For the latest stable version, please use Spring Framework 6.2.4! |
Testing
To test code that uses the WebClient
, you can use a mock web server, such as the
OkHttp MockWebServer. To see an example
of its use, check out
WebClientIntegrationTests
in the Spring Framework test suite or the
static-server
sample in the OkHttp repository.
