For the latest stable version, please use Spring Framework 6.2.4! |
Customizing the Nature of a Bean
The Spring Framework provides a number of interfaces you can use to customize the nature of a bean. This section groups them as follows:
Lifecycle Callbacks
To interact with the container’s management of the bean lifecycle, you can implement
the Spring InitializingBean
and DisposableBean
interfaces. The container calls
afterPropertiesSet()
for the former and destroy()
for the latter to let the bean
perform certain actions upon initialization and destruction of your beans.
The JSR-250 If you do not want to use the JSR-250 annotations but you still want to remove
coupling, consider |
Internally, the Spring Framework uses BeanPostProcessor
implementations to process any
callback interfaces it can find and call the appropriate methods. If you need custom
features or other lifecycle behavior Spring does not by default offer, you can
implement a BeanPostProcessor
yourself. For more information, see
Container Extension Points.
In addition to the initialization and destruction callbacks, Spring-managed objects may
also implement the Lifecycle
interface so that those objects can participate in the
startup and shutdown process, as driven by the container’s own lifecycle.
The lifecycle callback interfaces are described in this section.
Initialization Callbacks
The org.springframework.beans.factory.InitializingBean
interface lets a bean
perform initialization work after the container has set all necessary properties on the
bean. The InitializingBean
interface specifies a single method:
void afterPropertiesSet() throws Exception;
We recommend that you do not use the InitializingBean
interface, because it
unnecessarily couples the code to Spring. Alternatively, we suggest using
the @PostConstruct
annotation or
specifying a POJO initialization method. In the case of XML-based configuration metadata,
you can use the init-method
attribute to specify the name of the method that has a void
no-argument signature. With Java configuration, you can use the initMethod
attribute of
. See Receiving Lifecycle Callbacks. Consider the following example:
<bean id="exampleInitBean" class="examples.ExampleBean" init-method="init"/>
Java
Kotlin
public class ExampleBean {
public void init() {
// do some initialization work
class ExampleBean {
fun init() {
The preceding example has almost exactly the same effect as the following example (which consists of two listings):
<bean id="exampleInitBean" class="examples.AnotherExampleBean"/>
Java
Kotlin
public class AnotherExampleBean implements InitializingBean {
public void afterPropertiesSet() {
class AnotherExampleBean : InitializingBean {
override fun afterPropertiesSet() {
However, the first of the two preceding examples does not couple the code to Spring.
Be aware that For a scenario where expensive post-initialization activity is to be triggered,
e.g. asynchronous database preparation steps, your bean should either implement
Alternatively, you may implement the |
Destruction Callbacks
Implementing the org.springframework.beans.factory.DisposableBean
interface lets a
bean get a callback when the container that contains it is destroyed. The
DisposableBean
void destroy() throws Exception;
We recommend that you do not use the DisposableBean
callback interface, because it
the @PreDestroy
annotation or
specifying a generic method that is supported by bean definitions. With XML-based
configuration metadata, you can use the destroy-method
attribute on the <bean/>
With Java configuration, you can use the destroyMethod
attribute of @Bean
. See
Receiving Lifecycle Callbacks. Consider the following definition:
<bean id="exampleDestructionBean" class="examples.ExampleBean" destroy-method="cleanup"/>
Java
Kotlin
public void cleanup() {
// do some destruction work (like releasing pooled connections)
class ExampleBean {
fun cleanup() {
The preceding definition has almost exactly the same effect as the following definition:
<bean id="exampleDestructionBean" class="examples.AnotherExampleBean"/>
Java
Kotlin
public class AnotherExampleBean implements DisposableBean {
public void destroy() {
class AnotherExampleBean : DisposableBean {
override fun destroy() {
However, the first of the two preceding definitions does not couple the code to Spring.
Note that Spring also supports inference of destroy methods, detecting a public close
or
shutdown
method. This is the default behavior for @Bean
methods in Java configuration
classes and automatically matches java.lang.AutoCloseable
or java.io.Closeable
implementations, not coupling the destruction logic to Spring either.
For destroy method inference with XML, you may assign the destroy-method attribute
of a <bean> element a special (inferred) value, which instructs Spring to automatically
detect a public close or shutdown method on the bean class for a specific bean definition.
You can also set this special (inferred) value on the default-destroy-method attribute
of a <beans> element to apply this behavior to an entire set of bean definitions (see
Default Initialization and Destroy Methods).
