For the latest stable version, please use Spring Framework 6.2.4! |
Observability Support
Micrometer defines an Observation concept that enables both Metrics and Traces in applications. Metrics support offers a way to create timers, gauges, or counters for collecting statistics about the runtime behavior of your application. Metrics can help you to track error rates, usage patterns, performance, and more. Traces provide a holistic view of an entire system, crossing application boundaries; you can zoom in on particular user requests and follow their entire completion across applications.
Spring Framework instruments various parts of its own codebase to publish observations if an ObservationRegistry
is configured.
You can learn more about configuring the observability infrastructure in Spring Boot.
List of produced Observations
Spring Framework instruments various features for observability. As outlined at the beginning of this section, observations can generate timer Metrics and/or Traces depending on the configuration.
Observation name | Description |
Time spent for HTTP client exchanges |
Processing time for HTTP server exchanges at the Framework level |
Time spent sending a JMS message to a destination by a message producer. |
Processing time for a JMS message that was previously received by a message consumer. |
Processing time for an execution of a |
Observations are using Micrometer’s official naming convention, but Metrics names will be automatically converted to the format preferred by the monitoring system backend (Prometheus, Atlas, Graphite, InfluxDB…). |
Micrometer Observation concepts
If you are not familiar with Micrometer Observation, here’s a quick summary of the concepts you should know about.
Observation
is the actual recording of something happening in your application. This is processed byObservationHandler
implementations to produce metrics or traces. -
Each observation has a corresponding
ObservationContext
implementation; this type holds all the relevant information for extracting metadata for it. In the case of an HTTP server observation, the context implementation could hold the HTTP request, the HTTP response, any exception thrown during processing, and so forth. -
Each
Observation
holdsKeyValues
metadata. In the case of an HTTP server observation, this could be the HTTP request method, the HTTP response status, and so forth. This metadata is contributed byObservationConvention
implementations which should declare the type ofObservationContext
they support. -
KeyValues
are said to be "low cardinality" if there is a low, bounded number of possible values for theKeyValue
tuple (HTTP method is a good example). Low cardinality values are contributed to metrics only. Conversely, "high cardinality" values are unbounded (for example, HTTP request URIs) and are only contributed to traces. -
An
ObservationDocumentation
documents all observations in a particular domain, listing the expected key names and their meaning.
Configuring Observations
Global configuration options are available at the ObservationRegistry#observationConfig()
level.
Each instrumented component will provide two extension points:
setting the
ObservationRegistry
; if not set, observations will not be recorded and will be no-ops -
providing a custom
to change the default observation name and extractedKeyValues
Using custom Observation conventions
Let’s take the example of the Spring MVC "http.server.requests" metrics instrumentation with the ServerHttpObservationFilter
This observation uses a ServerRequestObservationConvention
with a ServerRequestObservationContext
; custom conventions can be configured on the Servlet filter.
If you would like to customize the metadata produced with the observation, you can extend the DefaultServerRequestObservationConvention
for your requirements:
import io.micrometer.common.KeyValue;
import io.micrometer.common.KeyValues;
import org.springframework.http.server.observation.DefaultServerRequestObservationConvention;
import org.springframework.http.server.observation.ServerRequestObservationContext;
public class ExtendedServerRequestObservationConvention extends DefaultServerRequestObservationConvention {
public KeyValues getLowCardinalityKeyValues(ServerRequestObservationContext context) {
// here, we just want to have an additional KeyValue to the observation, keeping the default values
return super.getLowCardinalityKeyValues(context).and(custom(context));
private KeyValue custom(ServerRequestObservationContext context) {
return KeyValue.of("custom.method", context.getCarrier().getMethod());
If you want full control, you can implement the entire convention contract for the observation you’re interested in:
import java.util.Locale;
import org.springframework.http.server.observation.ServerHttpObservationDocumentation;
import org.springframework.http.server.observation.ServerRequestObservationConvention;
public class CustomServerRequestObservationConvention implements ServerRequestObservationConvention {
public String getName() {
// will be used as the metric name
return "http.server.requests";
public String getContextualName(ServerRequestObservationContext context) {
// will be used for the trace name
return "http " + context.getCarrier().getMethod().toLowerCase(Locale.ROOT);
return KeyValues.of(method(context), status(context), exception(context));
public KeyValues getHighCardinalityKeyValues(ServerRequestObservationContext context) {
return KeyValues.of(httpUrl(context));
private KeyValue method(ServerRequestObservationContext context) {
// You should reuse as much as possible the corresponding ObservationDocumentation for key names
return KeyValue.of(ServerHttpObservationDocumentation.LowCardinalityKeyNames.METHOD, context.getCarrier().getMethod());
// status(), exception(), httpUrl()...
