对于最新的稳定版本,请使用 Spring Security 6.5.0spring-doc.cadn.net.cn
身份验证事件
对于每个成功或失败的身份验证,一个AuthenticationSuccessEventAuthenticationFailureEvent,分别触发。spring-doc.cadn.net.cn
要侦听这些事件,您必须首先发布AuthenticationEventPublisher. Spring Security 的DefaultAuthenticationEventPublisher适用于此目的:spring-doc.cadn.net.cn
public AuthenticationEventPublisher authenticationEventPublisher
        (ApplicationEventPublisher applicationEventPublisher) {
    return new DefaultAuthenticationEventPublisher(applicationEventPublisher);
fun authenticationEventPublisher
        (applicationEventPublisher: ApplicationEventPublisher?): AuthenticationEventPublisher {
    return DefaultAuthenticationEventPublisher(applicationEventPublisher)
然后你可以使用 Spring 的@EventListener支持:spring-doc.cadn.net.cn
@Component
public class AuthenticationEvents {
	@EventListener
    public void onSuccess(AuthenticationSuccessEvent success) {
    @EventListener
    public void onFailure(AbstractAuthenticationFailureEvent failures) {
@Component
    @EventListener
    fun onSuccess(success: AuthenticationSuccessEvent?) {
    @EventListener
    fun onFailure(failures: AbstractAuthenticationFailureEvent?) {
虽然与AuthenticationSuccessHandlerAuthenticationFailureHandler,这些都很好,因为它们可以独立于 servlet API 使用。spring-doc.cadn.net.cn
添加异常映射
默认情况下,DefaultAuthenticationEventPublisher发布AuthenticationFailureEvent对于以下事件:spring-doc.cadn.net.cn
例外spring-doc.cadn.net.cn
事件spring-doc.cadn.net.cn
BadCredentialsExceptionspring-doc.cadn.net.cn
AuthenticationFailureBadCredentialsEventspring-doc.cadn.net.cn
UsernameNotFoundExceptionspring-doc.cadn.net.cn
AccountExpiredExceptionspring-doc.cadn.net.cn
AuthenticationFailureExpiredEventspring-doc.cadn.net.cn
ProviderNotFoundExceptionspring-doc.cadn.net.cn
AuthenticationFailureProviderNotFoundEventspring-doc.cadn.net.cn
DisabledExceptionspring-doc.cadn.net.cn
AuthenticationFailureDisabledEventspring-doc.cadn.net.cn
LockedExceptionspring-doc.cadn.net.cn
AuthenticationFailureLockedEventspring-doc.cadn.net.cn
AuthenticationServiceExceptionspring-doc.cadn.net.cn
AuthenticationFailureServiceExceptionEventspring-doc.cadn.net.cn
CredentialsExpiredExceptionspring-doc.cadn.net.cn
AuthenticationFailureCredentialsExpiredEventspring-doc.cadn.net.cn
InvalidBearerTokenExceptionspring-doc.cadn.net.cn
发布者会执行精确的Exceptionmatch,这意味着这些异常的子类不会同时生成事件。spring-doc.cadn.net.cn
为此,您可能希望通过setAdditionalExceptionMappings方法:spring-doc.cadn.net.cn
    Map<Class<? extends AuthenticationException>,
        Class<? extends AbstractAuthenticationFailureEvent>> mapping =
            Collections.singletonMap(FooException.class, FooEvent.class);
    AuthenticationEventPublisher authenticationEventPublisher =
    authenticationEventPublisher.setAdditionalExceptionMappings(mapping);
    return authenticationEventPublisher;
    val mapping: Map<Class<out AuthenticationException>, Class<out AbstractAuthenticationFailureEvent>> =
            mapOf(Pair(FooException::class.java, FooEvent::class.java))
    val authenticationEventPublisher = DefaultAuthenticationEventPublisher(applicationEventPublisher)
默认事件
您还可以提供一个 catch-all 事件,以便在出现任何AuthenticationException:spring-doc.cadn.net.cn
    authenticationEventPublisher.setDefaultAuthenticationFailureEvent
        (GenericAuthenticationFailureEvent.class);
    authenticationEventPublisher.setDefaultAuthenticationFailureEvent(GenericAuthenticationFailureEvent::class.java)