For extended shutdown phases, you may implement the |
When you write initialization and destroy method callbacks that do not use the
Spring-specific InitializingBean
and DisposableBean
callback interfaces, you
typically write methods with names such as init()
, initialize()
, dispose()
and so on. Ideally, the names of such lifecycle callback methods are standardized across
a project so that all developers use the same method names and ensure consistency.
You can configure the Spring container to “look” for named initialization and destroy
callback method names on every bean. This means that you, as an application developer,
can write your application classes and use an initialization callback called init()
without having to configure an init-method="init"
attribute with each bean definition.
The Spring IoC container calls that method when the bean is created (and in accordance
with the standard lifecycle callback contract described previously).
This feature also enforces a consistent naming convention for initialization and
destroy method callbacks.
Suppose that your initialization callback methods are named init()
and your destroy
callback methods are named destroy()
. Your class then resembles the class in the
following example:
Java
Kotlin
public class DefaultBlogService implements BlogService {
private BlogDao blogDao;
public void setBlogDao(BlogDao blogDao) {
this.blogDao = blogDao;
// this is (unsurprisingly) the initialization callback method
if (this.blogDao == null) {
throw new IllegalStateException("The [blogDao] property must be set.");
class DefaultBlogService : BlogService {
private var blogDao: BlogDao? = null
fun init() {
if (blogDao == null) {
throw IllegalStateException("The [blogDao] property must be set.")
You could then use that class in a bean resembling the following:
<beans default-init-method="init">
<bean id="blogService" class="com.something.DefaultBlogService">
<property name="blogDao" ref="blogDao" />
</bean>
</beans>
The presence of the default-init-method
attribute on the top-level <beans/>
element
attribute causes the Spring IoC container to recognize a method called init
on the bean
class as the initialization method callback. When a bean is created and assembled, if the
bean class has such a method, it is invoked at the appropriate time.
You can configure destroy method callbacks similarly (in XML, that is) by using the
element.
Where existing bean classes already have callback methods that are named at variance
with the convention, you can override the default by specifying (in XML, that is) the
method name by using the init-method
and destroy-method
attributes of the <bean/>
itself.
The Spring container guarantees that a configured initialization callback is called
immediately after a bean is supplied with all dependencies. Thus, the initialization
callback is called on the raw bean reference, which means that AOP interceptors and so
forth are not yet applied to the bean. A target bean is fully created first and
then an AOP proxy (for example) with its interceptor chain is applied. If the target
bean and the proxy are defined separately, your code can even interact with the raw
target bean, bypassing the proxy. Hence, it would be inconsistent to apply the
interceptors to the init
method, because doing so would couple the lifecycle of the
target bean to its proxy or interceptors and leave strange semantics when your code
interacts directly with the raw target bean.
Combining Lifecycle Mechanisms
As of Spring 2.5, you have three options for controlling bean lifecycle behavior:
The
InitializingBean
andDisposableBean
callback interfaces -
Custom
init()
anddestroy()
methods -
The
@PostConstruct
and@PreDestroy
annotations-
You can combine these mechanisms to control a given bean.
If multiple lifecycle mechanisms are configured for a bean and each mechanism is
configured with a different method name, then each configured method is run in the
order listed after this note. However, if the same method name is configured — for example,
init() for an initialization method — for more than one of these lifecycle mechanisms,
that method is run once, as explained in the
preceding section.
Multiple lifecycle mechanisms configured for the same bean, with different initialization methods, are called as follows:
Methods annotated with
@PostConstruct
as defined by theInitializingBean
callback interface -
A custom configured
init()
method
Destroy methods are called in the same order:
@PreDestroy
destroy()
as defined by theDisposableBean
A custom configured
destroy()
method
Startup and Shutdown Callbacks
The Lifecycle
interface defines the essential methods for any object that has its own
lifecycle requirements (such as starting and stopping some background process):
public interface Lifecycle {
void start();
void stop();
boolean isRunning();
Any Spring-managed object may implement the Lifecycle
interface. Then, when the
ApplicationContext
itself receives start and stop signals (for example, for a stop/restart
scenario at runtime), it cascades those calls to all Lifecycle
implementations
defined within that context. It does this by delegating to a LifecycleProcessor
, shown
in the following listing:
public interface LifecycleProcessor extends Lifecycle {
void onRefresh();
void onClose();
Notice that the LifecycleProcessor
is itself an extension of the Lifecycle
interface. It also adds two other methods for reacting to the context being refreshed
and closed.