private KeyValue status(ServerRequestObservationContext context) {
return KeyValue.of(ServerHttpObservationDocumentation.LowCardinalityKeyNames.STATUS, String.valueOf(context.getResponse().getStatus()));
private KeyValue exception(ServerRequestObservationContext context) {
String exception = (context.getError() != null ? context.getError().getClass().getSimpleName() : KeyValue.NONE_VALUE);
return KeyValue.of(ServerHttpObservationDocumentation.LowCardinalityKeyNames.EXCEPTION, exception);
private KeyValue httpUrl(ServerRequestObservationContext context) {
return KeyValue.of(ServerHttpObservationDocumentation.HighCardinalityKeyNames.HTTP_URL, context.getCarrier().getRequestURI());
You can also achieve similar goals using a custom ObservationFilter
– adding or removing key values for an observation.
Filters do not replace the default convention and are used as a post-processing component.
import io.micrometer.observation.Observation;
import io.micrometer.observation.ObservationFilter;
public class ServerRequestObservationFilter implements ObservationFilter {
public Observation.Context map(Observation.Context context) {
if (context instanceof ServerRequestObservationContext serverContext) {
context.setName("custom.observation.name");
context.addLowCardinalityKeyValue(KeyValue.of("project", "spring"));
String customAttribute = (String) serverContext.getCarrier().getAttribute("customAttribute");
context.addLowCardinalityKeyValue(KeyValue.of("custom.attribute", customAttribute));
return context;
You can configure ObservationFilter
instances on the ObservationRegistry
@Scheduled tasks instrumentation
An Observation is created for each execution of an @Scheduled
task.
Applications need to configure the ObservationRegistry
on the ScheduledTaskRegistrar
to enable the recording of observations.
This can be done by declaring a SchedulingConfigurer
bean that sets the observation registry:
import io.micrometer.observation.ObservationRegistry;
import org.springframework.scheduling.annotation.SchedulingConfigurer;
import org.springframework.scheduling.config.ScheduledTaskRegistrar;
public class ObservationSchedulingConfigurer implements SchedulingConfigurer {
private final ObservationRegistry observationRegistry;
public ObservationSchedulingConfigurer(ObservationRegistry observationRegistry) {
this.observationRegistry = observationRegistry;
public void configureTasks(ScheduledTaskRegistrar taskRegistrar) {
taskRegistrar.setObservationRegistry(this.observationRegistry);
It is using the org.springframework.scheduling.support.DefaultScheduledTaskObservationConvention
by default, backed by the ScheduledTaskObservationContext
You can configure a custom implementation on the ObservationRegistry
directly.
During the execution of the scheduled method, the current observation is restored in the ThreadLocal
context or the Reactor context (if the scheduled method returns a Mono
or Flux
type).
By default, the following KeyValues
are created:
Name |
Description |
Name of Java |
Canonical name of the class of the bean instance that holds the scheduled method, or |
Class name of the exception thrown during the execution, or |
Duplicates the |
Outcome of the method execution. Can be |
JMS messaging instrumentation
Spring Framework uses the Jakarta JMS instrumentation provided by Micrometer if the io.micrometer:micrometer-jakarta9
dependency is on the classpath.
The io.micrometer.jakarta9.instrument.jms.JmsInstrumentation
instruments jakarta.jms.Session
and records the relevant observations.
This instrumentation will create 2 types of observations:
"jms.message.publish"
when a JMS message is sent to the broker, typically withJmsTemplate
"jms.message.process"
when a JMS message is processed by the application, typically with aMessageListener
or a@JmsListener
annotated method.
currently there is no instrumentation for "jms.message.receive" observations as there is little value in measuring the time spent waiting for the reception of a message.
Such an integration would typically instrument MessageConsumer#receive method calls. But once those return, the processing time is not measured and the trace scope cannot be propagated to the application.
By default, both observations share the same set of possible KeyValues
Name |
Description |
Class name of the exception thrown during the messaging operation (or "none"). |
Duplicates the |
Whether the destination is a |
Name of JMS operation being performed (values: |
Name |
Description |
The correlation ID of the JMS message. |
The name of destination the current message was sent to. |
Value used by the messaging system as an identifier for the message. |
JMS message Publication instrumentation
observations are recorded when a JMS message is sent to the broker.
They measure the time spent sending the message and propagate the tracing information with outgoing JMS message headers.
