此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Boot 3.4.0! |
Prometheus (prometheus
这prometheus
endpoint 以 Prometheus 服务器抓取所需的格式提供 Spring Boot 应用程序的指标。
检索所有指标
要检索所有指标,请创建一个GET
request 添加到/actuator/prometheus
,如以下基于 curl 的示例所示:
$ curl 'http://localhost:8080/actuator/prometheus' -i -X GET
生成的响应类似于以下内容:
HTTP/1.1 200 OK
Content-Type: text/plain;version=0.0.4;charset=utf-8
Content-Length: 3093
# HELP jvm_buffer_count_buffers An estimate of the number of buffers in the pool
# TYPE jvm_buffer_count_buffers gauge
jvm_buffer_count_buffers{id="direct"} 16.0
jvm_buffer_count_buffers{id="mapped"} 0.0
jvm_buffer_count_buffers{id="mapped - 'non-volatile memory'"} 0.0
# HELP jvm_buffer_memory_used_bytes An estimate of the memory that the Java virtual machine is using for this buffer pool
# TYPE jvm_buffer_memory_used_bytes gauge
jvm_buffer_memory_used_bytes{id="direct"} 1.7043464E7
jvm_buffer_memory_used_bytes{id="mapped"} 0.0
jvm_buffer_memory_used_bytes{id="mapped - 'non-volatile memory'"} 0.0
# HELP jvm_buffer_total_capacity_bytes An estimate of the total capacity of the buffers in this pool
# TYPE jvm_buffer_total_capacity_bytes gauge
jvm_buffer_total_capacity_bytes{id="direct"} 1.7043463E7
jvm_buffer_total_capacity_bytes{id="mapped"} 0.0
jvm_buffer_total_capacity_bytes{id="mapped - 'non-volatile memory'"} 0.0
# HELP jvm_memory_committed_bytes The amount of memory in bytes that is committed for the Java virtual machine to use
# TYPE jvm_memory_committed_bytes gauge
jvm_memory_committed_bytes{area="heap",id="G1 Eden Space"} 7.7594624E7
jvm_memory_committed_bytes{area="heap",id="G1 Old Gen"} 1.12197632E8
jvm_memory_committed_bytes{area="heap",id="G1 Survivor Space"} 4194304.0
jvm_memory_committed_bytes{area="nonheap",id="CodeHeap 'non-nmethods'"} 2555904.0
jvm_memory_committed_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 4194304.0
jvm_memory_committed_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 2.031616E7
jvm_memory_committed_bytes{area="nonheap",id="Compressed Class Space"} 1.2189696E7
jvm_memory_committed_bytes{area="nonheap",id="Metaspace"} 8.8997888E7
# HELP jvm_memory_max_bytes The maximum amount of memory in bytes that can be used for memory management
# TYPE jvm_memory_max_bytes gauge
jvm_memory_max_bytes{area="heap",id="G1 Eden Space"} -1.0
jvm_memory_max_bytes{area="heap",id="G1 Old Gen"} 1.073741824E9
jvm_memory_max_bytes{area="heap",id="G1 Survivor Space"} -1.0
jvm_memory_max_bytes{area="nonheap",id="CodeHeap 'non-nmethods'"} 5836800.0
jvm_memory_max_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 1.22912768E8
jvm_memory_max_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 1.22908672E8
jvm_memory_max_bytes{area="nonheap",id="Compressed Class Space"} 1.073741824E9
jvm_memory_max_bytes{area="nonheap",id="Metaspace"} -1.0
# HELP jvm_memory_used_bytes The amount of used memory
# TYPE jvm_memory_used_bytes gauge
jvm_memory_used_bytes{area="heap",id="G1 Eden Space"} 1.572864E7
jvm_memory_used_bytes{area="heap",id="G1 Old Gen"} 8.3054592E7
jvm_memory_used_bytes{area="heap",id="G1 Survivor Space"} 3229632.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-nmethods'"} 1445504.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 4171648.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 2.0260864E7
jvm_memory_used_bytes{area="nonheap",id="Compressed Class Space"} 1.182632E7
jvm_memory_used_bytes{area="nonheap",id="Metaspace"} 8.8213E7
默认响应内容类型为text/plain;version=0.0.4
端点还可以生成application/openmetrics-text;version=1.0.0
当使用适当的Accept
header,如以下基于 curl 的示例所示:
$ curl 'http://localhost:8080/actuator/prometheus' -i -X GET \
-H 'Accept: application/openmetrics-text; version=1.0.0; charset=utf-8'
生成的响应类似于以下内容:
HTTP/1.1 200 OK
Content-Type: application/openmetrics-text;version=1.0.0;charset=utf-8
Content-Length: 3101
jvm_memory_committed_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 2.0250624E7
jvm_memory_used_bytes{area="heap",id="G1 Eden Space"} 1.4680064E7
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-nmethods'"} 1485952.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 4129792.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 2.0219136E7
jvm_memory_used_bytes{area="nonheap",id="Compressed Class Space"} 1.18224E7
jvm_memory_used_bytes{area="nonheap",id="Metaspace"} 8.81782E7
# EOF
检索筛选的指标
要检索与特定名称匹配的指标,请创建一个GET
使用includedNames
query 参数,如以下基于 curl 的示例所示:
$ curl 'http://localhost:8080/actuator/prometheus?includedNames=jvm_memory_used_bytes%2Cjvm_memory_committed_bytes' -i -X GET
生成的响应类似于以下内容:
HTTP/1.1 200 OK
Content-Length: 1462
jvm_memory_committed_bytes{area="nonheap",id="Compressed Class Space"} 1.2255232E7
jvm_memory_committed_bytes{area="nonheap",id="Metaspace"} 8.9063424E7
jvm_memory_used_bytes{area="heap",id="G1 Eden Space"} 1.6777216E7
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 4175488.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 2.0288896E7
jvm_memory_used_bytes{area="nonheap",id="Compressed Class Space"} 1.1826968E7
jvm_memory_used_bytes{area="nonheap",id="Metaspace"} 8.8219024E7
