For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Meta-Annotation Support for Testing
You can use most test-related annotations as meta-annotations to create custom composed annotations and reduce configuration duplication across a test suite.spring-doc.cn
You can use each of the following as a meta-annotation in conjunction with the TestContext framework.spring-doc.cn
Consider the following example:spring-doc.cn
@RunWith(SpringRunner.class)
@ContextConfiguration({"/app-config.xml", "/test-data-access-config.xml"})
@ActiveProfiles("dev")
@Transactional
public class OrderRepositoryTests { }
@Transactional
public class UserRepositoryTests { }
@RunWith(SpringRunner::class)
@ContextConfiguration("/app-config.xml", "/test-data-access-config.xml")
@Transactional
@Transactional
If we discover that we are repeating the preceding configuration across our JUnit 4-based test suite, we can reduce the duplication by introducing a custom composed annotation that centralizes the common test configuration for Spring, as follows:spring-doc.cn
@Target(ElementType.TYPE)
@Transactional
public @interface TransactionalDevTestConfig { }
@Target(AnnotationTarget.TYPE)
@Retention(AnnotationRetention.RUNTIME)
@Transactional
annotation class TransactionalDevTestConfig { }
Then we can use our custom @TransactionalDevTestConfig annotation to simplify the configuration of individual JUnit 4 based test classes, as follows:spring-doc.cn
If we write tests that use JUnit Jupiter, we can reduce code duplication even further, since annotations in JUnit 5 can also be used as meta-annotations. Consider the following example:spring-doc.cn
@ExtendWith(SpringExtension.class)
@Transactional
@Transactional
@ExtendWith(SpringExtension::class)
@Transactional
@Transactional
If we discover that we are repeating the preceding configuration across our JUnit Jupiter-based test suite, we can reduce the duplication by introducing a custom composed annotation that centralizes the common test configuration for Spring and JUnit Jupiter, as follows:spring-doc.cn
@Transactional
@Transactional
Then we can use our custom @TransactionalDevTestConfig annotation to simplify the configuration of individual JUnit Jupiter based test classes, as follows:spring-doc.cn
Since JUnit Jupiter supports the use of @Test, @RepeatedTest, ParameterizedTest, and others as meta-annotations, you can also create custom composed annotations at the test method level. For example, if we wish to create a composed annotation that combines the @Test and @Tag annotations from JUnit Jupiter with the @Transactional annotation from Spring, we could create an @TransactionalIntegrationTest annotation, as follows:spring-doc.cn
@Target(ElementType.METHOD)
@Transactional
@Tag("integration-test") // org.junit.jupiter.api.Tag
@Test // org.junit.jupiter.api.Test
public @interface TransactionalIntegrationTest { }
@Transactional
annotation class TransactionalIntegrationTest { }
Then we can use our custom @TransactionalIntegrationTest annotation to simplify the configuration of individual JUnit Jupiter based test methods, as follows:spring-doc.cn
void saveOrder() { }
void deleteOrder() { }
fun saveOrder() { }
fun deleteOrder() { }
For further details, see the Spring Annotation Programming Model wiki page.spring-doc.cn
