For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Reactive Core
The spring-web module contains the following foundational support for reactive web applications:spring-doc.cn
  • For server request processing there are two levels of support.spring-doc.cn
    • HttpHandler: Basic contract for HTTP request handling with non-blocking I/O and Reactive Streams back pressure, along with adapters for Reactor Netty, Undertow, Tomcat, Jetty, and any Servlet container.spring-doc.cn
    • WebHandler API: Slightly higher level, general-purpose web API for request handling, on top of which concrete programming models such as annotated controllers and functional endpoints are built.spring-doc.cn
  • For the client side, there is a basic ClientHttpConnector contract to perform HTTP requests with non-blocking I/O and Reactive Streams back pressure, along with adapters for Reactor Netty, reactive Jetty HttpClient and Apache HttpComponents. The higher level WebClient used in applications builds on this basic contract.spring-doc.cn
  • For client and server, codecs for serialization and deserialization of HTTP request and response content.spring-doc.cn
HttpHandler
HttpHandler is a simple contract with a single method to handle a request and a response. It is intentionally minimal, and its main and only purpose is to be a minimal abstraction over different HTTP server APIs.spring-doc.cn
The following table describes the supported server APIs:spring-doc.cn
Server name Server API used Reactive Streams support
Nettyspring-doc.cn
Netty APIspring-doc.cn
Reactor Nettyspring-doc.cn
Undertowspring-doc.cn
Undertow APIspring-doc.cn
spring-web: Undertow to Reactive Streams bridgespring-doc.cn
Tomcatspring-doc.cn
Servlet non-blocking I/O; Tomcat API to read and write ByteBuffers vs byte[]spring-doc.cn
spring-web: Servlet non-blocking I/O to Reactive Streams bridgespring-doc.cn
Jettyspring-doc.cn
Servlet non-blocking I/O; Jetty API to write ByteBuffers vs byte[]spring-doc.cn
Servlet containerspring-doc.cn
Servlet non-blocking I/Ospring-doc.cn
The following table describes server dependencies (also see supported versions):spring-doc.cn
Server name Group id Artifact name
io.projectreactor.nettyspring-doc.cn
reactor-nettyspring-doc.cn
io.undertowspring-doc.cn
undertow-corespring-doc.cn
Tomcatspring-doc.cn
org.apache.tomcat.embedspring-doc.cn
tomcat-embed-corespring-doc.cn
Jettyspring-doc.cn
org.eclipse.jettyspring-doc.cn
jetty-server, jetty-servletspring-doc.cn
The code snippets below show using the HttpHandler adapters with each server API:spring-doc.cn
HttpHandler handler = ...
ReactorHttpHandlerAdapter adapter = new ReactorHttpHandlerAdapter(handler);
HttpServer.create().host(host).port(port).handle(adapter).bindNow();
val handler: HttpHandler = ...
val adapter = ReactorHttpHandlerAdapter(handler)
UndertowHttpHandlerAdapter adapter = new UndertowHttpHandlerAdapter(handler);
Undertow server = Undertow.builder().addHttpListener(port, host).setHandler(adapter).build();
server.start();
val adapter = UndertowHttpHandlerAdapter(handler)
val server = Undertow.builder().addHttpListener(port, host).setHandler(adapter).build()
server.start()
Servlet servlet = new TomcatHttpHandlerAdapter(handler);
Tomcat server = new Tomcat();
File base = new File(System.getProperty("java.io.tmpdir"));
Context rootContext = server.addContext("", base.getAbsolutePath());
Tomcat.addServlet(rootContext, "main", servlet);
rootContext.addServletMappingDecoded("/", "main");
server.setHost(host);
server.setPort(port);
server.start();
val servlet = TomcatHttpHandlerAdapter(handler)
val server = Tomcat()
val base = File(System.getProperty("java.io.tmpdir"))
val rootContext = server.addContext("", base.absolutePath)
server.host = host
server.start()
Servlet servlet = new JettyHttpHandlerAdapter(handler);
Server server = new Server();
ServletContextHandler contextHandler = new ServletContextHandler(server, "");
contextHandler.addServlet(new ServletHolder(servlet), "/");
contextHandler.start();
ServerConnector connector = new ServerConnector(server);
connector.setHost(host);
connector.setPort(port);
server.addConnector(connector);
server.start();
val servlet = JettyHttpHandlerAdapter(handler)
val server = Server()
val contextHandler = ServletContextHandler(server, "")
contextHandler.addServlet(ServletHolder(servlet), "/")
val connector = ServerConnector(server)
connector.host = host
connector.port = port
server.start()
Servlet Containerspring-doc.cn
To deploy as a WAR to any Servlet container, you can extend and include AbstractReactiveWebInitializer in the WAR. That class wraps an HttpHandler with ServletHttpHandlerAdapter and registers that as a Servlet.spring-doc.cn
