此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Boot 3.4.0! |
使用 CLI
安装 CLI 后,您可以通过键入spring
,然后在命令行中按 Enter 键。
如果您运行spring
如果不包含任何参数,则会显示 Help 屏幕,如下所示:
$ spring
usage: spring [--help] [--version]
<command> [<args>]
Available commands are:
init [options] [location]
Initialize a new project using Spring Initializr (start.spring.io)
encodepassword [options] <password to encode>
Encode a password for use with Spring Security
shell
Start a nested shell
Common options:
--debug Verbose mode
Print additional status information for the command you are running
See 'spring help <command>' for more information on a specific command.
您可以键入spring help
获取有关任何受支持命令的更多详细信息,如以下示例所示:
$ spring help init
spring init - Initialize a new project using Spring Initializr (start.spring.io)
usage: spring init [options] [location]
Option Description
-a, --artifact-id <String> Project coordinates; infer archive name (for
example 'test')
-b, --boot-version <String> Spring Boot version (for example '1.2.0.RELEASE')
--build <String> Build system to use (for example 'maven' or
'gradle') (default: maven)
-d, --dependencies <String> Comma-separated list of dependency identifiers to
include in the generated project
--description <String> Project description
-f, --force Force overwrite of existing files
--format <String> Format of the generated content (for example
'build' for a build file, 'project' for a
project archive) (default: project)
-g, --group-id <String> Project coordinates (for example 'org.test')
-j, --java-version <String> Language level (for example '1.8')
-l, --language <String> Programming language (for example 'java')
--list List the capabilities of the service. Use it to
discover the dependencies and the types that are
available
-n, --name <String> Project name; infer application name
-p, --packaging <String> Project packaging (for example 'jar')
--package-name <String> Package name
-t, --type <String> Project type. Not normally needed if you use --
build and/or --format. Check the capabilities of
the service (--list) for more details
--target <String> URL of the service to use (default: https://start.
spring.io)
-v, --version <String> Project version (for example '0.0.1-SNAPSHOT')
-x, --extract Extract the project archive. Inferred if a
location is specified without an extension
examples:
To list all the capabilities of the service:
$ spring init --list
To creates a default project:
$ spring init
To create a web my-app.zip:
$ spring init -d=web my-app.zip
To create a web/data-jpa gradle project unpacked:
$ spring init -d=web,jpa --build=gradle my-dir
这version
命令提供了一种快速方法来检查你正在使用的 Spring Boot 版本,如下所示:
$ spring version
Spring CLI v3.3.7-SNAPSHOT
初始化新项目
这init
命令允许您使用 start.spring.io 创建新项目,而无需离开 shell,如以下示例所示:
$ spring init --dependencies=web,data-jpa my-project
Using service at https://start.spring.io
Project extracted to '/Users/developer/example/my-project'
前面的示例创建了一个my-project
目录,其中包含一个基于 Maven 的项目,该项目使用spring-boot-starter-web
和spring-boot-starter-data-jpa
您可以使用--list
标志,如以下示例所示:
Capabilities of https://start.spring.io
Available dependencies:
actuator - Actuator: Production ready features to help you monitor and manage your application
web - Web: Support for full-stack web development, including Tomcat and spring-webmvc
websocket - Websocket: Support for WebSocket development
ws - WS: Support for Spring Web Services
Available project types:
gradle-build - Gradle Config [format:build, build:gradle]
gradle-project - Gradle Project [format:project, build:gradle]
maven-build - Maven POM [format:build, build:maven]
maven-project - Maven Project [format:project, build:maven] (default)
这init
命令支持许多选项。
请参阅help
output 了解更多详情。
例如,以下命令创建一个使用 Java 17 和war
包装:
$ spring init --build=gradle --java-version=17 --dependencies=websocket --packaging=war sample-app.zip
Content saved to 'sample-app.zip'
使用嵌入式 Shell
Spring Boot 包括 BASH 和 zsh shell 的命令行完成脚本。
如果您不使用这两个 shell 中的任何一个(也许您是 Windows 用户),则可以使用shell
命令启动集成的 shell,如以下示例所示:
$ spring shell
Spring Boot (v3.3.7-SNAPSHOT)
Hit TAB to complete. Type \'help' and hit RETURN for help, and \'exit' to quit.
在嵌入式 shell 内部,您可以直接运行其他命令:
$ version
嵌入式外壳支持 ANSI 颜色输出以及tab
完成。
如果需要运行本机命令,可以使用!
前缀。
要退出嵌入的 shell,请按ctrl-c
