对于最新的稳定版本,请使用 Spring Security 6.5.0spring-doc.cadn.net.cn
客户端身份验证支持
JWT 持有者
有关 JWT 不记名客户端身份验证的更多详细信息,请参阅 OAuth 2.0 客户端身份验证和授权的 JSON Web Tokens (JWT) 配置文件。
JWT 不记名客户端身份验证的默认实现是NimbusJwtClientAuthenticationParametersConverter, 这是一个Converter,通过添加 已签名的 JSON Web Tokens (JWS)client_assertion参数。spring-doc.cadn.net.cn
java.security.PrivateKeyjavax.crypto.SecretKey用于签署 JWS 由com.nimbusds.jose.jwk.JWK解析器关联NimbusJwtClientAuthenticationParametersConverter.spring-doc.cadn.net.cn
身份验证方式private_key_jwt
给定 OAuth 2.0 客户端注册的以下 Spring Boot 2.x 属性:spring-doc.cadn.net.cn
spring:
  security:
    oauth2:
      client:
        registration:
          okta:
            client-id: okta-client-id
            client-authentication-method: private_key_jwt
            authorization-grant-type: authorization_code
以下示例显示如何配置WebClientReactiveAuthorizationCodeTokenResponseClient:spring-doc.cadn.net.cn
Function<ClientRegistration, JWK> jwkResolver = (clientRegistration) -> {
	if (clientRegistration.getClientAuthenticationMethod().equals(ClientAuthenticationMethod.PRIVATE_KEY_JWT)) {
		// Assuming RSA key type
		RSAPublicKey publicKey = ...
		RSAPrivateKey privateKey = ...
		return new RSAKey.Builder(publicKey)
				.privateKey(privateKey)
				.keyID(UUID.randomUUID().toString())
	return null;
WebClientReactiveAuthorizationCodeTokenResponseClient tokenResponseClient =
		new WebClientReactiveAuthorizationCodeTokenResponseClient();
tokenResponseClient.addParametersConverter(
		new NimbusJwtClientAuthenticationParametersConverter<>(jwkResolver));
val jwkResolver: Function<ClientRegistration, JWK> =
    Function<ClientRegistration, JWK> { clientRegistration ->
        if (clientRegistration.clientAuthenticationMethod.equals(ClientAuthenticationMethod.PRIVATE_KEY_JWT)) {
            var publicKey: RSAPublicKey = ...
            var privateKey: RSAPrivateKey = ...
                .build()
        null
val tokenResponseClient = WebClientReactiveAuthorizationCodeTokenResponseClient()
    NimbusJwtClientAuthenticationParametersConverter(jwkResolver)
身份验证方式client_secret_jwt
spring:
  security:
    oauth2:
      client:
        registration:
          okta:
            client-authentication-method: client_secret_jwt
            authorization-grant-type: client_credentials
以下示例显示如何配置WebClientReactiveClientCredentialsTokenResponseClient:spring-doc.cadn.net.cn
	if (clientRegistration.getClientAuthenticationMethod().equals(ClientAuthenticationMethod.CLIENT_SECRET_JWT)) {
		SecretKeySpec secretKey = new SecretKeySpec(
				clientRegistration.getClientSecret().getBytes(StandardCharsets.UTF_8),
				"HmacSHA256");
		return new OctetSequenceKey.Builder(secretKey)
	return null;
WebClientReactiveClientCredentialsTokenResponseClient tokenResponseClient =
		new WebClientReactiveClientCredentialsTokenResponseClient();
val jwkResolver = Function<ClientRegistration, JWK?> { clientRegistration: ClientRegistration ->
    if (clientRegistration.clientAuthenticationMethod == ClientAuthenticationMethod.CLIENT_SECRET_JWT) {
        val secretKey = SecretKeySpec(
            clientRegistration.clientSecret.toByteArray(StandardCharsets.UTF_8),
            "HmacSHA256"
            .build()
    null
val tokenResponseClient = WebClientReactiveClientCredentialsTokenResponseClient()
自定义 JWT 断言
生成的 JWTNimbusJwtClientAuthenticationParametersConverter包含iss,sub,aud,jti,iatexp声明。您可以通过提供Consumer<NimbusJwtClientAuthenticationParametersConverter.JwtClientAuthenticationContext<T>>setJwtClientAssertionCustomizer().以下示例显示如何自定义 JWT 的声明:spring-doc.cadn.net.cn
Function<ClientRegistration, JWK> jwkResolver = ...
NimbusJwtClientAuthenticationParametersConverter<OAuth2ClientCredentialsGrantRequest> converter =
		new NimbusJwtClientAuthenticationParametersConverter<>(jwkResolver);
converter.setJwtClientAssertionCustomizer((context) -> {
	context.getHeaders().header("custom-header", "header-value");
	context.getClaims().claim("custom-claim", "claim-value");
val jwkResolver = ...
val converter: NimbusJwtClientAuthenticationParametersConverter<OAuth2ClientCredentialsGrantRequest> =
converter.setJwtClientAssertionCustomizer { context ->
    context.headers.header("custom-header", "header-value")
    context.claims.claim("custom-claim", "claim-value")
