此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Boot 3.4.3! |
Apache Kafka 支持
Apache Kafka 通过提供spring-kafka
项目。
Kafka 配置由spring.kafka.*
例如,您可以在application.properties
Properties
YAML
spring.kafka.bootstrap-servers=localhost:9092
spring.kafka.consumer.group-id=myGroup
spring:
kafka:
bootstrap-servers: "localhost:9092"
consumer:
group-id: "myGroup"
要在启动时创建主题,请添加NewTopic .
如果主题已存在,则忽略该 Bean。 |
看KafkaProperties
以获取更多支持的选项。
发送消息
Spring的KafkaTemplate
是自动配置的,你可以直接在自己的 bean 中自动装配它,如以下示例所示:
Java
Kotlin
import org.springframework.kafka.core.KafkaTemplate;
@Component
public class MyBean {
private final KafkaTemplate<String, String> kafkaTemplate;
public MyBean(KafkaTemplate<String, String> kafkaTemplate) {
this.kafkaTemplate = kafkaTemplate;
public void someMethod() {
this.kafkaTemplate.send("someTopic", "Hello");
@Component
class MyBean(private val kafkaTemplate: KafkaTemplate<String, String>) {
fun someMethod() {
If the property spring.kafka.producer.transaction-id-prefix
is defined, a KafkaTransactionManager
is automatically configured.
Also, if a RecordMessageConverter
bean is defined, it is automatically associated to the auto-configured KafkaTemplate
Receiving a Message
When the Apache Kafka infrastructure is present, any bean can be annotated with @KafkaListener
to create a listener endpoint.
If no KafkaListenerContainerFactory
has been defined, a default one is automatically configured with keys defined in spring.kafka.listener.*
The following component creates a listener endpoint on the someTopic
topic:
Java
Kotlin
import org.springframework.kafka.annotation.KafkaListener;
@Component
@KafkaListener(topics = "someTopic")
public void processMessage(String content) {
@Component
class MyBean {
@KafkaListener(topics = ["someTopic"])
fun processMessage(content: String?) {
If a KafkaTransactionManager
bean is defined, it is automatically associated to the container factory.
Similarly, if a RecordFilterStrategy
, CommonErrorHandler
, AfterRollbackProcessor
or ConsumerAwareRebalanceListener
bean is defined, it is automatically associated to the default factory.
Depending on the listener type, a RecordMessageConverter
or BatchMessageConverter
bean is associated to the default factory.
If only a RecordMessageConverter
bean is present for a batch listener, it is wrapped in a BatchMessageConverter
A custom ChainedKafkaTransactionManager
must be marked @Primary
as it usually references the auto-configured KafkaTransactionManager
bean.
Kafka Streams
Spring for Apache Kafka provides a factory bean to create a StreamsBuilder
object and manage the lifecycle of its streams.
Spring Boot auto-configures the required KafkaStreamsConfiguration
bean as long as kafka-streams
is on the classpath and Kafka Streams is enabled by the @EnableKafkaStreams
annotation.
Enabling Kafka Streams means that the application id and bootstrap servers must be set.
The former can be configured using spring.kafka.streams.application-id
, defaulting to spring.application.name
if not set.
The latter can be set globally or specifically overridden only for streams.
Several additional properties are available using dedicated properties; other arbitrary Kafka properties can be set using the spring.kafka.streams.properties
namespace.
See also Additional Kafka Properties for more information.
To use the factory bean, wire StreamsBuilder
into your @Bean
as shown in the following example:
Java
Kotlin
import java.util.Locale;
import org.apache.kafka.common.serialization.Serdes;
import org.apache.kafka.streams.KeyValue;
import org.apache.kafka.streams.StreamsBuilder;
import org.apache.kafka.streams.kstream.KStream;
import org.apache.kafka.streams.kstream.Produced;
import org.springframework.kafka.annotation.EnableKafkaStreams;
import org.springframework.kafka.support.serializer.JsonSerde;
@EnableKafkaStreams
public class MyKafkaStreamsConfiguration {
public KStream<Integer, String> kStream(StreamsBuilder streamsBuilder) {
KStream<Integer, String> stream = streamsBuilder.stream("ks1In");
stream.map(this::uppercaseValue).to("ks1Out", Produced.with(Serdes.Integer(), new JsonSerde<>()));
return stream;
private KeyValue<Integer, String> uppercaseValue(Integer key, String value) {
return new KeyValue<>(key, value.toUpperCase(Locale.getDefault()));
@EnableKafkaStreams
fun kStream(streamsBuilder: StreamsBuilder): KStream<Int, String> {
val stream = streamsBuilder.stream<Int, String>("ks1In")
stream.map(this::uppercaseValue).to("ks1Out", Produced.with(Serdes.Integer(), JsonSerde()))
return stream
private fun uppercaseValue(key: Int, value: String): KeyValue<Int?, String?> {
return KeyValue(key, value.uppercase())
By default, the streams managed by the StreamsBuilder
object are started automatically.
