您可以通过 注册客户端过滤器 () 以拦截和修改请求,如以下示例所示:ExchangeFilterFunctionWebClient.Builder
  • Java
  • Kotlin
WebClient client = WebClient.builder()
		.filter((request, next) -> {
			ClientRequest filtered = ClientRequest.from(request)
					.header("foo", "bar")
			return next.exchange(filtered);
val client = WebClient.builder()
		.filter { request, next ->
			val filtered = ClientRequest.from(request)
					.build()
		.build()
这可用于跨领域问题,例如身份验证。以下示例使用 通过静态工厂方法进行基本身份验证的筛选器:
  • Java
  • Kotlin
import static org.springframework.web.reactive.function.client.ExchangeFilterFunctions.basicAuthentication;
		.filter(basicAuthentication("user", "password"))
import org.springframework.web.reactive.function.client.ExchangeFilterFunctions.basicAuthentication
		.build()
可以通过更改现有实例来添加或删除筛选器,从而导致 在不影响原始实例的新实例中。例如:WebClientWebClient
  • Java
  • Kotlin
WebClient client = webClient.mutate()
		.filters(filterList -> {
			filterList.add(0, basicAuthentication("user", "password"));
val client = webClient.mutate()
		.filters { it.add(0, basicAuthentication("user", "password")) }
		.build()
WebClient是围绕过滤器链的薄立面,后跟一个 .它提供了一个工作流来发出请求,对更高级别的编码 level 对象,它有助于确保始终使用响应内容。 当过滤器以某种方式处理响应时,必须格外小心,始终使用该 其内容或以其他方式将其传播到下游,这将确保 一样。下面是一个过滤器,用于处理状态代码,但确保 任何响应内容,无论是否预期,都会发布:ExchangeFunctionWebClientUNAUTHORIZED
  • Java
  • Kotlin
public ExchangeFilterFunction renewTokenFilter() {
	return (request, next) -> next.exchange(request).flatMap(response -> {
		if (response.statusCode().value() == HttpStatus.UNAUTHORIZED.value()) {
			return response.releaseBody()
					.then(renewToken())
					.flatMap(token -> {
						ClientRequest newRequest = ClientRequest.from(request).build();
						return next.exchange(newRequest);
		} else {
			return Mono.just(response);
fun renewTokenFilter(): ExchangeFilterFunction? {
	return ExchangeFilterFunction { request: ClientRequest?, next: ExchangeFunction ->
		next.exchange(request!!).flatMap { response: ClientResponse ->
				return@flatMap response.releaseBody()
						.then(renewToken())
						.flatMap { token: String? ->
							val newRequest = ClientRequest.from(request).build()
			} else {
				return@flatMap Mono.just(response)
下面的示例演示了如何使用接口创建 一个自定义筛选器类,可帮助计算使用缓冲的标头和请求。ExchangeFilterFunctionContent-LengthPUTPOSTmultipart/form-data
  • Java
  • Kotlin
public class MultipartExchangeFilterFunction implements ExchangeFilterFunction {
    public Mono<ClientResponse> filter(ClientRequest request, ExchangeFunction next) {
        if (MediaType.MULTIPART_FORM_DATA.includes(request.headers().getContentType())
                && (request.method() == HttpMethod.PUT || request.method() == HttpMethod.POST)) {
            return next.exchange(ClientRequest.from(request).body((outputMessage, context) ->
                request.body().insert(new BufferingDecorator(outputMessage), context)).build()
        } else {
            return next.exchange(request);
    private static final class BufferingDecorator extends ClientHttpRequestDecorator {
        private BufferingDecorator(ClientHttpRequest delegate) {
            super(delegate);
        public Mono<Void> writeWith(Publisher<? extends DataBuffer> body) {
            return DataBufferUtils.join(body).flatMap(buffer -> {
                getHeaders().setContentLength(buffer.readableByteCount());
                return super.writeWith(Mono.just(buffer));
class MultipartExchangeFilterFunction : ExchangeFilterFunction {
    override fun filter(request: ClientRequest, next: ExchangeFunction): Mono<ClientResponse> {
        return if (MediaType.MULTIPART_FORM_DATA.includes(request.headers().getContentType())
                .body { message, context -> request.body().insert(BufferingDecorator(message), context) }
                .build())
        else {
    private class BufferingDecorator(delegate: ClientHttpRequest) : ClientHttpRequestDecorator(delegate) {
        override fun writeWith(body: Publisher<out DataBuffer>): Mono<Void> {
                .flatMap {
                    headers.contentLength = it.readableByteCount().toLong()
                    super.writeWith(Mono.just(it))
