For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
Dependencies and Configuration in Detail
As mentioned in the previous section, you can define bean properties and constructor arguments as references to other managed beans (collaborators) or as values defined inline. Spring’s XML-based configuration metadata supports sub-element types within its <property/> and <constructor-arg/> elements for this purpose.spring-doc.cn
Straight Values (Primitives, Strings, and so on)
The value attribute of the <property/> element specifies a property or constructor argument as a human-readable string representation. Spring’s conversion service is used to convert these values from a String to the actual type of the property or argument. The following example shows various values being set:spring-doc.cn
<bean id="myDataSource" class="org.apache.commons.dbcp.BasicDataSource" destroy-method="close">
	<!-- results in a setDriverClassName(String) call -->
	<property name="driverClassName" value="com.mysql.jdbc.Driver"/>
	<property name="url" value="jdbc:mysql://localhost:3306/mydb"/>
	<property name="username" value="root"/>
	<property name="password" value="misterkaoli"/>
</bean>
The following example uses the p-namespace for even more succinct XML configuration:spring-doc.cn
	xmlns:p="http://www.springframework.org/schema/p"
	https://www.springframework.org/schema/beans/spring-beans.xsd">
		p:driverClassName="com.mysql.jdbc.Driver"
		p:url="jdbc:mysql://localhost:3306/mydb"
		p:username="root"
		p:password="misterkaoli"/>
</beans>
The preceding XML is more succinct. However, typos are discovered at runtime rather than design time, unless you use an IDE (such as IntelliJ IDEA or the Spring Tools for Eclipse) that supports automatic property completion when you create bean definitions. Such IDE assistance is highly recommended.spring-doc.cn
You can also configure a java.util.Properties instance, as follows:spring-doc.cn
<bean id="mappings"
	class="org.springframework.context.support.PropertySourcesPlaceholderConfigurer">
	<!-- typed as a java.util.Properties -->
	<property name="properties">
		<value>
			jdbc.driver.className=com.mysql.jdbc.Driver
			jdbc.url=jdbc:mysql://localhost:3306/mydb
		</value>
	</property>
</bean>
The Spring container converts the text inside the <value/> element into a java.util.Properties instance by using the JavaBeans PropertyEditor mechanism. This is a nice shortcut, and is one of a few places where the Spring team do favor the use of the nested <value/> element over the value attribute style.spring-doc.cn
The idref element
The idref element is simply an error-proof way to pass the id (a string value - not a reference) of another bean in the container to a <constructor-arg/> or <property/> element. The following example shows how to use it:spring-doc.cn
<bean id="theTargetBean" class="..."/>
<bean id="theClientBean" class="...">
	<property name="targetName">
		<idref bean="theTargetBean"/>
	</property>
</bean>
The preceding bean definition snippet is exactly equivalent (at runtime) to the following snippet:spring-doc.cn
<bean id="theTargetBean" class="..." />
	<property name="targetName" ref="theTargetBean"/>
</bean>
The first form is preferable to the second, because using the idref tag lets the container validate at deployment time that the referenced, named bean actually exists. In the second variation, no validation is performed on the value that is passed to the targetName property of the client bean. Typos are only discovered (with most likely fatal results) when the client bean is actually instantiated. If the client bean is a prototype bean, this typo and the resulting exception may only be discovered long after the container is deployed.spring-doc.cn
The local attribute on the idref element is no longer supported in the 4.0 beans XSD, since it does not provide value over a regular bean reference any more. Change your existing idref local references to idref bean when upgrading to the 4.0 schema.