You can customize this behavior using the spring.kafka.streams.auto-startup
property.
The properties supported by auto configuration are shown in the Integration Properties section of the Appendix.
Note that, for the most part, these properties (hyphenated or camelCase) map directly to the Apache Kafka dotted properties.
See the Apache Kafka documentation for details.
Properties that don’t include a client type (producer
, consumer
, admin
, or streams
) in their name are considered to be common and apply to all clients.
Most of these common properties can be overridden for one or more of the client types, if needed.
Apache Kafka designates properties with an importance of HIGH, MEDIUM, or LOW.
Spring Boot auto-configuration supports all HIGH importance properties, some selected MEDIUM and LOW properties, and any properties that do not have a default value.
Only a subset of the properties supported by Kafka are available directly through the KafkaProperties
class.
If you wish to configure the individual client types with additional properties that are not directly supported, use the following properties:
Properties
YAML
spring.kafka.properties[prop.one]=first
spring.kafka.admin.properties[prop.two]=second
spring.kafka.consumer.properties[prop.three]=third
spring.kafka.producer.properties[prop.four]=fourth
spring.kafka.streams.properties[prop.five]=fifth
spring:
kafka:
properties:
"[prop.one]": "first"
admin:
properties:
"[prop.two]": "second"
consumer:
properties:
"[prop.three]": "third"
producer:
properties:
"[prop.four]": "fourth"
streams:
properties:
"[prop.five]": "fifth"
This sets the common prop.one
Kafka property to first
(applies to producers, consumers, admins, and streams), the prop.two
admin property to second
, the prop.three
consumer property to third
, the prop.four
producer property to fourth
and the prop.five
streams property to fifth
You can also configure the Spring Kafka JsonDeserializer
as follows:
Properties
YAML
spring.kafka.consumer.value-deserializer=org.springframework.kafka.support.serializer.JsonDeserializer
spring.kafka.consumer.properties[spring.json.value.default.type]=com.example.Invoice
spring.kafka.consumer.properties[spring.json.trusted.packages]=com.example.main,com.example.another
spring:
kafka:
consumer:
value-deserializer: "org.springframework.kafka.support.serializer.JsonDeserializer"
properties:
"[spring.json.value.default.type]": "com.example.Invoice"
"[spring.json.trusted.packages]": "com.example.main,com.example.another"
Similarly, you can disable the JsonSerializer
default behavior of sending type information in headers:
Properties
YAML
spring.kafka.producer.value-serializer=org.springframework.kafka.support.serializer.JsonSerializer
spring.kafka.producer.properties[spring.json.add.type.headers]=false
spring:
kafka:
producer:
value-serializer: "org.springframework.kafka.support.serializer.JsonSerializer"
properties:
"[spring.json.add.type.headers]": false
Properties set in this way override any configuration item that Spring Boot explicitly supports.
Testing with Embedded Kafka
Spring for Apache Kafka provides a convenient way to test projects with an embedded Apache Kafka broker.
To use this feature, annotate a test class with @EmbeddedKafka
from the spring-kafka-test
module.
For more information, please see the Spring for Apache Kafka reference manual.
To make Spring Boot auto-configuration work with the aforementioned embedded Apache Kafka broker, you need to remap a system property for embedded broker addresses (populated by the EmbeddedKafkaBroker
) into the Spring Boot configuration property for Apache Kafka.
There are several ways to do that:
Provide a system property to map embedded broker addresses into spring.kafka.bootstrap-servers
in the test class:
Java
Kotlin
static {
System.setProperty(EmbeddedKafkaBroker.BROKER_LIST_PROPERTY, "spring.kafka.bootstrap-servers");
init {
Configure a property name on the @EmbeddedKafka
annotation:
Java
Kotlin
import org.springframework.boot.test.context.SpringBootTest;
import org.springframework.kafka.test.context.EmbeddedKafka;
@SpringBootTest
@EmbeddedKafka(topics = "someTopic", bootstrapServersProperty = "spring.kafka.bootstrap-servers")
class MyTest {
@SpringBootTest
@EmbeddedKafka(topics = ["someTopic"], bootstrapServersProperty = "spring.kafka.bootstrap-servers")
class MyTest {
Use a placeholder in configuration properties:
Properties
YAML
spring.kafka.bootstrap-servers=${spring.embedded.kafka.brokers}
spring:
kafka:
bootstrap-servers: "${spring.embedded.kafka.brokers}"
