For the latest stable version, please use Spring Framework 6.2.4! |
Literal Expressions
SpEL supports the following types of literal expressions.
- String
Strings can be delimited by single quotation marks (
) or double quotation marks ("
). To include a single quotation mark within a string literal enclosed in single quotation marks, use two adjacent single quotation mark characters. Similarly, to include a double quotation mark within a string literal enclosed in double quotation marks, use two adjacent double quotation mark characters. - Number
Numbers support the use of the negative sign, exponential notation, and decimal points.
Integer:
int
orlong
Hexadecimal:
int
orlong
Real:
float
ordouble
By default, real numbers are parsed using
Double.parseDouble()
- Boolean
true
orfalse
- Null
null
Due to the design and implementation of the Spring Expression Language, literal numbers are always stored internally as positive numbers. For example, This means that it is not possible to represent a negative literal number equal to the
minimum value of that type of number in Java. For example, the minimum supported value
for an If you need to use the minimum value for a particular type of number within a SpEL
expression, you can either reference the
The following listing shows simple usage of literals. Typically, they are not used in isolation like this but, rather, as part of a more complex expression — for example, using a literal on one side of a logical comparison operator or as an argument to a method.
Java
Kotlin
ExpressionParser parser = new SpelExpressionParser();
// evaluates to "Hello World"
String helloWorld = (String) parser.parseExpression("'Hello World'").getValue();
// evaluates to "Tony's Pizza"
String pizzaParlor = (String) parser.parseExpression("'Tony''s Pizza'").getValue();
double avogadrosNumber = (Double) parser.parseExpression("6.0221415E+23").getValue();
// evaluates to 2147483647
int maxValue = (Integer) parser.parseExpression("0x7FFFFFFF").getValue();
boolean trueValue = (Boolean) parser.parseExpression("true").getValue();
Object nullValue = parser.parseExpression("null").getValue();
val parser = SpelExpressionParser()
val helloWorld = parser.parseExpression("'Hello World'").value as String
val pizzaParlor = parser.parseExpression("'Tony''s Pizza'").value as String
val avogadrosNumber = parser.parseExpression("6.0221415E+23").value as Double
val maxValue = parser.parseExpression("0x7FFFFFFF").value as Int
val trueValue = parser.parseExpression("true").value as Boolean
val nullValue = parser.parseExpression("null").value
