For the latest stable version, please use Spring Framework 6.2.4! |
Validation
By default, if Bean Validation is present
on the classpath (for example, Hibernate Validator), the LocalValidatorFactoryBean
is
registered as a global Validator for use with @Valid
and
@Validated
on controller method arguments.
In Java configuration, you can customize the global Validator
instance, as the
following example shows:
Java
Kotlin
@EnableWebMvc
public Validator getValidator() {
@EnableWebMvc
override fun getValidator(): Validator {
The following example shows how to achieve the same configuration in XML:
xmlns:mvc="http://www.springframework.org/schema/mvc"
xsi:schemaLocation="
https://www.springframework.org/schema/mvc/spring-mvc.xsd">
<mvc:annotation-driven validator="globalValidator"/>
</beans>
Note that you can also register Validator
implementations locally, as the following
example shows:
Java
Kotlin
@Controller
public class MyController {
@InitBinder
protected void initBinder(WebDataBinder binder) {
binder.addValidators(new FooValidator());
@Controller
@InitBinder
protected fun initBinder(binder: WebDataBinder) {
binder.addValidators(FooValidator())
If you need to have a LocalValidatorFactoryBean injected somewhere, create a bean and
mark it with @Primary in order to avoid conflict with the one declared in the MVC configuration.
