此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Boot 3.4.3! |
反应式 Web 应用程序
Spring Boot 通过为 Spring Webflux 提供自动配置来简化反应式 Web 应用程序的开发。
“Spring WebFlux 框架”
Spring WebFlux 是 Spring Framework 5.0 中引入的新反应式 Web 框架。 与 Spring MVC 不同,它不需要 servlet API,是完全异步和非阻塞的,并通过 Reactor 项目实现反应流规范。
Spring WebFlux 有两种风格:函数式和基于 Comments 的。 基于 Comments 的模型与 Spring MVC 模型非常接近,如以下示例所示:
Java
Kotlin
import reactor.core.publisher.Flux;
import reactor.core.publisher.Mono;
import org.springframework.web.bind.annotation.DeleteMapping;
import org.springframework.web.bind.annotation.GetMapping;
import org.springframework.web.bind.annotation.PathVariable;
import org.springframework.web.bind.annotation.RequestMapping;
import org.springframework.web.bind.annotation.RestController;
@RestController
@RequestMapping("/users")
public class MyRestController {
private final UserRepository userRepository;
private final CustomerRepository customerRepository;
public MyRestController(UserRepository userRepository, CustomerRepository customerRepository) {
this.userRepository = userRepository;
this.customerRepository = customerRepository;
@GetMapping("/{userId}")
public Mono<User> getUser(@PathVariable Long userId) {
return this.userRepository.findById(userId);
@GetMapping("/{userId}/customers")
public Flux<Customer> getUserCustomers(@PathVariable Long userId) {
return this.userRepository.findById(userId).flatMapMany(this.customerRepository::findByUser);
@DeleteMapping("/{userId}")
public Mono<Void> deleteUser(@PathVariable Long userId) {
return this.userRepository.deleteById(userId);
@RestController
class MyRestController(private val userRepository: UserRepository, private val customerRepository: CustomerRepository) {
fun getUser(@PathVariable userId: Long): Mono<User?> {
return userRepository.findById(userId)
fun getUserCustomers(@PathVariable userId: Long): Flux<Customer> {
return userRepository.findById(userId).flatMapMany { user: User? ->
customerRepository.findByUser(user)
fun deleteUser(@PathVariable userId: Long): Mono<Void> {
return userRepository.deleteById(userId)
WebFlux is part of the Spring Framework and detailed information is available in its reference documentation.
“WebFlux.fn”, the functional variant, separates the routing configuration from the actual handling of the requests, as shown in the following example:
Java
Kotlin
import org.springframework.http.MediaType;
import org.springframework.web.reactive.function.server.RequestPredicate;
import org.springframework.web.reactive.function.server.RouterFunction;
import org.springframework.web.reactive.function.server.ServerResponse;
import static org.springframework.web.reactive.function.server.RequestPredicates.accept;
import static org.springframework.web.reactive.function.server.RouterFunctions.route;
public class MyRoutingConfiguration {
private static final RequestPredicate ACCEPT_JSON = accept(MediaType.APPLICATION_JSON);
public RouterFunction<ServerResponse> monoRouterFunction(MyUserHandler userHandler) {
return route()
.GET("/{user}", ACCEPT_JSON, userHandler::getUser)
.GET("/{user}/customers", ACCEPT_JSON, userHandler::getUserCustomers)
.DELETE("/{user}", ACCEPT_JSON, userHandler::deleteUser)
import org.springframework.web.reactive.function.server.RequestPredicates.DELETE
import org.springframework.web.reactive.function.server.RequestPredicates.GET
import org.springframework.web.reactive.function.server.RequestPredicates.accept
import org.springframework.web.reactive.function.server.RouterFunctions
fun monoRouterFunction(userHandler: MyUserHandler): RouterFunction<ServerResponse> {
return RouterFunctions.route(
GET("/{user}").and(ACCEPT_JSON), userHandler::getUser).andRoute(
GET("/{user}/customers").and(ACCEPT_JSON), userHandler::getUserCustomers).andRoute(
DELETE("/{user}").and(ACCEPT_JSON), userHandler::deleteUser)
companion object {
private val ACCEPT_JSON = accept(MediaType.APPLICATION_JSON)
Java
Kotlin
import org.springframework.web.reactive.function.server.ServerRequest;
@Component
public class MyUserHandler {
public Mono<ServerResponse> getUser(ServerRequest request) {
public Mono<ServerResponse> getUserCustomers(ServerRequest request) {
public Mono<ServerResponse> deleteUser(ServerRequest request) {
@Component
fun getUser(request: ServerRequest?): Mono<ServerResponse> {
fun getUserCustomers(request: ServerRequest?): Mono<ServerResponse> {
fun deleteUser(request: ServerRequest?): Mono<ServerResponse> {
“WebFlux.fn” is part of the Spring Framework and detailed information is available in its reference documentation.
