For the latest stable version, please use Spring Framework 6.2.4! |
Web MVC Config
Applications can declare the infrastructure beans listed in Special Bean Types
that are required to process requests. The DispatcherServlet
checks the
WebApplicationContext
for each special bean. If there are no matching bean types,
it falls back on the default types listed in
DispatcherServlet.properties
In most cases, the MVC Config is the best starting point. It declares the required beans in either Java or XML and provides a higher-level configuration callback API to customize it.
Spring Boot relies on the MVC Java configuration to configure Spring MVC and provides many extra convenient options. |
