For the latest stable version, please use Spring Framework 6.2.4! |
Authentication
Every STOMP over WebSocket messaging session begins with an HTTP request. That can be a request to upgrade to WebSockets (that is, a WebSocket handshake) or, in the case of SockJS fallbacks, a series of SockJS HTTP transport requests.
Many web applications already have authentication and authorization in place to secure HTTP requests. Typically, a user is authenticated through Spring Security by using some mechanism such as a login page, HTTP basic authentication, or another way. The security context for the authenticated user is saved in the HTTP session and is associated with subsequent requests in the same cookie-based session.
Therefore, for a WebSocket handshake or for SockJS HTTP transport requests,
typically, there is already an authenticated user accessible through
HttpServletRequest#getUserPrincipal()
. Spring automatically associates that user
with a WebSocket or SockJS session created for them and, subsequently, with all
STOMP messages transported over that session through a user header.
In short, a typical web application needs to do nothing
beyond what it already does for security. The user is authenticated at
the HTTP request level with a security context that is maintained through a cookie-based
HTTP session (which is then associated with WebSocket or SockJS sessions created
for that user) and results in a user header being stamped on every Message
flowing
through the application.
The STOMP protocol does have login
and passcode
headers on the CONNECT
frame.
Those were originally designed for and are needed for STOMP over TCP. However, for STOMP
over WebSocket, by default, Spring ignores authentication headers at the STOMP protocol
level, and assumes that the user is already authenticated at the HTTP transport level.
The expectation is that the WebSocket or SockJS session contain the authenticated user.