You can define as many RouterFunction
beans as you like to modularize the definition of the router.
Beans can be ordered if you need to apply a precedence.
To get started, add the spring-boot-starter-webflux
module to your application.
Adding both spring-boot-starter-web
and spring-boot-starter-webflux
modules in your application results in Spring Boot auto-configuring Spring MVC, not WebFlux.
This behavior has been chosen because many Spring developers add spring-boot-starter-webflux
to their Spring MVC application to use the reactive WebClient
You can still enforce your choice by setting the chosen application type to SpringApplication.setWebApplicationType(WebApplicationType.REACTIVE)
Spring WebFlux Auto-configuration
Spring Boot provides auto-configuration for Spring WebFlux that works well with most applications.
The auto-configuration adds the following features on top of Spring’s defaults:
Configuring codecs for HttpMessageReader
and HttpMessageWriter
instances (described later in this document).
Support for serving static resources, including support for WebJars (described later in this document).
If you want to keep Spring Boot WebFlux features and you want to add additional WebFlux configuration, you can add your own @Configuration
class of type WebFluxConfigurer
but without @EnableWebFlux
If you want to add additional customization to the auto-configured HttpHandler
, you can define beans of type WebHttpHandlerBuilderCustomizer
and use them to modify the WebHttpHandlerBuilder
If you want to take complete control of Spring WebFlux, you can add your own @Configuration
annotated with @EnableWebFlux
Spring WebFlux Conversion Service
If you want to customize the ConversionService
used by Spring WebFlux, you can provide a WebFluxConfigurer
bean with an addFormatters
method.
Conversion can also be customized using the spring.webflux.format.*
configuration properties.
When not configured, the following defaults are used:
Property
DateTimeFormatter
Formats
spring.webflux.format.date
ofLocalizedDate(FormatStyle.SHORT)
java.util.Date
and LocalDate
spring.webflux.format.time
ofLocalizedTime(FormatStyle.SHORT)
java.time’s LocalTime
and OffsetTime
spring.webflux.format.date-time
ofLocalizedDateTime(FormatStyle.SHORT)
java.time’s LocalDateTime
, OffsetDateTime
, and ZonedDateTime
HTTP Codecs with HttpMessageReaders and HttpMessageWriters
Spring WebFlux uses the HttpMessageReader
interfaces to convert HTTP requests and responses.
They are configured with CodecConfigurer
to have sensible defaults by looking at the libraries available in your classpath.
Spring Boot provides dedicated configuration properties for codecs, spring.codec.*
It also applies further customization by using CodecCustomizer
instances.
For example, spring.jackson.*
configuration keys are applied to the Jackson codec.
If you need to add or customize codecs, you can create a custom CodecCustomizer
component, as shown in the following example:
Java
Kotlin
import org.springframework.boot.web.codec.CodecCustomizer;
import org.springframework.http.codec.ServerSentEventHttpMessageReader;
public class MyCodecsConfiguration {
public CodecCustomizer myCodecCustomizer() {
return (configurer) -> {
configurer.registerDefaults(false);
configurer.customCodecs().register(new ServerSentEventHttpMessageReader());
import org.springframework.http.codec.CodecConfigurer
fun myCodecCustomizer(): CodecCustomizer {
return CodecCustomizer { configurer: CodecConfigurer ->
configurer.customCodecs().register(ServerSentEventHttpMessageReader())
You can also leverage Boot’s custom JSON serializers and deserializers.
