For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Mixing Aspect Types
It is perfectly possible to mix @AspectJ style aspects by using the auto-proxying support, schema-defined <aop:aspect> aspects, <aop:advisor> declared advisors, and even proxies and interceptors in other styles in the same configuration. All of these are implemented by using the same underlying support mechanism and can co-exist without any difficulty.spring-doc.cn
