异步出站网关
上一节中讨论的网关是同步的,因为发送线程将暂停,直到 收到回复(或发生超时)。 Spring 集成版本 4.3 添加了一个异步网关,它使用AsyncRabbitTemplate来自 Spring AMQP。 发送消息时,线程在发送作完成后立即返回,收到消息时,将在模板的侦听器容器线程上发送回复。 当在 poller 线程上调用网关时,这可能很有用。 线程已释放,可用于框架中的其他任务。spring-doc.cadn.net.cn
以下清单显示了 AMQP 异步出站网关的可能配置选项:spring-doc.cadn.net.cn
public class AmqpAsyncApplication {
    public IntegrationFlow asyncAmqpOutbound(AsyncRabbitTemplate asyncRabbitTemplate) {
        return f -> f
                .handle(Amqp.asyncOutboundGateway(asyncRabbitTemplate)
                        .routingKey("queue1")); // default exchange - route to queue 'queue1'
    @MessagingGateway(defaultRequestChannel = "asyncAmqpOutbound.input")
    public interface MyGateway {
        String sendToRabbit(String data);
public class AmqpAsyncConfig {
    @ServiceActivator(inputChannel = "amqpOutboundChannel")
    public AsyncAmqpOutboundGateway amqpOutbound(AsyncRabbitTemplate asyncTemplate) {
        AsyncAmqpOutboundGateway outbound = new AsyncAmqpOutboundGateway(asyncTemplate);
        outbound.setRoutingKey("foo"); // default exchange - route to queue 'foo'
        return outbound;
    public AsyncRabbitTemplate asyncTemplate(RabbitTemplate rabbitTemplate,
                     SimpleMessageListenerContainer replyContainer) {
        return new AsyncRabbitTemplate(rabbitTemplate, replyContainer);
    public SimpleMessageListenerContainer replyContainer() {
        SimpleMessageListenerContainer container = new SimpleMessageListenerContainer(ccf);
        container.setQueueNames("asyncRQ1");
        return container;
    public MessageChannel amqpOutboundChannel() {
        return new DirectChannel();
<int-amqp:outbound-async-gateway id="asyncOutboundGateway"    (1)
                           request-channel="myRequestChannel" (2)
                           async-template=""                  (3)
                           exchange-name=""                   (4)
                           exchange-name-expression=""        (5)
                           order="1"                          (6)
                           reply-channel=""                   (7)
                           reply-timeout=""                   (8)
                           requires-reply=""                  (9)
                           routing-key=""                     (10)
                           routing-key-expression=""          (11)
                           default-delivery-mode""            (12)
                           confirm-correlation-expression=""  (13)
                           confirm-ack-channel=""             (14)
                           confirm-nack-channel=""            (15)
                           confirm-timeout=""                 (16)
                           return-channel=""                  (17)
                           lazy-connect="true" />             (18)
1 此适配器的唯一 ID。 自选。
2 消息通道,消息应发送到该通道,以便将它们转换并发布到 AMQP 交换。 必填。
3 Bean 引用配置的AsyncRabbitTemplate. 可选(默认为asyncRabbitTemplate).
4 应将消息发送到的 AMQP 交换的名称。 如果未提供,则消息将发送到默认的 no-name 交换。 与 'exchange-name-expression' 互斥。 自选。
5 一个 SPEL 表达式,用于确定消息发送到的 AMQP 交换的名称,并将消息作为根对象。 如果未提供,则消息将发送到默认的 no-name 交换。 与 'exchange-name' 互斥。 自选。
6 注册多个使用者时此使用者的顺序,从而启用负载均衡和故障转移。 可选(默认为Ordered.LOWEST_PRECEDENCE [=Integer.MAX_VALUE]).
