For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
Fine-tuning Annotation-based Autowiring with Qualifiers
@Primary is an effective way to use autowiring by type with several instances when one primary candidate can be determined. When you need more control over the selection process, you can use Spring’s @Qualifier annotation. You can associate qualifier values with specific arguments, narrowing the set of type matches so that a specific bean is chosen for each argument. In the simplest case, this can be a plain descriptive value, as shown in the following example:spring-doc.cn
public class MovieRecommender {
	@Autowired
	@Qualifier("main")
	private MovieCatalog movieCatalog;
	@Autowired
	@Qualifier("main")
	private lateinit var movieCatalog: MovieCatalog
You can also specify the @Qualifier annotation on individual constructor arguments or method parameters, as shown in the following example:spring-doc.cn
	private final MovieCatalog movieCatalog;
	private final CustomerPreferenceDao customerPreferenceDao;
	@Autowired
	public void prepare(@Qualifier("main") MovieCatalog movieCatalog,
			CustomerPreferenceDao customerPreferenceDao) {
		this.movieCatalog = movieCatalog;
		this.customerPreferenceDao = customerPreferenceDao;
	private lateinit var customerPreferenceDao: CustomerPreferenceDao
	@Autowired
	fun prepare(@Qualifier("main") movieCatalog: MovieCatalog,
				customerPreferenceDao: CustomerPreferenceDao) {
The following example shows corresponding bean definitions.spring-doc.cn
	xmlns:context="http://www.springframework.org/schema/context"
		https://www.springframework.org/schema/context/spring-context.xsd">
	<context:annotation-config/>
	<bean class="example.SimpleMovieCatalog">
		<qualifier value="main"/> (1)
		<!-- inject any dependencies required by this bean -->
	</bean>
		<qualifier value="action"/> (2)
	</bean>
	<bean id="movieRecommender" class="example.MovieRecommender"/>
</beans>
1 The bean with the main qualifier value is wired with the constructor argument that is qualified with the same value.
2 The bean with the action qualifier value is wired with the constructor argument that is qualified with the same value.
For a fallback match, the bean name is considered a default qualifier value. Thus, you can define the bean with an id of main instead of the nested qualifier element, leading to the same matching result. However, although you can use this convention to refer to specific beans by name, @Autowired is fundamentally about type-driven injection with optional semantic qualifiers. This means that qualifier values, even with the bean name fallback, always have narrowing semantics within the set of type matches. They do not semantically express a reference to a unique bean id. Good qualifier values are main or EMEA or persistent, expressing characteristics of a specific component that are independent from the bean id, which may be auto-generated in case of an anonymous bean definition such as the one in the preceding example.spring-doc.cn
Qualifiers also apply to typed collections, as discussed earlier — for example, to Set<MovieCatalog>. In this case, all matching beans, according to the declared qualifiers, are injected as a collection. This implies that qualifiers do not have to be unique. Rather, they constitute filtering criteria. For example, you can define multiple MovieCatalog beans with the same qualifier value “action”, all of which are injected into a Set<MovieCatalog> annotated with @Qualifier("action").spring-doc.cn
Letting qualifier values select against target bean names, within the type-matching candidates, does not require a @Qualifier annotation at the injection point. If there is no other resolution indicator (such as a qualifier or a primary marker), for a non-unique dependency situation, Spring matches the injection point name (that is, the field name or parameter name) against the target bean names and chooses the same-named candidate, if any (either by bean name or by associated alias).spring-doc.cn
Since version 6.1, this requires the -parameters Java compiler flag to be present.spring-doc.cn
As an alternative for injection by name, consider the JSR-250 @Resource annotation which is semantically defined to identify a specific target component by its unique name, with the declared type being irrelevant for the matching process. @Autowired has rather different semantics: After selecting candidate beans by type, the specified String qualifier value is considered within those type-selected candidates only (for example, matching an account qualifier against beans marked with the same qualifier label).spring-doc.cn
For beans that are themselves defined as a collection, Map, or array type, @Resource is a fine solution, referring to the specific collection or array bean by unique name. That said, as of 4.3, you can match collection, Map, and array types through Spring’s @Autowired type matching algorithm as well, as long as the element type information is preserved in @Bean return type signatures or collection inheritance hierarchies. In this case, you can use qualifier values to select among same-typed collections, as outlined in the previous paragraph.spring-doc.cn
As of 4.3, @Autowired also considers self references for injection (that is, references back to the bean that is currently injected). Note that self injection is a fallback. Regular dependencies on other components always have precedence. In that sense, self references do not participate in regular candidate selection and are therefore in particular never primary. On the contrary, they always end up as lowest precedence. In practice, you should use self references as a last resort only (for example, for calling other methods on the same instance through the bean’s transactional proxy). Consider factoring out the affected methods to a separate delegate bean in such a scenario. Alternatively, you can use @Resource, which may obtain a proxy back to the current bean by its unique name.spring-doc.cn
