将产生以下输出(为清楚起见,添加了缩进):
START - name='http.server.requests', contextualName='null', error='null', lowCardinalityKeyValues=[], highCardinalityKeyValues=[], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@5dfdb78', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.00191856, duration(nanos)=1918560.0, startTimeNanos=101177265022745}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@121549e0']
START - name='spring.security.http.chains', contextualName='spring.security.http.chains.before', error='null', lowCardinalityKeyValues=[chain.size='14', filter.section='before'], highCardinalityKeyValues=[request.line='/'], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@3932a48c', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=4.65777E-4, duration(nanos)=465777.0, startTimeNanos=101177276300777}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@562db70f']
STOP - name='spring.security.http.chains', contextualName='spring.security.http.chains.before', error='null', lowCardinalityKeyValues=[chain.size='14', filter.section='before'], highCardinalityKeyValues=[request.line='/'], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@3932a48c', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.003733105, duration(nanos)=3733105.0, startTimeNanos=101177276300777}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@562db70f']
START - name='spring.security.authentications', contextualName='null', error='null', lowCardinalityKeyValues=[authentication.failure.type='Optional', authentication.method='UserDetailsRepositoryReactiveAuthenticationManager', authentication.request.type='UsernamePasswordAuthenticationToken'], highCardinalityKeyValues=[], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@574ba6cd', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=3.21015E-4, duration(nanos)=321015.0, startTimeNanos=101177336038417}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@49202cc7']
STOP - name='spring.security.authentications', contextualName='null', error='null', lowCardinalityKeyValues=[authentication.failure.type='Optional', authentication.method='UserDetailsRepositoryReactiveAuthenticationManager', authentication.request.type='UsernamePasswordAuthenticationToken', authentication.result.type='UsernamePasswordAuthenticationToken'], highCardinalityKeyValues=[], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@574ba6cd', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.37574992, duration(nanos)=3.7574992E8, startTimeNanos=101177336038417}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@49202cc7']
START - name='spring.security.authorizations', contextualName='null', error='null', lowCardinalityKeyValues=[object.type='SecurityContextServerWebExchange'], highCardinalityKeyValues=[], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@6f837332', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=2.65687E-4, duration(nanos)=265687.0, startTimeNanos=101177777941381}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@7f5bc7cb']
STOP - name='spring.security.authorizations', contextualName='null', error='null', lowCardinalityKeyValues=[authorization.decision='true', object.type='SecurityContextServerWebExchange'], highCardinalityKeyValues=[authentication.authorities='[app]', authorization.decision.details='AuthorizationDecision [granted=true]'], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@6f837332', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.039239047, duration(nanos)=3.9239047E7, startTimeNanos=101177777941381}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@7f5bc7cb']
START - name='spring.security.http.secured.requests', contextualName='null', error='null', lowCardinalityKeyValues=[], highCardinalityKeyValues=[], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@2f33dfae', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=3.1775E-4, duration(nanos)=317750.0, startTimeNanos=101177821377592}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@63b0d28f']
STOP - name='spring.security.http.secured.requests', contextualName='null', error='null', lowCardinalityKeyValues=[], highCardinalityKeyValues=[], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@2f33dfae', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.219901971, duration(nanos)=2.19901971E8, startTimeNanos=101177821377592}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@63b0d28f']
START - name='spring.security.http.chains', contextualName='spring.security.http.chains.after', error='null', lowCardinalityKeyValues=[chain.size='14', filter.section='after'], highCardinalityKeyValues=[request.line='/'], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@40b25623', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=3.25118E-4, duration(nanos)=325118.0, startTimeNanos=101178044824275}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@3b6cec2']
STOP - name='spring.security.http.chains', contextualName='spring.security.http.chains.after', error='null', lowCardinalityKeyValues=[chain.size='14', filter.section='after'], highCardinalityKeyValues=[request.line='/'], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@40b25623', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.001693146, duration(nanos)=1693146.0, startTimeNanos=101178044824275}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@3b6cec2']
STOP - name='http.server.requests', contextualName='null', error='null', lowCardinalityKeyValues=[], highCardinalityKeyValues=[], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@5dfdb78', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.784320641, duration(nanos)=7.84320641E8, startTimeNanos=101177265022745}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@121549e0']
手动配置
对于非 Spring Boot 应用程序,或者要覆盖现有的 Boot 配置,你可以发布自己的ObservationRegistry
Spring Security 仍将获取它。
Java
Kotlin
Xml
.username("user")
.authorities("app")
.build()
ObservationRegistry<ObservationRegistry> observationRegistry() {
ObservationRegistry registry = ObservationRegistry.create();
return registry;
.username("user")
.authorities("app")
.build()
fun observationRegistry(): ObservationRegistry<ObservationRegistry> {
registry.observationConfig().observationHandler(ObservationTextHandler())
return registry
<sec:http auto-config="true" observation-registry-ref="ref">
<sec:intercept-url pattern="/**" access="authenticated"/>
</sec:http>
<!-- define and configure ObservationRegistry bean -->
禁用可观测性
如果您不需要任何 Spring Security 观察,您可以在 Spring Boot 应用程序中发布一个ObservationRegistry.NOOP
但是,这可能会关闭 Spring Security 以外的其他 Observations。
相反,您可以更改提供的ObservationRegistry
替换为ObservationPredicate
如下所示:
Java
Kotlin
ObservationRegistryCustomizer<ObservationRegistry> noSpringSecurityObservations() {
ObservationPredicate predicate = (name, context) -> !name.startsWith("spring.security.")
return (registry) -> registry.observationConfig().observationPredicate(predicate)
fun noSpringSecurityObservations(): ObservationRegistryCustomizer<ObservationRegistry> {
ObservationPredicate predicate = (name: String, context: Observation.Context) -> !name.startsWith("spring.security.")
(registry: ObservationRegistry) -> registry.observationConfig().observationPredicate(predicate)
没有用于禁用具有 XML 支持的观测值的工具。
相反,只需不设置observation-registry-ref 属性。 |
跟踪列表
Spring Security 在每个请求上跟踪以下 span:
spring.security.http.requests
- 包装整个过滤器链(包括请求)的 span -
- 包装安全过滤器的接收部分的 span -
- 包装安全过滤器的返回部分的 span -
- 包装现在保护的应用程序请求的 SPAN -
spring.security.http.unsecured.requests
- 包装 Spring Security 不保护的请求的 span -
- 包装身份验证尝试的 SPAN -
- 包装授权尝试的 SPAN
spring.security.http.chains.before + spring.security.http.secured.requests + spring.security.http.chains.after = spring.security.http.requests
spring.security.http.chains.before + spring.security.http.chains.after = Spring Security 的请求部分 |