A common place (at least in versions earlier than Spring 2.0) where the <idref/> element brings value is in the configuration of AOP interceptors in a ProxyFactoryBean bean definition. Using <idref/> elements when you specify the interceptor names prevents you from misspelling an interceptor ID.spring-doc.cn
References to Other Beans (Collaborators)
The ref element is the final element inside a <constructor-arg/> or <property/> definition element. Here, you set the value of the specified property of a bean to be a reference to another bean (a collaborator) managed by the container. The referenced bean is a dependency of the bean whose property is to be set, and it is initialized on demand as needed before the property is set. (If the collaborator is a singleton bean, it may already be initialized by the container.) All references are ultimately a reference to another object. Scoping and validation depend on whether you specify the ID or name of the other object through the bean or parent attribute.spring-doc.cn
Specifying the target bean through the bean attribute of the <ref/> tag is the most general form and allows creation of a reference to any bean in the same container or parent container, regardless of whether it is in the same XML file. The value of the bean attribute may be the same as the id attribute of the target bean or be the same as one of the values in the name attribute of the target bean. The following example shows how to use a ref element:spring-doc.cn
<ref bean="someBean"/>
Specifying the target bean through the parent attribute creates a reference to a bean that is in a parent container of the current container. The value of the parent attribute may be the same as either the id attribute of the target bean or one of the values in the name attribute of the target bean. The target bean must be in a parent container of the current one. You should use this bean reference variant mainly when you have a hierarchy of containers and you want to wrap an existing bean in a parent container with a proxy that has the same name as the parent bean. The following pair of listings shows how to use the parent attribute:spring-doc.cn
<!-- in the parent context -->
<bean id="accountService" class="com.something.SimpleAccountService">
	<!-- insert dependencies as required here -->
</bean>
<!-- in the child (descendant) context -->
<bean id="accountService" <!-- bean name is the same as the parent bean -->
	class="org.springframework.aop.framework.ProxyFactoryBean">
	<property name="target">
		<ref parent="accountService"/> <!-- notice how we refer to the parent bean -->
	</property>
	<!-- insert other configuration and dependencies as required here -->
</bean>
The local attribute on the ref element is no longer supported in the 4.0 beans XSD, since it does not provide value over a regular bean reference any more. Change your existing ref local references to ref bean when upgrading to the 4.0 schema.
Inner Beans
A <bean/> element inside the <property/> or <constructor-arg/> elements defines an inner bean, as the following example shows:spring-doc.cn
<bean id="outer" class="...">
	<!-- instead of using a reference to a target bean, simply define the target bean inline -->
		<bean class="com.example.Person"> <!-- this is the inner bean -->
			<property name="name" value="Fiona Apple"/>
			<property name="age" value="25"/>
		</bean>
	</property>
</bean>
An inner bean definition does not require a defined ID or name. If specified, the container does not use such a value as an identifier. The container also ignores the scope flag on creation, because inner beans are always anonymous and are always created with the outer bean. It is not possible to access inner beans independently or to inject them into collaborating beans other than into the enclosing bean.spring-doc.cn
As a corner case, it is possible to receive destruction callbacks from a custom scope — for example, for a request-scoped inner bean contained within a singleton bean. The creation of the inner bean instance is tied to its containing bean, but destruction callbacks let it participate in the request scope’s lifecycle. This is not a common scenario. Inner beans typically simply share their containing bean’s scope.spring-doc.cn
Collections
The <list/>, <set/>, <map/>, and <props/> elements set the properties and arguments of the Java Collection types List, Set, Map, and Properties, respectively. The following example shows how to use them:spring-doc.cn
<bean id="moreComplexObject" class="example.ComplexObject">
	<!-- results in a setAdminEmails(java.util.Properties) call -->
	<property name="adminEmails">
		<props>
			<prop key="administrator">[email protected]</prop>
			<prop key="support">[email protected]</prop>
			<prop key="development">[email protected]</prop>
		</props>
	</property>
	<!-- results in a setSomeList(java.util.List) call -->
	<property name="someList">
		<list>
			<value>a list element followed by a reference</value>
			<ref bean="myDataSource" />