Trying to inject the results from @Bean methods on the same configuration class is effectively a self-reference scenario as well. Either lazily resolve such references in the method signature where it is actually needed (as opposed to an autowired field in the configuration class) or declare the affected @Bean methods as static, decoupling them from the containing configuration class instance and its lifecycle. Otherwise, such beans are only considered in the fallback phase, with matching beans on other configuration classes selected as primary candidates instead (if available).spring-doc.cn
@Autowired applies to fields, constructors, and multi-argument methods, allowing for narrowing through qualifier annotations at the parameter level. In contrast, @Resource is supported only for fields and bean property setter methods with a single argument. As a consequence, you should stick with qualifiers if your injection target is a constructor or a multi-argument method.spring-doc.cn
You can create your own custom qualifier annotations. To do so, define an annotation and provide the @Qualifier annotation within your definition, as the following example shows:spring-doc.cn
@Target({ElementType.FIELD, ElementType.PARAMETER})
@Qualifier
public @interface Genre {
	String value();
@Target(AnnotationTarget.FIELD, AnnotationTarget.VALUE_PARAMETER)
@Retention(AnnotationRetention.RUNTIME)
@Qualifier
annotation class Genre(val value: String)
Then you can provide the custom qualifier on autowired fields and parameters, as the following example shows:spring-doc.cn
	@Autowired
	@Genre("Action")
	private MovieCatalog actionCatalog;
	private MovieCatalog comedyCatalog;
	@Autowired
	public void setComedyCatalog(@Genre("Comedy") MovieCatalog comedyCatalog) {
		this.comedyCatalog = comedyCatalog;
	@Autowired
	@Genre("Action")
	private lateinit var actionCatalog: MovieCatalog
	private lateinit var comedyCatalog: MovieCatalog
	@Autowired
	fun setComedyCatalog(@Genre("Comedy") comedyCatalog: MovieCatalog) {
Next, you can provide the information for the candidate bean definitions. You can add <qualifier/> tags as sub-elements of the <bean/> tag and then specify the type and value to match your custom qualifier annotations. The type is matched against the fully-qualified class name of the annotation. Alternately, as a convenience if no risk of conflicting names exists, you can use the short class name. The following example demonstrates both approaches:spring-doc.cn
		<qualifier type="Genre" value="Action"/>
	</bean>
		<qualifier type="example.Genre" value="Comedy"/>
	</bean>
</beans>
In Classpath Scanning and Managed Components, you can see an annotation-based alternative to providing the qualifier metadata in XML. Specifically, see Providing Qualifier Metadata with Annotations.spring-doc.cn
In some cases, using an annotation without a value may suffice. This can be useful when the annotation serves a more generic purpose and can be applied across several different types of dependencies. For example, you may provide an offline catalog that can be searched when no Internet connection is available. First, define the simple annotation, as the following example shows:spring-doc.cn
@Qualifier
public @interface Offline {
@Qualifier
annotation class Offline
Then add the annotation to the field or property to be autowired, as shown in the following example:spring-doc.cn
	@Autowired
	@Offline (1)
	private MovieCatalog offlineCatalog;
1 This line adds the @Offline annotation.
	@Autowired
	@Offline (1)
	private lateinit var offlineCatalog: MovieCatalog
Now the bean definition only needs a qualifier type, as shown in the following example:spring-doc.cn
	<qualifier type="Offline"/> (1)
</bean>
1 This element specifies the qualifier.
You can also define custom qualifier annotations that accept named attributes in addition to or instead of the simple value attribute. If multiple attribute values are then specified on a field or parameter to be autowired, a bean definition must match all such attribute values to be considered an autowire candidate. As an example, consider the following annotation definition:spring-doc.cn
@Qualifier
public @interface MovieQualifier {
	String genre();
	Format format();
@Qualifier
annotation class MovieQualifier(val genre: String, val format: Format)
In this case Format is an enum, defined as follows:spring-doc.cn
public enum Format {
	VHS, DVD, BLURAY
enum class Format {
	VHS, DVD, BLURAY
The fields to be autowired are annotated with the custom qualifier and include values for both attributes: genre and format, as the following example shows:spring-doc.cn
	@Autowired
	@MovieQualifier(format=Format.VHS, genre="Action")
	private MovieCatalog actionVhsCatalog;
	@Autowired
	@MovieQualifier(format=Format.VHS, genre="Comedy")
	private MovieCatalog comedyVhsCatalog;
	@Autowired
	@MovieQualifier(format=Format.DVD, genre="Action")
	private MovieCatalog actionDvdCatalog;
	@Autowired
	@MovieQualifier(format=Format.BLURAY, genre="Comedy")
	private MovieCatalog comedyBluRayCatalog;
	@Autowired
	@MovieQualifier(format = Format.VHS, genre = "Action")
	private lateinit var actionVhsCatalog: MovieCatalog
	@Autowired
	@MovieQualifier(format = Format.VHS, genre = "Comedy")
	private lateinit var comedyVhsCatalog: MovieCatalog
	@Autowired
	@MovieQualifier(format = Format.DVD, genre = "Action")
	private lateinit var actionDvdCatalog: MovieCatalog
	@Autowired
	@MovieQualifier(format = Format.BLURAY, genre = "Comedy")
	private lateinit var comedyBluRayCatalog: MovieCatalog
Finally, the bean definitions should contain matching qualifier values. This example also demonstrates that you can use bean meta attributes instead of the <qualifier/> elements. If available, the <qualifier/> element and its attributes take precedence, but the autowiring mechanism falls back on the values provided within the <meta/> tags if no such qualifier is present, as in the last two bean definitions in the following example:spring-doc.cn
		<qualifier type="MovieQualifier">
			<attribute key="format" value="VHS"/>
			<attribute key="genre" value="Action"/>
		</qualifier>
	</bean>
			<attribute key="genre" value="Comedy"/>
		</qualifier>
	</bean>
		<meta key="format" value="DVD"/>
		<meta key="genre" value="Action"/>
	</bean>
		<meta key="format" value="BLURAY"/>
		<meta key="genre" value="Comedy"/>
	</bean>
</beans>