You will need to configure the ObservationRegistry
on the JmsTemplate
to enable observations:
import jakarta.jms.ConnectionFactory;
import org.springframework.jms.core.JmsMessagingTemplate;
import org.springframework.jms.core.JmsTemplate;
public class JmsTemplatePublish {
private final JmsTemplate jmsTemplate;
private final JmsMessagingTemplate jmsMessagingTemplate;
public JmsTemplatePublish(ObservationRegistry observationRegistry, ConnectionFactory connectionFactory) {
this.jmsTemplate = new JmsTemplate(connectionFactory);
// configure the observation registry
this.jmsTemplate.setObservationRegistry(observationRegistry);
// For JmsMessagingTemplate, instantiate it with a JMS template that has a configured registry
this.jmsMessagingTemplate = new JmsMessagingTemplate(this.jmsTemplate);
public void sendMessages() {
this.jmsTemplate.convertAndSend("spring.observation.test", "test message");
It uses the io.micrometer.jakarta9.instrument.jms.DefaultJmsPublishObservationConvention
by default, backed by the io.micrometer.jakarta9.instrument.jms.JmsPublishObservationContext
Similar observations are recorded with @JmsListener
annotated methods when response messages are returned from the listener method.
JMS message Processing instrumentation
observations are recorded when a JMS message is processed by the application.
They measure the time spent processing the message and propagate the tracing context with incoming JMS message headers.
Most applications will use the @JmsListener
annotated methods mechanism to process incoming messages.
You will need to ensure that the ObservationRegistry
is configured on the dedicated JmsListenerContainerFactory
import org.springframework.jms.annotation.EnableJms;
import org.springframework.jms.config.DefaultJmsListenerContainerFactory;
@EnableJms
public class JmsConfiguration {
public DefaultJmsListenerContainerFactory jmsListenerContainerFactory(ConnectionFactory connectionFactory, ObservationRegistry observationRegistry) {
DefaultJmsListenerContainerFactory factory = new DefaultJmsListenerContainerFactory();
factory.setConnectionFactory(connectionFactory);
factory.setObservationRegistry(observationRegistry);
return factory;
A default container factory is required to enable the annotation support,
but note that @JmsListener
annotations can refer to specific container factory beans for specific purposes.
In all cases, Observations are only recorded if the observation registry is configured on the container factory.
Similar observations are recorded with JmsTemplate
when messages are processed by a MessageListener
Such listeners are set on a MessageConsumer
within a session callback (see JmsTemplate.execute(SessionCallback<T>)
This observation uses the io.micrometer.jakarta9.instrument.jms.DefaultJmsProcessObservationConvention
by default, backed by the io.micrometer.jakarta9.instrument.jms.JmsProcessObservationContext
HTTP Server instrumentation
HTTP server exchange observations are created with the name "http.server.requests"
for Servlet and Reactive applications.
Servlet applications
Applications need to configure the org.springframework.web.filter.ServerHttpObservationFilter
Servlet filter in their application.
It uses the org.springframework.http.server.observation.DefaultServerRequestObservationConvention
by default, backed by the ServerRequestObservationContext
This will only record an observation as an error if the Exception
has not been handled by the web framework and has bubbled up to the Servlet filter.
Typically, all exceptions handled by Spring MVC’s @ExceptionHandler
and ProblemDetail
support will not be recorded with the observation.
You can, at any point during request processing, set the error field on the ObservationContext
yourself:
import jakarta.servlet.http.HttpServletRequest;
import org.springframework.http.ResponseEntity;
import org.springframework.stereotype.Controller;
import org.springframework.web.bind.annotation.ExceptionHandler;
import org.springframework.web.filter.ServerHttpObservationFilter;
@Controller
public class UserController {
@ExceptionHandler(MissingUserException.class)
ResponseEntity<Void> handleMissingUser(HttpServletRequest request, MissingUserException exception) {
// We want to record this exception with the observation
ServerHttpObservationFilter.findObservationContext(request)
.ifPresent(context -> context.setError(exception));
return ResponseEntity.notFound().build();
static class MissingUserException extends RuntimeException {
Because the instrumentation is done at the Servlet Filter level, the observation scope only covers the filters ordered after this one as well as the handling of the request.
Typically, Servlet container error handling is performed at a lower level and won’t have any active observation or span.
For this use case, a container-specific implementation is required, such as a org.apache.catalina.Valve for Tomcat; this is outside the scope of this project.
are created:
Name |
Description |
Class name of the exception thrown during the exchange, or |
Duplicates the |
Name of HTTP request method or |
Outcome of the HTTP server exchange. |
HTTP response raw status code, or |
URI pattern for the matching handler if available, falling back to |
Name |
Description |
HTTP request URI. |
Applications need to configure the WebHttpHandlerBuilder
with a MeterRegistry
to enable server instrumentation.
This can be done on the WebHttpHandlerBuilder
, as follows:
import org.springframework.context.ApplicationContext;
import org.springframework.http.server.reactive.HttpHandler;
import org.springframework.web.server.adapter.WebHttpHandlerBuilder;
public class HttpHandlerConfiguration {
private final ApplicationContext applicationContext;
public HttpHandlerConfiguration(ApplicationContext applicationContext) {
this.applicationContext = applicationContext;
public HttpHandler httpHandler(ObservationRegistry registry) {
return WebHttpHandlerBuilder.applicationContext(this.applicationContext)
.observationRegistry(registry)
It is using the org.springframework.http.server.reactive.observation.DefaultServerRequestObservationConvention
has not been handled by an application Controller.
