For the latest stable version, please use Spring Framework 6.2.4! |
View Controllers
This is a shortcut for defining a ParameterizableViewController
that immediately
forwards to a view when invoked. You can use it in static cases when there is no Java controller
logic to run before the view generates the response.
The following example of Java configuration forwards a request for /
to a view called home
Java
Kotlin
@EnableWebMvc
public void addViewControllers(ViewControllerRegistry registry) {
registry.addViewController("/").setViewName("home");
@EnableWebMvc
override fun addViewControllers(registry: ViewControllerRegistry) {
The following example achieves the same thing as the preceding example, but with XML, by
using the <mvc:view-controller>
element:
<mvc:view-controller path="/" view-name="home"/>
If an @RequestMapping
method is mapped to a URL for any HTTP method then a view
controller cannot be used to handle the same URL. This is because a match by URL to an
annotated controller is considered a strong enough indication of endpoint ownership so
that a 405 (METHOD_NOT_ALLOWED), a 415 (UNSUPPORTED_MEDIA_TYPE), or similar response can
be sent to the client to help with debugging. For this reason it is recommended to avoid
splitting URL handling across an annotated controller and a view controller.
