For the latest stable version, please use Spring Framework 6.2.4! |
Advanced XML Config
The MVC namespace does not have an advanced mode. If you need to customize a property on
a bean that you cannot change otherwise, you can use the BeanPostProcessor
lifecycle
hook of the Spring ApplicationContext
, as the following example shows:
Java
Kotlin
@Component
public class MyPostProcessor implements BeanPostProcessor {
public Object postProcessBeforeInitialization(Object bean, String name) throws BeansException {
@Component
class MyPostProcessor : BeanPostProcessor {
override fun postProcessBeforeInitialization(bean: Any, name: String): Any {
Note that you need to declare MyPostProcessor
as a bean, either explicitly in XML or
by letting it be detected through a <component-scan/>
declaration.
