For the latest stable version, please use Spring Framework 6.2.4! |
Exporting Your Beans to JMX
The core class in Spring’s JMX framework is the MBeanExporter
. This class is
responsible for taking your Spring beans and registering them with a JMX MBeanServer
For example, consider the following class:
package org.springframework.jmx;
public class JmxTestBean implements IJmxTestBean {
private String name;
private int age;
private boolean isSuperman;
public int getAge() {
return age;
public void setAge(int age) {
this.age = age;
public void setName(String name) {
this.name = name;
public String getName() {
return name;
public int add(int x, int y) {
return x + y;
public void dontExposeMe() {
throw new RuntimeException();
To expose the properties and methods of this bean as attributes and operations of an
MBean, you can configure an instance of the MBeanExporter
class in your
configuration file and pass in the bean, as the following example shows:
<beans>
<!-- this bean must not be lazily initialized if the exporting is to happen -->
<bean id="exporter" class="org.springframework.jmx.export.MBeanExporter" lazy-init="false">
<property name="beans">
<map>
<entry key="bean:name=testBean1" value-ref="testBean"/>
</map>
</property>
</bean>
<bean id="testBean" class="org.springframework.jmx.JmxTestBean">
<property name="name" value="TEST"/>
<property name="age" value="100"/>
</bean>
</beans>
The pertinent bean definition from the preceding configuration snippet is the exporter
bean. The beans
property tells the MBeanExporter
exactly which of your beans must be
exported to the JMX MBeanServer
. In the default configuration, the key of each entry
in the beans
Map
is used as the ObjectName
for the bean referenced by the
corresponding entry value. You can change this behavior, as described in Controlling ObjectName
Instances for Your Beans.
With this configuration, the testBean
bean is exposed as an MBean under the
ObjectName
bean:name=testBean1
. By default, all public
properties of the bean
are exposed as attributes and all public
methods (except those inherited from the
Object
class) are exposed as operations.
MBeanExporter is a Lifecycle bean (see Startup and Shutdown Callbacks
). By default, MBeans are exported as late as possible during
the application lifecycle. You can configure the phase at which
the export happens or disable automatic registration by setting the autoStartup flag.
Creating an MBeanServer
The configuration shown in the preceding section assumes that the
application is running in an environment that has one (and only one) MBeanServer
already running. In this case, Spring tries to locate the running MBeanServer
and
register your beans with that server (if any). This behavior is useful when your
application runs inside a container (such as Tomcat or IBM WebSphere) that has its
own MBeanServer
However, this approach is of no use in a standalone environment or when running inside
a container that does not provide an MBeanServer
. To address this, you can create an
MBeanServer
instance declaratively by adding an instance of the
org.springframework.jmx.support.MBeanServerFactoryBean
class to your configuration.
You can also ensure that a specific MBeanServer
is used by setting the value of the
MBeanExporter
instance’s server
property to the MBeanServer
value returned by an
<beans>
<bean id="mbeanServer" class="org.springframework.jmx.support.MBeanServerFactoryBean"/>
this bean needs to be eagerly pre-instantiated in order for the exporting to occur;
this means that it must not be marked as lazily initialized
<bean id="exporter" class="org.springframework.jmx.export.MBeanExporter">
<map>
</map>
</property>
<property name="server" ref="mbeanServer"/>
</bean>
</bean>
</beans>
In the preceding example, an instance of MBeanServer
is created by the MBeanServerFactoryBean
and is
supplied to the MBeanExporter
through the server
property. When you supply your own
MBeanServer
instance, the MBeanExporter
does not try to locate a running
MBeanServer
and uses the supplied MBeanServer
instance. For this to work
correctly, you must have a JMX implementation on your classpath.
Reusing an Existing MBeanServer
If no server is specified, the MBeanExporter
tries to automatically detect a running
MBeanServer
. This works in most environments, where only one MBeanServer
instance is
used. However, when multiple instances exist, the exporter might pick the wrong server.
In such cases, you should use the MBeanServer
agentId
to indicate which instance to
be used, as the following example shows:
<beans>
<bean id="mbeanServer" class="org.springframework.jmx.support.MBeanServerFactoryBean">
<!-- indicate to first look for a server -->
<property name="locateExistingServerIfPossible" value="true"/>
<!-- search for the MBeanServer instance with the given agentId -->
<property name="agentId" value="MBeanServer_instance_agentId>"/>
</bean>
</bean>
</beans>
For platforms or cases where the existing MBeanServer
has a dynamic (or unknown)
agentId
that is retrieved through lookup methods, you should use
factory-method,
<beans>
<property name="server">
<!-- Custom MBeanServerLocator -->
<bean class="platform.package.MBeanServerLocator" factory-method="locateMBeanServer"/>
</property>
</bean>
<!-- other beans here -->
</beans>
Lazily Initialized MBeans
If you configure a bean with an MBeanExporter
that is also configured for lazy
initialization, the MBeanExporter
does not break this contract and avoids
instantiating the bean. Instead, it registers a proxy with the MBeanServer
and defers
obtaining the bean from the container until the first invocation on the proxy occurs.
This also affects FactoryBean
resolution where MBeanExporter
will regularly
introspect the produced object, effectively triggering FactoryBean.getObject()
In order to avoid this, mark the corresponding bean definition as lazy-init.
Automatic Registration of MBeans
Any beans that are exported through the MBeanExporter
and are already valid MBeans
are registered as-is with the MBeanServer
without further intervention from Spring.
You can cause MBeans to be automatically detected by the MBeanExporter
by setting
the autodetect
property to true
<property name="autodetect" value="true"/>
</bean>
<bean name="spring:mbean=true" class="org.springframework.jmx.export.TestDynamicMBean"/>
In the preceding example, the bean called spring:mbean=true
is already a valid JMX MBean
and is automatically registered by Spring. By default, a bean that is autodetected for JMX
registration has its bean name used as the ObjectName
. You can override this behavior,
as detailed in Controlling ObjectName
Controlling the Registration Behavior
Consider the scenario where a Spring MBeanExporter
attempts to register an MBean
with an MBeanServer
by using the ObjectName
bean:name=testBean1
. If an MBean
instance has already been registered under that same ObjectName
, the default behavior
is to fail (and throw an InstanceAlreadyExistsException
You can control exactly what happens when an MBean
is
registered with an MBeanServer
. Spring’s JMX support allows for three different
registration behaviors to control the registration behavior when the registration
process finds that an MBean
has already been registered under the same ObjectName
The following table summarizes these registration behaviors:
Registration behavior | Explanation |
This is the default registration behavior. If an |
If an |
If an |
The values in the preceding table are defined as enums on the RegistrationPolicy
class.
If you want to change the default registration behavior, you need to set the value of the
registrationPolicy
property on your MBeanExporter
definition to one of those
values.
The following example shows how to change from the default registration
behavior to the REPLACE_EXISTING
behavior:
<beans>
<map>
</map>
</property>
<property name="registrationPolicy" value="REPLACE_EXISTING"/>
</bean>
</bean>
</beans>