WebHandler API
The org.springframework.web.server package builds on the HttpHandler contract to provide a general-purpose web API for processing requests through a chain of multiple WebExceptionHandler, multiple WebFilter, and a single WebHandler component. The chain can be put together with WebHttpHandlerBuilder by simply pointing to a Spring ApplicationContext where components are auto-detected, and/or by registering components with the builder.spring-doc.cn
While HttpHandler has a simple goal to abstract the use of different HTTP servers, the WebHandler API aims to provide a broader set of features commonly used in web applications such as:spring-doc.cn
Special bean types
The table below lists the components that WebHttpHandlerBuilder can auto-detect in a Spring ApplicationContext, or that can be registered directly with it:spring-doc.cn
Bean name Bean type Count Description
<any>spring-doc.cn
WebExceptionHandlerspring-doc.cn
0..Nspring-doc.cn
Provide handling for exceptions from the chain of WebFilter instances and the target WebHandler. For more details, see Exceptions.spring-doc.cn
<any>spring-doc.cn
WebFilterspring-doc.cn
0..Nspring-doc.cn
Apply interception style logic to before and after the rest of the filter chain and the target WebHandler. For more details, see Filters.spring-doc.cn
webHandlerspring-doc.cn
WebHandlerspring-doc.cn
1spring-doc.cn
The handler for the request.spring-doc.cn
webSessionManagerspring-doc.cn
WebSessionManagerspring-doc.cn
0..1spring-doc.cn
The manager for WebSession instances exposed through a method on ServerWebExchange. DefaultWebSessionManager by default.spring-doc.cn
serverCodecConfigurerspring-doc.cn
ServerCodecConfigurerspring-doc.cn
0..1spring-doc.cn
For access to HttpMessageReader instances for parsing form data and multipart data that is then exposed through methods on ServerWebExchange. ServerCodecConfigurer.create() by default.spring-doc.cn
localeContextResolverspring-doc.cn
LocaleContextResolverspring-doc.cn
0..1spring-doc.cn
The resolver for LocaleContext exposed through a method on ServerWebExchange. AcceptHeaderLocaleContextResolver by default.spring-doc.cn
forwardedHeaderTransformerspring-doc.cn
ForwardedHeaderTransformerspring-doc.cn
0..1spring-doc.cn
For processing forwarded type headers, either by extracting and removing them or by removing them only. Not used by default.spring-doc.cn
Form Data
ServerWebExchange exposes the following method for accessing form data:spring-doc.cn
Mono<MultiValueMap<String, String>> getFormData();
suspend fun getFormData(): MultiValueMap<String, String>
The DefaultServerWebExchange uses the configured HttpMessageReader to parse form data (application/x-www-form-urlencoded) into a MultiValueMap. By default, FormHttpMessageReader is configured for use by the ServerCodecConfigurer bean (see the Web Handler API).spring-doc.cn
Multipart Data
ServerWebExchange exposes the following method for accessing multipart data:spring-doc.cn
Mono<MultiValueMap<String, Part>> getMultipartData();
suspend fun getMultipartData(): MultiValueMap<String, Part>
The DefaultServerWebExchange uses the configured HttpMessageReader<MultiValueMap<String, Part>> to parse multipart/form-data, multipart/mixed, and multipart/related content into a MultiValueMap. By default, this is the DefaultPartHttpMessageReader, which does not have any third-party dependencies. Alternatively, the SynchronossPartHttpMessageReader can be used, which is based on the Synchronoss NIO Multipart library. Both are configured through the ServerCodecConfigurer bean (see the Web Handler API).spring-doc.cn
To parse multipart data in streaming fashion, you can use the Flux<PartEvent> returned from the PartEventHttpMessageReader instead of using @RequestPart, as that implies Map-like access to individual parts by name and, hence, requires parsing multipart data in full. By contrast, you can use @RequestBody to decode the content to Flux<PartEvent> without collecting to a MultiValueMap.spring-doc.cn
Forwarded Headers
As a request goes through proxies such as load balancers the host, port, and scheme may change, and that makes it a challenge to create links that point to the correct host, port, and scheme from a client perspective.spring-doc.cn
RFC 7239 defines the Forwarded HTTP header that proxies can use to provide information about the original request.spring-doc.cn
Non-standard Headers
There are other non-standard headers, too, including X-Forwarded-Host, X-Forwarded-Port, X-Forwarded-Proto, X-Forwarded-Ssl, and X-Forwarded-Prefix.spring-doc.cn
X-Forwarded-Host