Note that the regular Also, please note that stop notifications are not guaranteed to come before destruction.
On regular shutdown, all |
The order of startup and shutdown invocations can be important. If a “depends-on”
relationship exists between any two objects, the dependent side starts after its
dependency, and it stops before its dependency. However, at times, the direct
dependencies are unknown. You may only know that objects of a certain type should start
prior to objects of another type. In those cases, the SmartLifecycle
interface defines
another option, namely the getPhase()
method as defined on its super-interface,
Phased
. The following listing shows the definition of the Phased
interface:
public interface Phased {
int getPhase();
The following listing shows the definition of the SmartLifecycle
interface:
public interface SmartLifecycle extends Lifecycle, Phased {
boolean isAutoStartup();
void stop(Runnable callback);
When starting, the objects with the lowest phase start first. When stopping, the
reverse order is followed. Therefore, an object that implements SmartLifecycle
and
whose getPhase()
method returns Integer.MIN_VALUE
would be among the first to start
and the last to stop. At the other end of the spectrum, a phase value of
Integer.MAX_VALUE
would indicate that the object should be started last and stopped
first (likely because it depends on other processes to be running). When considering the
phase value, it is also important to know that the default phase for any “normal”
Lifecycle
object that does not implement SmartLifecycle
is 0
. Therefore, any
negative phase value indicates that an object should start before those standard
components (and stop after them). The reverse is true for any positive phase value.
The stop method defined by SmartLifecycle
accepts a callback. Any
implementation must invoke that callback’s run()
method after that implementation’s
shutdown process is complete. That enables asynchronous shutdown where necessary, since
the default implementation of the LifecycleProcessor
interface,
DefaultLifecycleProcessor
, waits up to its timeout value for the group of objects
within each phase to invoke that callback. The default per-phase timeout is 30 seconds.
You can override the default lifecycle processor instance by defining a bean named
lifecycleProcessor
within the context. If you want only to modify the timeout,
defining the following would suffice:
<bean id="lifecycleProcessor" class="org.springframework.context.support.DefaultLifecycleProcessor">
<!-- timeout value in milliseconds -->
<property name="timeoutPerShutdownPhase" value="10000"/>
</bean>
As mentioned earlier, the LifecycleProcessor
interface defines callback methods for the
refreshing and closing of the context as well. The latter drives the shutdown
process as if stop()
had been called explicitly, but it happens when the context is
closing. The 'refresh' callback, on the other hand, enables another feature of
SmartLifecycle
beans. When the context is refreshed (after all objects have been
instantiated and initialized), that callback is invoked. At that point, the
default lifecycle processor checks the boolean value returned by each
SmartLifecycle
object’s isAutoStartup()
method. If true
, that object is
started at that point rather than waiting for an explicit invocation of the context’s or
its own start()
method (unlike the context refresh, the context start does not happen
automatically for a standard context implementation). The phase
value and any
“depends-on” relationships determine the startup order as described earlier.
Shutting Down the Spring IoC Container Gracefully in Non-Web Applications
This section applies only to non-web applications. Spring’s web-based
If you use Spring’s IoC container in a non-web application environment (for example, in a rich client desktop environment), register a shutdown hook with the JVM. Doing so ensures a graceful shutdown and calls the relevant destroy methods on your singleton beans so that all resources are released. You must still configure and implement these destroy callbacks correctly.
To register a shutdown hook, call the registerShutdownHook()
method that is
declared on the ConfigurableApplicationContext
interface, as the following example shows:
Java
Kotlin
import org.springframework.context.ConfigurableApplicationContext;
import org.springframework.context.support.ClassPathXmlApplicationContext;
public final class Boot {
public static void main(final String[] args) throws Exception {
ConfigurableApplicationContext ctx = new ClassPathXmlApplicationContext("beans.xml");
// add a shutdown hook for the above context...
ctx.registerShutdownHook();
// app runs here...
// main method exits, hook is called prior to the app shutting down...
fun main() {
val ctx = ClassPathXmlApplicationContext("beans.xml")
// app runs here...
