For the latest stable version, please use Spring Framework 6.2.4! |
@Commit
@Commit
indicates that the transaction for a transactional test method should be
committed after the test method has completed. You can use @Commit
as a direct
replacement for @Rollback(false)
to more explicitly convey the intent of the code.
Analogous to @Rollback
, @Commit
can also be declared as a class-level or method-level
annotation.
The following example shows how to use the @Commit
annotation:
Java
Kotlin
@Commit (1)
@Test
void testProcessWithoutRollback() {
1 | Commit the result of the test to the database. |
@Commit (1)
@Test
fun testProcessWithoutRollback() {