While not standard, X-Forwarded-Host: <host> is a de-facto standard header that is used to communicate the original host to a downstream server. For example, if a request of example.com/resource is sent to a proxy which forwards the request to localhost:8080/resource, then a header of X-Forwarded-Host: example.com can be sent to inform the server that the original host was example.com.spring-doc.cn
X-Forwarded-Port
While not standard, X-Forwarded-Port: <port> is a de-facto standard header that is used to communicate the original port to a downstream server. For example, if a request of example.com/resource is sent to a proxy which forwards the request to localhost:8080/resource, then a header of X-Forwarded-Port: 443 can be sent to inform the server that the original port was 443.spring-doc.cn
X-Forwarded-Proto
While not standard, X-Forwarded-Proto: (https|http) is a de-facto standard header that is used to communicate the original protocol (e.g. https / https) to a downstream server. For example, if a request of example.com/resource is sent to a proxy which forwards the request to localhost:8080/resource, then a header of X-Forwarded-Proto: https can be sent to inform the server that the original protocol was https.spring-doc.cn
X-Forwarded-Ssl
While not standard, X-Forwarded-Ssl: (on|off) is a de-facto standard header that is used to communicate the original protocol (e.g. https / https) to a downstream server. For example, if a request of example.com/resource is sent to a proxy which forwards the request to localhost:8080/resource, then a header of X-Forwarded-Ssl: on to inform the server that the original protocol was https.spring-doc.cn
X-Forwarded-Prefix
While not standard, X-Forwarded-Prefix: <prefix> is a de-facto standard header that is used to communicate the original URL path prefix to a downstream server.spring-doc.cn
Use of X-Forwarded-Prefix can vary by deployment scenario, and needs to be flexible to allow replacing, removing, or prepending the path prefix of the target server.spring-doc.cn
Scenario 1: Override path prefixspring-doc.cn
https://example.com/api/{path} -> http://localhost:8080/app1/{path}
The prefix is the start of the path before the capture group {path}. For the proxy, the prefix is /api while for the server the prefix is /app1. In this case, the proxy can send X-Forwarded-Prefix: /api to have the original prefix /api override the server prefix /app1.spring-doc.cn
Scenario 2: Remove path prefixspring-doc.cn
At times, an application may want to have the prefix removed. For example, consider the following proxy to server mapping:spring-doc.cn
https://app1.example.com/{path} -> http://localhost:8080/app1/{path}
https://app2.example.com/{path} -> http://localhost:8080/app2/{path}
The proxy has no prefix, while applications app1 and app2 have path prefixes /app1 and /app2 respectively. The proxy can send X-Forwarded-Prefix: to have the empty prefix override server prefixes /app1 and /app2.spring-doc.cn
A common case for this deployment scenario is where licenses are paid per production application server, and it is preferable to deploy multiple applications per server to reduce fees. Another reason is to run more applications on the same server in order to share the resources required by the server to run.spring-doc.cn
In these scenarios, applications need a non-empty context root because there are multiple applications on the same server. However, this should not be visible in URL paths of the public API where applications may use different subdomains that provides benefits such as:spring-doc.cn
  • Added security, e.g. same origin policyspring-doc.cn
  • Independent scaling of applications (different domain points to different IP address)spring-doc.cn
Scenario 3: Insert path prefixspring-doc.cn
In other cases, it may be necessary to prepend a prefix. For example, consider the following proxy to server mapping:spring-doc.cn
https://example.com/api/app1/{path} -> http://localhost:8080/app1/{path}
In this case, the proxy has a prefix of /api/app1 and the server has a prefix of /app1. The proxy can send X-Forwarded-Prefix: /api/app1 to have the original prefix /api/app1 override the server prefix /app1.spring-doc.cn
ForwardedHeaderTransformer is a component that modifies the host, port, and scheme of the request, based on forwarded headers, and then removes those headers. If you declare it as a bean with the name forwardedHeaderTransformer, it will be detected and used.spring-doc.cn
In 5.1 ForwardedHeaderFilter was deprecated and superseded by ForwardedHeaderTransformer so forwarded headers can be processed earlier, before the exchange is created. If the filter is configured anyway, it is taken out of the list of filters, and ForwardedHeaderTransformer is used instead.
