此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Boot 3.4.3spring-doc.cadn.net.cn
测试实用程序
在测试应用程序时通常有用的一些测试工具类打包为spring-boot.spring-doc.cadn.net.cn
ConfigDataApplicationContextInitializer
ConfigDataApplicationContextInitializer是一个ApplicationContextInitializer您可以将其应用于测试以加载 Spring Bootapplication.properties文件。 当您不需要@SpringBootTest,如以下示例所示:spring-doc.cadn.net.cn
import org.springframework.boot.test.context.ConfigDataApplicationContextInitializer;
import org.springframework.test.context.ContextConfiguration;
@ContextConfiguration(classes = Config.class, initializers = ConfigDataApplicationContextInitializer.class)
class MyConfigFileTests {
@ContextConfiguration(classes = [Config::class], initializers = [ConfigDataApplicationContextInitializer::class])
Using ConfigDataApplicationContextInitializer alone does not provide support for @Value("${…​}") injection. Its only job is to ensure that application.properties files are loaded into Spring’s Environment. For @Value support, you need to either additionally configure a PropertySourcesPlaceholderConfigurer or use @SpringBootTest, which auto-configures one for you.
TestPropertyValues
TestPropertyValues lets you quickly add properties to a ConfigurableEnvironment or ConfigurableApplicationContext. You can call it with key=value strings, as follows:spring-doc.cadn.net.cn
import org.junit.jupiter.api.Test;
import org.springframework.boot.test.util.TestPropertyValues;
import org.springframework.mock.env.MockEnvironment;
import static org.assertj.core.api.Assertions.assertThat;
class MyEnvironmentTests {
	@Test
	void testPropertySources() {
		MockEnvironment environment = new MockEnvironment();
		TestPropertyValues.of("org=Spring", "name=Boot").applyTo(environment);
		assertThat(environment.getProperty("name")).isEqualTo("Boot");
import org.assertj.core.api.Assertions.assertThat
	@Test
	fun testPropertySources() {
		val environment = MockEnvironment()
OutputCaptureExtension
OutputCaptureExtension is a JUnit Extension that you can use to capture System.out and System.err output. To use it, add @ExtendWith(OutputCaptureExtension.class) and inject CapturedOutput as an argument to your test class constructor or test method as follows:spring-doc.cadn.net.cn
import org.junit.jupiter.api.extension.ExtendWith;
import org.springframework.boot.test.system.CapturedOutput;
import org.springframework.boot.test.system.OutputCaptureExtension;
class MyOutputCaptureTests {
	@Test
	void testName(CapturedOutput output) {
		System.out.println("Hello World!");
		assertThat(output).contains("World");
@ExtendWith(OutputCaptureExtension::class)
	@Test
	fun testName(output: CapturedOutput?) {
TestRestTemplate
TestRestTemplate is a convenience alternative to Spring’s RestTemplate that is useful in integration tests. You can get a vanilla template or one that sends Basic HTTP authentication (with a username and password). In either case, the template is fault tolerant. This means that it behaves in a test-friendly way by not throwing exceptions on 4xx and 5xx errors. Instead, such errors can be detected through the returned ResponseEntity and its status code.spring-doc.cadn.net.cn
Spring Framework 5.0 provides a new WebTestClient that works for WebFlux integration tests and both WebFlux and MVC end-to-end testing. It provides a fluent API for assertions, unlike TestRestTemplate.
It is recommended, but not mandatory, to use the Apache HTTP Client (version 5.1 or better). If you have that on your classpath, the TestRestTemplate responds by configuring the client appropriately. If you do use Apache’s HTTP client, some additional test-friendly features are enabled:spring-doc.cadn.net.cn
TestRestTemplate can be instantiated directly in your integration tests, as shown in the following example:spring-doc.cadn.net.cn
import org.springframework.boot.test.web.client.TestRestTemplate;
import org.springframework.http.ResponseEntity;
class MyTests {
	private final TestRestTemplate template = new TestRestTemplate();
	@Test
	void testRequest() {
		ResponseEntity<String> headers = this.template.getForEntity("https://myhost.example.com/example", String.class);
		assertThat(headers.getHeaders().getLocation()).hasHost("other.example.com");
class MyTests {
	private val template = TestRestTemplate()
	@Test
	fun testRequest() {
		val headers = template.getForEntity("https://myhost.example.com/example", String::class.java)
		assertThat(headers.headers.location).hasHost("other.example.com")
Alternatively, if you use the @SpringBootTest annotation with WebEnvironment.RANDOM_PORT or WebEnvironment.DEFINED_PORT, you can inject a fully configured TestRestTemplate and start using it. If necessary, additional customizations can be applied through the RestTemplateBuilder bean. Any URLs that do not specify a host and port automatically connect to the embedded server, as shown in the following example:spring-doc.cadn.net.cn
import java.time.Duration;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.boot.test.context.SpringBootTest;
import org.springframework.boot.test.context.SpringBootTest.WebEnvironment;
import org.springframework.boot.test.context.TestConfiguration;
import org.springframework.boot.web.client.RestTemplateBuilder;
import org.springframework.http.HttpHeaders;
@SpringBootTest(webEnvironment = WebEnvironment.RANDOM_PORT)
class MySpringBootTests {
	@Autowired
	private TestRestTemplate template;
	@Test
		HttpHeaders headers = this.template.getForEntity("/example", String.class).getHeaders();
		assertThat(headers.getLocation()).hasHost("other.example.com");
	@TestConfiguration(proxyBeanMethods = false)
	static class RestTemplateBuilderConfiguration {
		RestTemplateBuilder restTemplateBuilder() {
			return new RestTemplateBuilder().connectTimeout(Duration.ofSeconds(1)).readTimeout(Duration.ofSeconds(1));
class MySpringBootTests(@Autowired val template: TestRestTemplate) {
	@Test
	fun testRequest() {
		val headers = template.getForEntity("/example", String::class.java).headers
		assertThat(headers.location).hasHost("other.example.com")
	internal class RestTemplateBuilderConfiguration {
		fun restTemplateBuilder(): RestTemplateBuilder {
			return RestTemplateBuilder().connectTimeout(Duration.ofSeconds(1))
