此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Framework 6.1.10! |
默认情况下,未添加注释的日期和时间字段将从
字符串。如果您愿意,可以通过以下方式更改此设置
定义自己的全局格式。@DateTimeFormat
DateFormat.SHORT
为此,请确保 Spring 没有注册默认格式化程序。相反,请注册 在以下帮助下手动格式化程序:
org.springframework.format.datetime.standard.DateTimeFormatterRegistrar
org.springframework.format.datetime.DateFormatterRegistrar
例如,以下 Java 配置注册全局格式:yyyyMMdd
Java
Kotlin
public class AppConfig {
public FormattingConversionService conversionService() {
// Use the DefaultFormattingConversionService but do not register defaults
DefaultFormattingConversionService conversionService =
new DefaultFormattingConversionService(false);
// Ensure @NumberFormat is still supported
conversionService.addFormatterForFieldAnnotation(
new NumberFormatAnnotationFormatterFactory());
// Register JSR-310 date conversion with a specific global format
DateTimeFormatterRegistrar dateTimeRegistrar = new DateTimeFormatterRegistrar();
dateTimeRegistrar.setDateFormatter(DateTimeFormatter.ofPattern("yyyyMMdd"));
dateTimeRegistrar.registerFormatters(conversionService);
// Register date conversion with a specific global format
DateFormatterRegistrar dateRegistrar = new DateFormatterRegistrar();
dateRegistrar.setFormatter(new DateFormatter("yyyyMMdd"));
dateRegistrar.registerFormatters(conversionService);
return conversionService;
class AppConfig {
fun conversionService(): FormattingConversionService {
return DefaultFormattingConversionService(false).apply {
addFormatterForFieldAnnotation(NumberFormatAnnotationFormatterFactory())
val dateTimeRegistrar = DateTimeFormatterRegistrar()
dateTimeRegistrar.registerFormatters(this)
val dateRegistrar = DateFormatterRegistrar()
dateRegistrar.setFormatter(DateFormatter("yyyyMMdd"))
dateRegistrar.registerFormatters(this)
如果更喜欢基于 XML 的配置,则可以使用 .以下示例演示如何执行此操作:FormattingConversionServiceFactoryBean
xsi:schemaLocation="
https://www.springframework.org/schema/beans/spring-beans.xsd">
<bean id="conversionService" class="org.springframework.format.support.FormattingConversionServiceFactoryBean">
<property name="registerDefaultFormatters" value="false" />
<property name="formatters">
<set>
<bean class="org.springframework.format.number.NumberFormatAnnotationFormatterFactory" />
</set>
</property>
<property name="formatterRegistrars">
<set>
<bean class="org.springframework.format.datetime.standard.DateTimeFormatterRegistrar">
<property name="dateFormatter">
<bean class="org.springframework.format.datetime.standard.DateTimeFormatterFactoryBean">
<property name="pattern" value="yyyyMMdd"/>
</bean>
</property>
</bean>
</set>
</property>
</bean>
</beans>
请注意,在 Web 中配置日期和时间格式时需要注意额外的注意事项 应用。请参阅 WebMVC 转换和格式化或 WebFlux 转换和格式化。