Security Considerations
There are security considerations for forwarded headers since an application cannot know if the headers were added by a proxy, as intended, or by a malicious client. This is why a proxy at the boundary of trust should be configured to remove untrusted forwarded traffic coming from the outside. You can also configure the ForwardedHeaderTransformer with removeOnly=true, in which case it removes but does not use the headers.spring-doc.cn
Filters
In the WebHandler API, you can use a WebFilter to apply interception-style logic before and after the rest of the processing chain of filters and the target WebHandler. When using the WebFlux Config, registering a WebFilter is as simple as declaring it as a Spring bean and (optionally) expressing precedence by using @Order on the bean declaration or by implementing Ordered.spring-doc.cn
CORS
Spring WebFlux provides fine-grained support for CORS configuration through annotations on controllers. However, when you use it with Spring Security, we advise relying on the built-in CorsFilter, which must be ordered ahead of Spring Security’s chain of filters.spring-doc.cn
See the section on CORS and the CORS WebFilter for more details.spring-doc.cn
Exceptions
In the WebHandler API, you can use a WebExceptionHandler to handle exceptions from the chain of WebFilter instances and the target WebHandler. When using the WebFlux Config, registering a WebExceptionHandler is as simple as declaring it as a Spring bean and (optionally) expressing precedence by using @Order on the bean declaration or by implementing Ordered.spring-doc.cn
The following table describes the available WebExceptionHandler implementations:spring-doc.cn
Exception Handler Description
ResponseStatusExceptionHandlerspring-doc.cn
Provides handling for exceptions of type ResponseStatusException by setting the response to the HTTP status code of the exception.spring-doc.cn
WebFluxResponseStatusExceptionHandlerspring-doc.cn
Extension of ResponseStatusExceptionHandler that can also determine the HTTP status code of a @ResponseStatus annotation on any exception.spring-doc.cn
This handler is declared in the WebFlux Config.spring-doc.cn
Codecs
The spring-web and spring-core modules provide support for serializing and deserializing byte content to and from higher level objects through non-blocking I/O with Reactive Streams back pressure. The following describes this support:spring-doc.cn
The spring-core module provides byte[], ByteBuffer, DataBuffer, Resource, and String encoder and decoder implementations. The spring-web module provides Jackson JSON, Jackson Smile, JAXB2, Protocol Buffers and other encoders and decoders along with web-only HTTP message reader and writer implementations for form data, multipart content, server-sent events, and others.spring-doc.cn
ClientCodecConfigurer and ServerCodecConfigurer are typically used to configure and customize the codecs to use in an application. See the section on configuring HTTP message codecs.spring-doc.cn
Jackson JSON
JSON and binary JSON (Smile) are both supported when the Jackson library is present.spring-doc.cn
The Jackson2Decoder works as follows:spring-doc.cn
  • Jackson’s asynchronous, non-blocking parser is used to aggregate a stream of byte chunks into TokenBuffer's each representing a JSON object.spring-doc.cn
  • Each TokenBuffer is passed to Jackson’s ObjectMapper to create a higher level object.spring-doc.cn
  • When decoding to a single-value publisher (e.g. Mono), there is one TokenBuffer.spring-doc.cn
  • When decoding to a multi-value publisher (e.g. Flux), each TokenBuffer is passed to the ObjectMapper as soon as enough bytes are received for a fully formed object. The input content can be a JSON array, or any line-delimited JSON format such as NDJSON, JSON Lines, or JSON Text Sequences.spring-doc.cn
The Jackson2Encoder works as follows:spring-doc.cn
  • For a single value publisher (e.g. Mono), simply serialize it through the ObjectMapper.spring-doc.cn
  • For a multi-value publisher with application/json, by default collect the values with Flux#collectToList() and then serialize the resulting collection.spring-doc.cn
  • For a multi-value publisher with a streaming media type such as application/x-ndjson or application/stream+x-jackson-smile, encode, write, and flush each value individually using a line-delimited JSON format. Other streaming media types may be registered with the encoder.spring-doc.cn
