此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Security 6.3.1
对于每个被拒绝的授权,都会触发一个。 此外,还可以触发和授予授权。AuthorizationDeniedEventAuthorizationGrantedEvent
若要侦听这些事件,必须首先发布 .AuthorizationEventPublisher
Spring Security 可能会做得很好。 它使用 Spring 的 :SpringAuthorizationEventPublisherApplicationEventPublisher
  • Java
  • Kotlin
public AuthorizationEventPublisher authorizationEventPublisher
        (ApplicationEventPublisher applicationEventPublisher) {
    return new SpringAuthorizationEventPublisher(applicationEventPublisher);
fun authorizationEventPublisher
        (applicationEventPublisher: ApplicationEventPublisher?): AuthorizationEventPublisher {
    return SpringAuthorizationEventPublisher(applicationEventPublisher)
然后,您可以使用 Spring 的支持:@EventListener
  • Java
  • Kotlin
@Component
public class AuthenticationEvents {
    @EventListener
    public void onFailure(AuthorizationDeniedEvent failure) {
@Component
    @EventListener
    fun onFailure(failure: AuthorizationDeniedEvent?) {
授权授予事件
由于 s 可能会非常嘈杂,因此默认情况下不会发布它们。AuthorizationGrantedEvent
事实上,发布这些事件可能需要您执行一些业务逻辑,以确保您的应用程序不会被嘈杂的授权事件淹没。
您可以创建自己的事件发布者来筛选成功事件。 例如,以下发布者仅在需要时发布授权:ROLE_ADMIN
  • Java
  • Kotlin
@Component
public class MyAuthorizationEventPublisher implements AuthorizationEventPublisher {
    private final ApplicationEventPublisher publisher;
    private final AuthorizationEventPublisher delegate;
    public MyAuthorizationEventPublisher(ApplicationEventPublisher publisher) {
        this.publisher = publisher;
        this.delegate = new SpringAuthorizationEventPublisher(publisher);
    public <T> void publishAuthorizationEvent(Supplier<Authentication> authentication,
            T object, AuthorizationDecision decision) {
        if (decision == null) {
            return;
        if (!decision.isGranted()) {
            this.delegate.publishAuthorizationEvent(authentication, object, decision);
            return;
        if (shouldThisEventBePublished(decision)) {
            AuthorizationGrantedEvent granted = new AuthorizationGrantedEvent(
            this.publisher.publishEvent(granted);
    private boolean shouldThisEventBePublished(AuthorizationDecision decision) {
        if (!(decision instanceof AuthorityAuthorizationDecision)) {
            return false;
        Collection<GrantedAuthority> authorities = ((AuthorityAuthorizationDecision) decision).getAuthorities();
        for (GrantedAuthority authority : authorities) {
            if ("ROLE_ADMIN".equals(authority.getAuthority())) {
                return true;
        return false;
@Component
class MyAuthorizationEventPublisher(val publisher: ApplicationEventPublisher,
    val delegate: SpringAuthorizationEventPublisher = SpringAuthorizationEventPublisher(publisher)):
    override fun <T : Any?> publishAuthorizationEvent(
        authentication: Supplier<Authentication>?,
        `object`: T,
        decision: AuthorizationDecision?
            return
        if (!decision.isGranted) {
            this.delegate.publishAuthorizationEvent(authentication, `object`, decision)
            return
            val granted = AuthorizationGrantedEvent(authentication, `object`, decision)
    private fun shouldThisEventBePublished(decision: AuthorizationDecision): Boolean {
        if (decision !is AuthorityAuthorizationDecision) {
            return false
        val authorities = decision.authorities
        for (authority in authorities) {
            if ("ROLE_ADMIN" == authority.authority) {
                return true
        return false