Thread Safety and Visibility
The Spring core container publishes created singleton instances in a thread-safe manner, guarding access through a singleton lock and guaranteeing visibility in other threads.
As a consequence, application-provided bean classes do not have to be concerned about the
visibility of their initialization state. Regular configuration fields do not have to be
marked as volatile
as long as they are only mutated during the initialization phase,
providing visibility guarantees similar to final
even for setter-based configuration
state that is mutable during that initial phase. If such fields get changed after the
bean creation phase and its subsequent initial publication, they need to be declared as
volatile
or guarded by a common lock whenever accessed.
Note that concurrent access to such configuration state in singleton bean instances,
e.g. for controller instances or repository instances, is perfectly thread-safe after
such safe initial publication from the container side. This includes common singleton
FactoryBean
instances which are processed within the general singleton lock as well.
For destruction callbacks, the configuration state remains thread-safe but any runtime
state accumulated between initialization and destruction should be kept in thread-safe
structures (or in volatile
fields for simple cases) as per common Java guidelines.
Deeper Lifecycle
integration as shown above involves runtime-mutable state such as
a runnable
field which will have to be declared as volatile
. While the common
lifecycle callbacks follow a certain order, e.g. a start callback is guaranteed to
only happen after full initialization and a stop callback only after an initial start,
there is a special case with the common stop before destroy arrangement: It is strongly
recommended that the internal state in any such bean also allows for an immediate
destroy callback without a preceding stop since this may happen during an extraordinary
shutdown after a cancelled bootstrap or in case of a stop timeout caused by another bean.
ApplicationContextAware
and BeanNameAware
When an ApplicationContext
creates an object instance that implements the
org.springframework.context.ApplicationContextAware
interface, the instance is provided
with a reference to that ApplicationContext
of the ApplicationContextAware
interface:
public interface ApplicationContextAware {
void setApplicationContext(ApplicationContext applicationContext) throws BeansException;
Thus, beans can programmatically manipulate the ApplicationContext
that created them,
through the ApplicationContext
interface or by casting the reference to a known
subclass of this interface (such as ConfigurableApplicationContext
, which exposes
additional functionality). One use would be the programmatic retrieval of other beans.
Sometimes this capability is useful. However, in general, you should avoid it, because
it couples the code to Spring and does not follow the Inversion of Control style,
where collaborators are provided to beans as properties. Other methods of the
ApplicationContext
provide access to file resources, publishing application events,
and accessing a MessageSource
. These additional features are described in
Additional Capabilities of the ApplicationContext
Autowiring is another alternative to obtain a reference to the
ApplicationContext
. The traditional constructor
and byType
autowiring modes
(as described in Autowiring Collaborators) can provide a dependency of type
ApplicationContext
for a constructor argument or a setter method parameter,
respectively. For more flexibility, including the ability to autowire fields and
multiple parameter methods, use the annotation-based autowiring features. If you do,
is autowired into a field, constructor argument, or method
parameter that expects the ApplicationContext
type if the field, constructor, or
method in question carries the @Autowired
annotation. For more information, see
Using @Autowired
creates a class that implements the
org.springframework.beans.factory.BeanNameAware
interface, the class is provided with
a reference to the name defined in its associated object definition. The following listing
shows the definition of the BeanNameAware interface:
public interface BeanNameAware {
void setBeanName(String name) throws BeansException;
The callback is invoked after population of normal bean properties but before an
initialization callback such as InitializingBean.afterPropertiesSet()
or a custom
init-method.
Other Aware
Interfaces
Besides ApplicationContextAware
and BeanNameAware
(discussed earlier),
Spring offers a wide range of Aware
callback interfaces that let beans indicate to the container
that they require a certain infrastructure dependency. As a general rule, the name indicates the
dependency type. The following table summarizes the most important Aware
interfaces:
Name | Injected Dependency | Explained in… |
Declaring |
Event publisher of the enclosing |
Class loader used to load the bean classes. |
Declaring |
Name of the declaring bean. |
Defined weaver for processing class definition at load time. |
Configured strategy for resolving messages (with support for parameterization and internationalization). |
Spring JMX notification publisher. |
Configured loader for low-level access to resources. |
Current |
Current |
Note again that using these interfaces ties your code to the Spring API and does not follow the Inversion of Control style. As a result, we recommend them for infrastructure beans that require programmatic access to the container.
