For the latest stable version, please use Spring Framework 6.2.4! |
Coroutines
Kotlin Coroutines are Kotlin
lightweight threads allowing to write non-blocking code in an imperative way. On language side,
suspending functions provides an abstraction for asynchronous operations while on library side
kotlinx.coroutines provides functions like
async { }
and types like Flow
Spring Framework provides support for Coroutines on the following scope:
Deferred and Flow return values support in Spring MVC and WebFlux annotated
@Controller
Suspending function support in Spring MVC and WebFlux annotated
@Controller
WebFlux.fn coRouter { } DSL
WebFlux
CoWebFilter
Suspending function and
Flow
support in RSocket@MessageMapping
annotated methods -
Extensions for
RSocketRequester
Spring AOP
Dependencies
Coroutines support is enabled when kotlinx-coroutines-core
and kotlinx-coroutines-reactor
dependencies are in the classpath:
build.gradle.kts
dependencies {
implementation("org.jetbrains.kotlinx:kotlinx-coroutines-core:${coroutinesVersion}")
implementation("org.jetbrains.kotlinx:kotlinx-coroutines-reactor:${coroutinesVersion}")
Version 1.4.0
and above are supported.
How Reactive translates to Coroutines?
For return values, the translation from Reactive to Coroutines APIs is the following:
fun handler(): Mono<Void>
becomessuspend fun handler()
fun handler(): Mono<T>
becomessuspend fun handler(): T
orsuspend fun handler(): T?
depending on if theMono
can be empty or not (with the advantage of being more statically typed) -
fun handler(): Flux<T>
becomesfun handler(): Flow<T>
For input parameters:
If laziness is not needed,
fun handler(mono: Mono<T>)
becomesfun handler(value: T)
since a suspending functions can be invoked to get the value parameter. -
If laziness is needed,
becomesfun handler(supplier: suspend () → T)
orfun handler(supplier: suspend () → T?)
Flow
is Flux
equivalent in Coroutines world, suitable for hot or cold stream, finite or infinite streams, with the following main differences:
Flow
is push-based whileFlux
is push-pull hybrid -
Backpressure is implemented via suspending functions
Flow
has only a single suspendingcollect
method and operators are implemented as extensions -
Operators are easy to implement thanks to Coroutines
Extensions allow to add custom operators to
Flow
Collect operations are suspending functions
map
operator supports asynchronous operation (no need forflatMap
) since it takes a suspending function parameter
Read this blog post about Going Reactive with Spring, Coroutines and Kotlin Flow for more details, including how to run code concurrently with Coroutines.
Controllers
Here is an example of a Coroutines @RestController
@RestController
class CoroutinesRestController(client: WebClient, banner: Banner) {
@GetMapping("/suspend")
suspend fun suspendingEndpoint(): Banner {
delay(10)
return banner
@GetMapping("/flow")
fun flowEndpoint() = flow {
delay(10)
emit(banner)
delay(10)
emit(banner)
@GetMapping("/deferred")
fun deferredEndpoint() = GlobalScope.async {
delay(10)
banner
@GetMapping("/sequential")
suspend fun sequential(): List<Banner> {
val banner1 = client
.get()
.uri("/suspend")
.accept(MediaType.APPLICATION_JSON)
.awaitExchange()
.awaitBody<Banner>()
val banner2 = client
.get()
.uri("/suspend")
.awaitExchange()
return listOf(banner1, banner2)
@GetMapping("/parallel")
suspend fun parallel(): List<Banner> = coroutineScope {
val deferredBanner1: Deferred<Banner> = async {
client
.get()
.uri("/suspend")
.awaitExchange()
val deferredBanner2: Deferred<Banner> = async {
client
.get()
.uri("/suspend")
.awaitExchange()
listOf(deferredBanner1.await(), deferredBanner2.await())
@GetMapping("/error")
suspend fun error() {
throw IllegalStateException()
@GetMapping("/cancel")
suspend fun cancel() {
throw CancellationException()
View rendering with a @Controller
is also supported.
@Controller
class CoroutinesViewController(banner: Banner) {
@GetMapping("/")
suspend fun render(model: Model): String {
delay(10)
model["banner"] = banner
return "index"
WebFlux.fn
Here is an example of Coroutines router defined via the coRouter { } DSL and related handlers.
class RouterConfiguration {
fun mainRouter(userHandler: UserHandler) = coRouter {
GET("/", userHandler::listView)
GET("/api/user", userHandler::listApi)
class UserHandler(builder: WebClient.Builder) {
private val client = builder.baseUrl("...").build()
suspend fun listView(request: ServerRequest): ServerResponse =
ServerResponse.ok().renderAndAwait("users", mapOf("users" to
client.get().uri("...").awaitExchange().awaitBody<User>()))
suspend fun listApi(request: ServerRequest): ServerResponse =
ServerResponse.ok().contentType(MediaType.APPLICATION_JSON).bodyAndAwait(
Transactions
Transactions on Coroutines are supported via the programmatic variant of the Reactive transaction management provided as of Spring Framework 5.2.
For suspending functions, a TransactionalOperator.executeAndAwait
extension is provided.
import org.springframework.transaction.reactive.executeAndAwait
class PersonRepository(private val operator: TransactionalOperator) {
suspend fun initDatabase() = operator.executeAndAwait {
insertPerson1()
insertPerson2()
private suspend fun insertPerson1() {
// INSERT SQL statement
private suspend fun insertPerson2() {
For Kotlin Flow
, a Flow<T>.transactional
import org.springframework.transaction.reactive.transactional
fun updatePeople() = findPeople().map(::updatePerson).transactional(operator)
private fun findPeople(): Flow<Person> {
// SELECT SQL statement
private suspend fun updatePerson(person: Person): Person {
// UPDATE SQL statement