  • For SSE the Jackson2Encoder is invoked per event and the output is flushed to ensure delivery without delay.spring-doc.cn
By default both Jackson2Encoder and Jackson2Decoder do not support elements of type String. Instead the default assumption is that a string or a sequence of strings represent serialized JSON content, to be rendered by the CharSequenceEncoder. If what you need is to render a JSON array from Flux<String>, use Flux#collectToList() and encode a Mono<List<String>>.spring-doc.cn
Form Data
FormHttpMessageReader and FormHttpMessageWriter support decoding and encoding application/x-www-form-urlencoded content.spring-doc.cn
On the server side where form content often needs to be accessed from multiple places, ServerWebExchange provides a dedicated getFormData() method that parses the content through FormHttpMessageReader and then caches the result for repeated access. See Form Data in the WebHandler API section.spring-doc.cn
Once getFormData() is used, the original raw content can no longer be read from the request body. For this reason, applications are expected to go through ServerWebExchange consistently for access to the cached form data versus reading from the raw request body.spring-doc.cn
Multipart
MultipartHttpMessageReader and MultipartHttpMessageWriter support decoding and encoding "multipart/form-data", "multipart/mixed", and "multipart/related" content. In turn MultipartHttpMessageReader delegates to another HttpMessageReader for the actual parsing to a Flux<Part> and then simply collects the parts into a MultiValueMap. By default, the DefaultPartHttpMessageReader is used, but this can be changed through the ServerCodecConfigurer. For more information about the DefaultPartHttpMessageReader, refer to the javadoc of DefaultPartHttpMessageReader.spring-doc.cn
On the server side where multipart form content may need to be accessed from multiple places, ServerWebExchange provides a dedicated getMultipartData() method that parses the content through MultipartHttpMessageReader and then caches the result for repeated access. See Multipart Data in the WebHandler API section.spring-doc.cn
Once getMultipartData() is used, the original raw content can no longer be read from the request body. For this reason applications have to consistently use getMultipartData() for repeated, map-like access to parts, or otherwise rely on the SynchronossPartHttpMessageReader for a one-time access to Flux<Part>.spring-doc.cn
Limits
Decoder and HttpMessageReader implementations that buffer some or all of the input stream can be configured with a limit on the maximum number of bytes to buffer in memory. In some cases buffering occurs because input is aggregated and represented as a single object — for example, a controller method with @RequestBody byte[], x-www-form-urlencoded data, and so on. Buffering can also occur with streaming, when splitting the input stream — for example, delimited text, a stream of JSON objects, and so on. For those streaming cases, the limit applies to the number of bytes associated with one object in the stream.spring-doc.cn
To configure buffer sizes, you can check if a given Decoder or HttpMessageReader exposes a maxInMemorySize property and if so the Javadoc will have details about default values. On the server side, ServerCodecConfigurer provides a single place from where to set all codecs, see HTTP message codecs. On the client side, the limit for all codecs can be changed in WebClient.Builder.spring-doc.cn
For Multipart parsing the maxInMemorySize property limits the size of non-file parts. For file parts, it determines the threshold at which the part is written to disk. For file parts written to disk, there is an additional maxDiskUsagePerPart property to limit the amount of disk space per part. There is also a maxParts property to limit the overall number of parts in a multipart request. To configure all three in WebFlux, you’ll need to supply a pre-configured instance of MultipartHttpMessageReader to ServerCodecConfigurer.spring-doc.cn
Streaming