Static Content
By default, Spring Boot serves static content from a directory called /static
(or /public
or /resources
or /META-INF/resources
) in the classpath.
It uses the ResourceWebHandler
from Spring WebFlux so that you can modify that behavior by adding your own WebFluxConfigurer
and overriding the addResourceHandlers
method.
By default, resources are mapped on , but you can tune that by setting the /**
spring.webflux.static-path-pattern
property.
For instance, relocating all resources to /resources/**
can be achieved as follows:
Properties
YAML
spring.webflux.static-path-pattern=/resources/**
spring:
webflux:
static-path-pattern: "/resources/**"
You can also customize the static resource locations by using spring.web.resources.static-locations
Doing so replaces the default values with a list of directory locations.
If you do so, the default welcome page detection switches to your custom locations.
So, if there is an index.html
in any of your locations on startup, it is the home page of the application.
In addition to the “standard” static resource locations listed earlier, a special case is made for Webjars content.
By default, any resources with a path in /webjars/**
are served from jar files if they are packaged in the Webjars format.
The path can be customized with the spring.webflux.webjars-path-pattern
property.
Spring WebFlux applications do not strictly depend on the servlet API, so they cannot be deployed as war files and do not use the src/main/webapp
directory.
Welcome Page
Spring Boot supports both static and templated welcome pages.
It first looks for an index.html
file in the configured static content locations.
If one is not found, it then looks for an index
template.
If either is found, it is automatically used as the welcome page of the application.
This only acts as a fallback for actual index routes defined by the application.
The ordering is defined by the order of HandlerMapping
beans which is by default the following:
org.springframework.web.reactive.function.server.support.RouterFunctionMapping
Endpoints declared with RouterFunction
beans
org.springframework.web.reactive.result.method.annotation.RequestMappingHandlerMapping
Endpoints declared in @Controller
beans
for the Welcome Page
The welcome page support
Template Engines
As well as REST web services, you can also use Spring WebFlux to serve dynamic HTML content.
Spring WebFlux supports a variety of templating technologies, including Thymeleaf, FreeMarker, and Mustache.
Spring Boot includes auto-configuration support for the following templating engines:
Not all FreeMarker features are supported with WebFlux.
For more details, check the description of each property.
When you use one of these templating engines with the default configuration, your templates are picked up automatically from src/main/resources/templates
Error Handling
Spring Boot provides a WebExceptionHandler
that handles all errors in a sensible way.
Its position in the processing order is immediately before the handlers provided by WebFlux, which are considered last.
For machine clients, it produces a JSON response with details of the error, the HTTP status, and the exception message.
For browser clients, there is a “whitelabel” error handler that renders the same data in HTML format.
You can also provide your own HTML templates to display errors (see the next section).
Before customizing error handling in Spring Boot directly, you can leverage the RFC 9457 Problem Details support in Spring WebFlux.
Spring WebFlux can produce custom error messages with the application/problem+json
media type, like:
"type": "https://example.org/problems/unknown-project",
"title": "Unknown project",
"status": 404,
"detail": "No project found for id 'spring-unknown'",
"instance": "/projects/spring-unknown"
This support can be enabled by setting spring.webflux.problemdetails.enabled
to true
The first step to customizing this feature often involves using the existing mechanism but replacing or augmenting the error contents.
For that, you can add a bean of type ErrorAttributes
To change the error handling behavior, you can implement ErrorWebExceptionHandler
and register a bean definition of that type.
