For the latest stable version, please use Spring Framework 6.2.4! |
Spring JUnit 4 Testing Annotations
The following annotations are supported only when used in conjunction with the SpringRunner, Spring’s JUnit 4 rules , or Spring’s JUnit 4 support classes:
@IfProfileValue
@IfProfileValue
indicates that the annotated test is enabled for a specific testing
environment. If the configured ProfileValueSource
returns a matching value
for the
provided name
, the test is enabled. Otherwise, the test is disabled and, effectively,
ignored.
You can apply @IfProfileValue
at the class level, the method level, or both.
Class-level usage of @IfProfileValue
takes precedence over method-level usage for any
methods within that class or its subclasses. Specifically, a test is enabled if it is
enabled both at the class level and at the method level. The absence of @IfProfileValue
means the test is implicitly enabled. This is analogous to the semantics of JUnit 4’s
@Ignore
annotation, except that the presence of @Ignore
always disables a test.
The following example shows a test that has an @IfProfileValue
annotation:
Java
Kotlin
@IfProfileValue(name="java.vendor", value="Oracle Corporation") (1)
@Test
public void testProcessWhichRunsOnlyOnOracleJvm() {
// some logic that should run only on Java VMs from Oracle Corporation
1 | Run this test only when the Java vendor is "Oracle Corporation". |
@Test
fun testProcessWhichRunsOnlyOnOracleJvm() {
Alternatively, you can configure @IfProfileValue
with a list of values
(with OR
semantics) to achieve TestNG-like support for test groups in a JUnit 4 environment.
Consider the following example:
Java
Kotlin
@IfProfileValue(name="test-groups", values={"unit-tests", "integration-tests"}) (1)
@Test
public void testProcessWhichRunsForUnitOrIntegrationTestGroups() {
// some logic that should run only for unit and integration test groups
1 | Run this test for unit tests and integration tests. |
@IfProfileValue(name="test-groups", values=["unit-tests", "integration-tests"]) (1)
@Test
fun testProcessWhichRunsForUnitOrIntegrationTestGroups() {
@ProfileValueSourceConfiguration
is a class-level annotation that specifies what type
of ProfileValueSource
to use when retrieving profile values configured through the
@IfProfileValue
annotation. If @ProfileValueSourceConfiguration
is not declared for a
test, SystemProfileValueSource
is used by default. The following example shows how to
use @ProfileValueSourceConfiguration
Java
Kotlin
@ProfileValueSourceConfiguration(CustomProfileValueSource.class) (1)
public class CustomProfileValueSourceTests {
// class body...
1 | Use a custom profile value source. |
@ProfileValueSourceConfiguration(CustomProfileValueSource::class) (1)
// class body...
@Timed
@Timed
indicates that the annotated test method must finish execution in a specified
time period (in milliseconds). If the text execution time exceeds the specified time
period, the test fails.
The time period includes running the test method itself, any repetitions of the test (see
@Repeat
), as well as any setting up or tearing down of the test fixture. The following
example shows how to use it:
Java
Kotlin
@Timed(millis = 1000) (1)
public void testProcessWithOneSecondTimeout() {
// some logic that should not take longer than 1 second to run
1 | Set the time period for the test to one second. |
fun testProcessWithOneSecondTimeout() {
Spring’s @Timed
annotation has different semantics than JUnit 4’s @Test(timeout=…)
support. Specifically, due to the manner in which JUnit 4 handles test execution timeouts
(that is, by executing the test method in a separate Thread
), @Test(timeout=…)
preemptively fails the test if the test takes too long. Spring’s @Timed
, on the other
hand, does not preemptively fail the test but rather waits for the test to complete
before failing.
@Repeat
@Repeat
indicates that the annotated test method must be run repeatedly. The number of
times that the test method is to be run is specified in the annotation.
The scope of execution to be repeated includes execution of the test method itself as
well as any setting up or tearing down of the test fixture. When used with the
SpringMethodRule
, the scope additionally includes
preparation of the test instance by TestExecutionListener
implementations. The
following example shows how to use the @Repeat
annotation:
Java
Kotlin
@Repeat(10) (1)
@Test
public void testProcessRepeatedly() {
1 | Repeat this test ten times. |
@Repeat(10) (1)
@Test
fun testProcessRepeatedly() {