Typically, all exceptions handled by Spring WebFlux’s @ExceptionHandler
and ProblemDetail
yourself:
import org.springframework.http.server.reactive.observation.ServerRequestObservationContext;
import org.springframework.web.server.ServerWebExchange;
@Controller
ResponseEntity<Void> handleMissingUser(ServerWebExchange exchange, MissingUserException exception) {
ServerRequestObservationContext.findCurrent(exchange.getAttributes())
are created:
Name |
Description |
Duplicates the |
Name |
Description |
HTTP request URI. |
HTTP Client Instrumentation
HTTP client exchange observations are created with the name "http.client.requests"
for blocking and reactive clients.
Unlike their server counterparts, the instrumentation is implemented directly in the client so the only required step is to configure an ObservationRegistry
on the client.
RestTemplate
Applications must configure an ObservationRegistry
on RestTemplate
instances to enable the instrumentation; without that, observations are "no-ops".
Spring Boot will auto-configure RestTemplateBuilder
beans with the observation registry already set.
Instrumentation uses the org.springframework.http.client.observation.ClientRequestObservationConvention
by default, backed by the ClientRequestObservationContext
Name |
Description |
URI template used for HTTP request, or |
Client name derived from the request URI host. |
Outcome of the HTTP client exchange. |
Duplicates the |
Name |
Description |
HTTP request URI. |
RestClient
on the RestClient.Builder
Name |
Description |
Duplicates the |
Name |
Description |
HTTP request URI. |
WebClient
on the WebClient
builder to enable the instrumentation; without that, observations are "no-ops".
Spring Boot will auto-configure WebClient.Builder
Instrumentation uses the org.springframework.web.reactive.function.client.ClientRequestObservationConvention
Name |
Description |
Duplicates the |
Name |
Description |
HTTP request URI. |
Application Events and @EventListener
Spring Framework does not contribute Observations for @EventListener
calls,
as they don’t have the right semantics for such instrumentation.
By default, event publication and processing are done synchronously and on the same thread.
This means that during the execution of that task, the ThreadLocals and logging context will be the same as the event publisher.
If the application globally configures a custom ApplicationEventMulticaster
with a strategy that schedules event processing on different threads, this is no longer true.
All @EventListener
methods will be processed on a different thread, outside the main event publication thread.
In these cases, the Micrometer Context Propagation library can help propagate such values and better correlate the processing of the events.
The application can configure the chosen TaskExecutor
to use a ContextPropagatingTaskDecorator
that decorates tasks and propagates context.
For this to work, the io.micrometer:context-propagation
library must be present on the classpath:
import org.springframework.context.event.SimpleApplicationEventMulticaster;
import org.springframework.core.task.SimpleAsyncTaskExecutor;
import org.springframework.core.task.support.ContextPropagatingTaskDecorator;
public class ApplicationEventsConfiguration {
@Bean(name = "applicationEventMulticaster")
public SimpleApplicationEventMulticaster simpleApplicationEventMulticaster() {
SimpleApplicationEventMulticaster eventMulticaster = new SimpleApplicationEventMulticaster();
SimpleAsyncTaskExecutor taskExecutor = new SimpleAsyncTaskExecutor();
// decorate task execution with a decorator that supports context propagation
taskExecutor.setTaskDecorator(new ContextPropagatingTaskDecorator());
eventMulticaster.setTaskExecutor(taskExecutor);
return eventMulticaster;
Similarly, if that asynchronous choice is made locally for each @EventListener
annotated method, by adding @Async
to it,
you can choose a TaskExecutor
that propagates context by referring to it by its qualifier.
Given the following TaskExecutor
bean definition, configured with the dedicated task decorator:
import org.springframework.core.task.TaskExecutor;
public class EventAsyncExecutionConfiguration {
@Bean(name = "propagatingContextExecutor")
public TaskExecutor propagatingContextExecutor() {
return taskExecutor;
Annotating event listeners with @Async
and the relevant qualifier will achieve similar context propagation results:
import org.apache.commons.logging.Log;
import org.apache.commons.logging.LogFactory;
import org.springframework.context.event.EventListener;
import org.springframework.scheduling.annotation.Async;
@Component
public class EmailNotificationListener {
private final Log logger = LogFactory.getLog(EmailNotificationListener.class);
@EventListener(EmailReceivedEvent.class)
@Async("propagatingContextExecutor")
public void emailReceived(EmailReceivedEvent event) {
// asynchronously process the received event
// this logging statement will contain the expected MDC entries from the propagated context
logger.info("email has been received");