Because an ErrorWebExceptionHandler
is quite low-level, Spring Boot also provides a convenient AbstractErrorWebExceptionHandler
to let you handle errors in a WebFlux functional way, as shown in the following example:
Java
Kotlin
import org.springframework.boot.autoconfigure.web.WebProperties;
import org.springframework.boot.autoconfigure.web.reactive.error.AbstractErrorWebExceptionHandler;
import org.springframework.boot.web.reactive.error.ErrorAttributes;
import org.springframework.context.ApplicationContext;
import org.springframework.http.HttpStatus;
import org.springframework.http.codec.ServerCodecConfigurer;
import org.springframework.web.reactive.function.server.RouterFunctions;
import org.springframework.web.reactive.function.server.ServerResponse.BodyBuilder;
@Component
public class MyErrorWebExceptionHandler extends AbstractErrorWebExceptionHandler {
public MyErrorWebExceptionHandler(ErrorAttributes errorAttributes, WebProperties webProperties,
ApplicationContext applicationContext, ServerCodecConfigurer serverCodecConfigurer) {
super(errorAttributes, webProperties.getResources(), applicationContext);
setMessageReaders(serverCodecConfigurer.getReaders());
setMessageWriters(serverCodecConfigurer.getWriters());
protected RouterFunction<ServerResponse> getRoutingFunction(ErrorAttributes errorAttributes) {
return RouterFunctions.route(this::acceptsXml, this::handleErrorAsXml);
private boolean acceptsXml(ServerRequest request) {
return request.headers().accept().contains(MediaType.APPLICATION_XML);
public Mono<ServerResponse> handleErrorAsXml(ServerRequest request) {
BodyBuilder builder = ServerResponse.status(HttpStatus.INTERNAL_SERVER_ERROR);
// ... additional builder calls
return builder.build();
@Component
class MyErrorWebExceptionHandler(
errorAttributes: ErrorAttributes, webProperties: WebProperties,
applicationContext: ApplicationContext, serverCodecConfigurer: ServerCodecConfigurer
) : AbstractErrorWebExceptionHandler(errorAttributes, webProperties.resources, applicationContext) {
init {
setMessageReaders(serverCodecConfigurer.readers)
setMessageWriters(serverCodecConfigurer.writers)
override fun getRoutingFunction(errorAttributes: ErrorAttributes): RouterFunction<ServerResponse> {
private fun acceptsXml(request: ServerRequest): Boolean {
fun handleErrorAsXml(request: ServerRequest): Mono<ServerResponse> {
val builder = ServerResponse.status(HttpStatus.INTERNAL_SERVER_ERROR)
For a more complete picture, you can also subclass DefaultErrorWebExceptionHandler
directly and override specific methods.
In some cases, errors handled at the controller level are not recorded by web observations or the metrics infrastructure.
Applications can ensure that such exceptions are recorded with the observations by setting the handled exception on the observation context.
Custom Error Pages
If you want to display a custom HTML error page for a given status code, you can add views that resolve from error/*
, for example by adding files to a /error
directory.
Error pages can either be static HTML (that is, added under any of the static resource directories) or built with templates.
The name of the file should be the exact status code, a status code series mask, or error
for a default if nothing else matches.
Note that the path to the default error view is error/error
, whereas with Spring MVC the default error view is error
For example, to map 404
to a static HTML file, your directory structure would be as follows:
src/
+- main/
+- java/
| + <source code>
+- resources/
+- public/
+- error/
| +- 404.html
+- <other public assets>
To map all 5xx
errors by using a Mustache template, your directory structure would be as follows:
src/
+- main/
+- java/
| + <source code>
+- resources/
+- templates/
+- error/
| +- 5xx.mustache
+- <other templates>
Web Filters
Spring WebFlux provides a WebFilter
interface that can be implemented to filter HTTP request-response exchanges.
WebFilter
beans found in the application context will be automatically used to filter each exchange.
Where the order of the filters is important they can implement Ordered
or be annotated with @Order
Spring Boot auto-configuration may configure web filters for you.
When it does so, the orders shown in the following table will be used:
Web Filter
Order
WebFilterChainProxy
(Spring Security)
-100
Ordered.LOWEST_PRECEDENCE - 10
Embedded Reactive Server Support
Spring Boot includes support for the following embedded reactive web servers: Reactor Netty, Tomcat, Jetty, and Undertow.
