此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Boot 3.4.0! |
条件评估报告 (conditions
这conditions
endpoint 提供有关 Configuration 和 Auto-Configuration 类的条件评估的信息。
检索报告
要检索报告,请创建一个GET
request 添加到/actuator/conditions
,如以下基于 curl 的示例所示:
$ curl 'http://localhost:8080/actuator/conditions' -i -X GET
生成的响应类似于以下内容:
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 3705
"contexts" : {
"application" : {
"positiveMatches" : {
"EndpointAutoConfiguration#endpointOperationParameterMapper" : [ {
"condition" : "OnBeanCondition",
"message" : "@ConditionalOnMissingBean (types: org.springframework.boot.actuate.endpoint.invoke.ParameterValueMapper; SearchStrategy: all) did not find any beans"
"JacksonEndpointAutoConfiguration#endpointObjectMapper" : [ {
"condition" : "OnClassCondition",
"message" : "@ConditionalOnClass found required classes 'com.fasterxml.jackson.databind.ObjectMapper', 'org.springframework.http.converter.json.Jackson2ObjectMapperBuilder'"
"condition" : "OnPropertyCondition",
"message" : "@ConditionalOnProperty (management.endpoints.jackson.isolated-object-mapper) matched"
"EndpointAutoConfiguration#endpointCachingOperationInvokerAdvisor" : [ {
"message" : "@ConditionalOnMissingBean (types: org.springframework.boot.actuate.endpoint.invoker.cache.CachingOperationInvokerAdvisor; SearchStrategy: all) did not find any beans"
"negativeMatches" : {
"WebFluxEndpointManagementContextConfiguration" : {
"notMatched" : [ {
"condition" : "OnWebApplicationCondition",
"message" : "not a reactive web application"
"matched" : [ {
"message" : "@ConditionalOnClass found required classes 'org.springframework.web.reactive.DispatcherHandler', 'org.springframework.http.server.reactive.HttpHandler'"
"GsonHttpMessageConvertersConfiguration.GsonHttpMessageConverterConfiguration" : {
"notMatched" : [ {
"condition" : "GsonHttpMessageConvertersConfiguration.PreferGsonOrJacksonAndJsonbUnavailableCondition",
"message" : "AnyNestedCondition 0 matched 2 did not; NestedCondition on GsonHttpMessageConvertersConfiguration.PreferGsonOrJacksonAndJsonbUnavailableCondition.JacksonJsonbUnavailable NoneNestedConditions 1 matched 1 did not; NestedCondition on GsonHttpMessageConvertersConfiguration.JacksonAndJsonbUnavailableCondition.JsonbPreferred @ConditionalOnProperty (spring.mvc.converters.preferred-json-mapper=jsonb) did not find property 'spring.mvc.converters.preferred-json-mapper'; NestedCondition on GsonHttpMessageConvertersConfiguration.JacksonAndJsonbUnavailableCondition.JacksonAvailable @ConditionalOnBean (types: org.springframework.http.converter.json.MappingJackson2HttpMessageConverter; SearchStrategy: all) found bean 'mappingJackson2HttpMessageConverter'; NestedCondition on GsonHttpMessageConvertersConfiguration.PreferGsonOrJacksonAndJsonbUnavailableCondition.GsonPreferred @ConditionalOnProperty (spring.mvc.converters.preferred-json-mapper=gson) did not find property 'spring.mvc.converters.preferred-json-mapper'"
"matched" : [ ]
"WebMvcEndpointManagementContextConfiguration#managementHealthEndpointWebMvcHandlerMapping" : {
"notMatched" : [ {
"condition" : "OnManagementPortCondition",
"message" : "Management Port actual port type (SAME) did not match required type (DIFFERENT)"
"matched" : [ ]
"unconditionalClasses" : [ "org.springframework.boot.autoconfigure.context.PropertyPlaceholderAutoConfiguration", "org.springframework.boot.actuate.autoconfigure.endpoint.jackson.JacksonEndpointAutoConfiguration", "org.springframework.boot.actuate.autoconfigure.endpoint.EndpointAutoConfiguration" ]
响应结构
响应包含应用程序条件评估的详细信息。 下表描述了响应的结构:
路径 | 类型 | 描述 |
以 id 为键的应用程序上下文。 |
具有匹配条件的类和方法。 |
条件的名称。 |
条件匹配原因的详细信息。 |
条件不匹配的类和方法。 |
匹配的条件。 |
条件的名称。 |
条件不匹配原因的详细信息。 |
匹配的条件。 |
条件的名称。 |
条件匹配原因的详细信息。 |
无条件自动配置类的名称(如果有)。 |
父应用程序上下文的 ID(如果有)。 |