When streaming to the HTTP response (for example, text/event-stream, application/x-ndjson), it is important to send data periodically, in order to reliably detect a disconnected client sooner rather than later. Such a send could be a comment-only, empty SSE event or any other "no-op" data that would effectively serve as a heartbeat.spring-doc.cn
DataBuffer
DataBuffer is the representation for a byte buffer in WebFlux. The Spring Core part of this reference has more on that in the section on Data Buffers and Codecs. The key point to understand is that on some servers like Netty, byte buffers are pooled and reference counted, and must be released when consumed to avoid memory leaks.spring-doc.cn
WebFlux applications generally do not need to be concerned with such issues, unless they consume or produce data buffers directly, as opposed to relying on codecs to convert to and from higher level objects, or unless they choose to create custom codecs. For such cases please review the information in Data Buffers and Codecs, especially the section on Using DataBuffer.spring-doc.cn
Logging
DEBUG level logging in Spring WebFlux is designed to be compact, minimal, and human-friendly. It focuses on high value bits of information that are useful over and over again vs others that are useful only when debugging a specific issue.spring-doc.cn
TRACE level logging generally follows the same principles as DEBUG (and for example also should not be a firehose) but can be used for debugging any issue. In addition, some log messages may show a different level of detail at TRACE vs DEBUG.spring-doc.cn
Good logging comes from the experience of using the logs. If you spot anything that does not meet the stated goals, please let us know.spring-doc.cn
Log Id
In WebFlux, a single request can be run over multiple threads and the thread ID is not useful for correlating log messages that belong to a specific request. This is why WebFlux log messages are prefixed with a request-specific ID by default.spring-doc.cn
On the server side, the log ID is stored in the ServerWebExchange attribute (LOG_ID_ATTRIBUTE), while a fully formatted prefix based on that ID is available from ServerWebExchange#getLogPrefix(). On the WebClient side, the log ID is stored in the ClientRequest attribute (LOG_ID_ATTRIBUTE) ,while a fully formatted prefix is available from ClientRequest#logPrefix().spring-doc.cn
Sensitive Data
DEBUG and TRACE logging can log sensitive information. This is why form parameters and headers are masked by default and you must explicitly enable their logging in full.spring-doc.cn
The following example shows how to do so for server-side requests:spring-doc.cn
@EnableWebFlux
class MyConfig implements WebFluxConfigurer {
	public void configureHttpMessageCodecs(ServerCodecConfigurer configurer) {
		configurer.defaultCodecs().enableLoggingRequestDetails(true);
@EnableWebFlux
class MyConfig : WebFluxConfigurer {
	override fun configureHttpMessageCodecs(configurer: ServerCodecConfigurer) {
The following example shows how to do so for client-side requests:spring-doc.cn
Consumer<ClientCodecConfigurer> consumer = configurer ->
WebClient webClient = WebClient.builder()
		.exchangeStrategies(strategies -> strategies.codecs(consumer))
val consumer: (ClientCodecConfigurer) -> Unit  = { configurer -> configurer.defaultCodecs().enableLoggingRequestDetails(true) }
val webClient = WebClient.builder()
		.exchangeStrategies({ strategies -> strategies.codecs(consumer) })
		.build()
Appenders
Logging libraries such as SLF4J and Log4J 2 provide asynchronous loggers that avoid blocking. While those have their own drawbacks such as potentially dropping messages that could not be queued for logging, they are the best available options currently for use in a reactive, non-blocking application.spring-doc.cn
Custom codecs
Applications can register custom codecs for supporting additional media types, or specific behaviors that are not supported by the default codecs.spring-doc.cn
Some configuration options expressed by developers are enforced on default codecs. Custom codecs might want to get a chance to align with those preferences, like enforcing buffering limits or logging sensitive data.spring-doc.cn
		.codecs(configurer -> {
				CustomDecoder decoder = new CustomDecoder();
                   configurer.customCodecs().registerWithDefaultConfig(decoder);
		.codecs({ configurer ->
				val decoder = CustomDecoder()
		.build()