Most developers use the appropriate starter to obtain a fully configured instance.
By default, the embedded server listens for HTTP requests on port 8080.
Customizing Reactive Servers
Common reactive web server settings can be configured by using Spring Environment
properties.
Usually, you would define the properties in your application.properties
or application.yaml
file.
Common server settings include:
Network settings: Listen port for incoming HTTP requests (server.port
), interface address to bind to (server.address
), and so on.
Error management: Location of the error page (server.error.path
) and so on.
Spring Boot tries as much as possible to expose common settings, but this is not always possible.
For those cases, dedicated namespaces such as server.netty.*
offer server-specific customizations.
See the ServerProperties
class for a complete list.
Programmatic Customization
If you need to programmatically configure your reactive web server, you can register a Spring bean that implements the WebServerFactoryCustomizer
interface.
provides access to the ConfigurableReactiveWebServerFactory
, which includes numerous customization setter methods.
The following example shows programmatically setting the port:
Java
Kotlin
import org.springframework.boot.web.reactive.server.ConfigurableReactiveWebServerFactory;
import org.springframework.boot.web.server.WebServerFactoryCustomizer;
@Component
public class MyWebServerFactoryCustomizer implements WebServerFactoryCustomizer<ConfigurableReactiveWebServerFactory> {
public void customize(ConfigurableReactiveWebServerFactory server) {
server.setPort(9000);
@Component
class MyWebServerFactoryCustomizer : WebServerFactoryCustomizer<ConfigurableReactiveWebServerFactory> {
override fun customize(server: ConfigurableReactiveWebServerFactory) {
JettyReactiveWebServerFactory
, NettyReactiveWebServerFactory
, TomcatReactiveWebServerFactory
, and UndertowReactiveWebServerFactory
are dedicated variants of ConfigurableReactiveWebServerFactory
that have additional customization setter methods for Jetty, Reactor Netty, Tomcat, and Undertow respectively.
The following example shows how to customize NettyReactiveWebServerFactory
that provides access to Reactor Netty-specific configuration options:
Java
Kotlin
import java.time.Duration;
import org.springframework.boot.web.embedded.netty.NettyReactiveWebServerFactory;
@Component
public class MyNettyWebServerFactoryCustomizer implements WebServerFactoryCustomizer<NettyReactiveWebServerFactory> {
public void customize(NettyReactiveWebServerFactory factory) {
factory.addServerCustomizers((server) -> server.idleTimeout(Duration.ofSeconds(20)));
@Component
class MyNettyWebServerFactoryCustomizer : WebServerFactoryCustomizer<NettyReactiveWebServerFactory> {
override fun customize(factory: NettyReactiveWebServerFactory) {
factory.addServerCustomizers({ server -> server.idleTimeout(Duration.ofSeconds(20)) })
Customizing ConfigurableReactiveWebServerFactory Directly
For more advanced use cases that require you to extend from ReactiveWebServerFactory
, you can expose a bean of such type yourself.
Setters are provided for many configuration options.
Several protected method “hooks” are also provided should you need to do something more exotic.
See the ConfigurableReactiveWebServerFactory
API documentation for details.
Auto-configured customizers are still applied on your custom factory, so use that option carefully.
Reactive Server Resources Configuration
When auto-configuring a Reactor Netty or Jetty server, Spring Boot will create specific beans that will provide HTTP resources to the server instance: ReactorResourceFactory
or JettyResourceFactory
By default, those resources will be also shared with the Reactor Netty and Jetty clients for optimal performances, given:
the same technology is used for server and client
the client instance is built using the WebClient.Builder
bean auto-configured by Spring Boot
Developers can override the resource configuration for Jetty and Reactor Netty by providing a custom ReactorResourceFactory
bean - this will be applied to both clients and servers.
You can learn more about the resource configuration on the client side in the WebClient Runtime section.
