For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Kotlin
Kotlin is a statically typed language that targets the JVM (and other platforms) which allows writing concise and elegant code while providing very good interoperability with existing libraries written in Java.spring-doc.cn
The Spring Framework provides first-class support for Kotlin and lets developers write Kotlin applications almost as if the Spring Framework was a native Kotlin framework. Most of the code samples of the reference documentation are provided in Kotlin in addition to Java.spring-doc.cn
The easiest way to build a Spring application with Kotlin is to leverage Spring Boot and its dedicated Kotlin support. This comprehensive tutorial will teach you how to build Spring Boot applications with Kotlin using start.spring.io.spring-doc.cn
Feel free to join the #spring channel of Kotlin Slack or ask a question with spring and kotlin as tags on Stackoverflow if you need support.spring-doc.cn