7 从 AMQP 队列接收回复并进行转换后,应将回复发送到的消息通道。 自选。
8 网关在将回复消息发送到reply-channel. 这仅适用于reply-channelcan 阻止 — 例如QueueChannel容量限制当前已满。 默认值为 infinity。
9 AsyncRabbitTemplate’s `receiveTimeout属性,并且该设置为true,网关会向入站消息的errorChannel页眉。 当AsyncRabbitTemplate’s `receiveTimeout属性,并且该设置为false,网关会向默认的errorChannel(如果可用)。 它默认为true.
10 发送 Messages 时使用的 routing-key。 默认情况下,这是一个空的String. 与 'routing-key-expression' 互斥。 自选。
11 一个 SPEL 表达式,用于确定发送消息时要使用的路由密钥。 将消息作为根对象(例如,'payload.key')。 默认情况下,这是一个空的String. 与 'routing-key' 互斥。 自选。
12 消息的默认传递模式:PERSISTENTNON_PERSISTENT. 如果header-mapper设置传递模式。 如果 Spring 集成消息头 (amqp_deliveryMode) 存在,则DefaultHeaderMapper设置值。 如果未提供此属性并且 Headers 映射器未设置它,则默认值取决于底层的 Spring AMQPMessagePropertiesConverterRabbitTemplate. 如果未自定义,则默认值为PERSISTENT. 自选。
13 定义相关数据的表达式。 如果提供,这会将底层 AMQP 模板配置为接收发布者确认。 需要专用的RabbitTemplate以及CachingConnectionFactory及其publisherConfirms属性设置为true. 收到发布者确认并提供关联数据后,确认将写入confirm-ack-channelconfirm-nack-channel,具体取决于确认类型。 确认的有效负载是此表达式定义的关联数据,并且消息的 'amqp_publishConfirm' 标头设置为true (ack) 或false (nack). 为nack实例、附加标头 (amqp_publishConfirmNackCause) 提供。 例子:headers['myCorrelationData'],payload. 如果表达式解析为Message<?>实例(例如 “#this”)上,则在ack/nackchannel 基于该消息,并添加了其他标头。 另请参阅发布者确认和返回的替代机制。 自选。
14 正 (ack) 发布者确认。 有效负载是由confirm-correlation-expression. 需要底层AsyncRabbitTemplate使其enableConfirms属性设置为true. 另请参阅发布者确认和返回的替代机制。 可选(默认值为nullChannel).
15 从 4.2 版本开始。 负数 (nack) 发布者确认。 有效负载是由confirm-correlation-expression. 需要底层AsyncRabbitTemplate使其enableConfirms属性设置为true. 另请参阅发布者确认和返回的替代机制。 可选(默认值为nullChannel).
16 设置后,如果在此时间(以毫秒为单位)内未收到发布者确认,网关将合成否定确认 (nack)。 待处理确认每检查一次此值的 50%,因此发送 nack 的实际时间将介于此值的 1 倍到 1.5 倍之间。 另请参阅发布者确认和返回的替代机制。 默认无(不会生成 nack)。
17 返回的消息发送到的通道。 如果提供,则底层 AMQP 模板配置为将无法送达的消息返回到网关。 该消息是根据从 AMQP 接收的数据构建的,并带有以下附加标头:amqp_returnReplyCode,amqp_returnReplyText,amqp_returnExchangeamqp_returnRoutingKey. 需要底层AsyncRabbitTemplate使其mandatory属性设置为true. 另请参阅发布者确认和返回的替代机制。 自选。
18 当设置为false时,终端节点会尝试在应用程序上下文初始化期间连接到代理。 这样做可以在代理宕机时记录错误消息,从而“快速失败”检测错误配置。 什么时候true(默认值),则连接已建立(如果由于已建立其他组件而尚不存在 it) 的 API 请求。
有关更多信息,另请参阅 Asynchronous Service Activatorspring-doc.cadn.net.cn
RabbitTemplate (兔模板)
当您使用 Confirmation 和 Returns 时,我们建议RabbitTemplate连接到AsyncRabbitTemplate要敬业。 否则,可能会遇到意想不到的副作用。spring-doc.cadn.net.cn