		</list>
	</property>
	<!-- results in a setSomeMap(java.util.Map) call -->
	<property name="someMap">
		<map>
			<entry key="an entry" value="just some string"/>
			<entry key="a ref" value-ref="myDataSource"/>
		</map>
	</property>
	<!-- results in a setSomeSet(java.util.Set) call -->
	<property name="someSet">
		<set>
			<value>just some string</value>
		</set>
	</property>
</bean>
The value of a map key or value, or a set value, can also be any of the following elements:spring-doc.cn
bean | ref | idref | list | set | map | props | value | null
Collection Merging
The Spring container also supports merging collections. An application developer can define a parent <list/>, <map/>, <set/> or <props/> element and have child <list/>, <map/>, <set/> or <props/> elements inherit and override values from the parent collection. That is, the child collection’s values are the result of merging the elements of the parent and child collections, with the child’s collection elements overriding values specified in the parent collection.spring-doc.cn
This section on merging discusses the parent-child bean mechanism. Readers unfamiliar with parent and child bean definitions may wish to read the relevant section before continuing.spring-doc.cn
The following example demonstrates collection merging:spring-doc.cn
<beans>
	<bean id="parent" abstract="true" class="example.ComplexObject">
			<props>
			</props>
		</property>
	</bean>
	<bean id="child" parent="parent">
			<!-- the merge is specified on the child collection definition -->
			<props merge="true">
				<prop key="sales">[email protected]</prop>
			</props>
		</property>
	</bean>
<beans>
Notice the use of the merge=true attribute on the <props/> element of the adminEmails property of the child bean definition. When the child bean is resolved and instantiated by the container, the resulting instance has an adminEmails Properties collection that contains the result of merging the child’s adminEmails collection with the parent’s adminEmails collection. The following listing shows the result:spring-doc.cn
The child Properties collection’s value set inherits all property elements from the parent <props/>, and the child’s value for the support value overrides the value in the parent collection.spring-doc.cn
This merging behavior applies similarly to the <list/>, <map/>, and <set/> collection types. In the specific case of the <list/> element, the semantics associated with the List collection type (that is, the notion of an ordered collection of values) is maintained. The parent’s values precede all of the child list’s values. In the case of the Map, Set, and Properties collection types, no ordering exists. Hence, no ordering semantics are in effect for the collection types that underlie the associated Map, Set, and Properties implementation types that the container uses internally.spring-doc.cn
Limitations of Collection Merging
You cannot merge different collection types (such as a Map and a List). If you do attempt to do so, an appropriate Exception is thrown. The merge attribute must be specified on the lower, inherited, child definition. Specifying the merge attribute on a parent collection definition is redundant and does not result in the desired merging.spring-doc.cn
Strongly-typed collection
Thanks to Java’s support for generic types, you can use strongly typed collections. That is, it is possible to declare a Collection type such that it can only contain (for example) String elements. If you use Spring to dependency-inject a strongly-typed Collection into a bean, you can take advantage of Spring’s type-conversion support such that the elements of your strongly-typed Collection instances are converted to the appropriate type prior to being added to the Collection. The following Java class and bean definition show how to do so:spring-doc.cn
public class SomeClass {
	private Map<String, Float> accounts;
	public void setAccounts(Map<String, Float> accounts) {
		this.accounts = accounts;
class SomeClass {
	lateinit var accounts: Map<String, Float>
<beans>
	<bean id="something" class="x.y.SomeClass">
		<property name="accounts">
			<map>
				<entry key="one" value="9.99"/>
				<entry key="two" value="2.75"/>
				<entry key="six" value="3.99"/>
			</map>
		</property>
	</bean>
</beans>
When the accounts property of the something bean is prepared for injection, the generics information about the element type of the strongly-typed Map<String, Float> is available by reflection. Thus, Spring’s type conversion infrastructure recognizes the various value elements as being of type Float, and the string values (9.99, 2.75, and 3.99) are converted into an actual Float type.spring-doc.cn
Null and Empty String Values
Spring treats empty arguments for properties and the like as empty Strings. The following XML-based configuration metadata snippet sets the email property to the empty String value ("").spring-doc.cn
<bean class="ExampleBean">
	<property name="email" value=""/>
</bean>
The preceding example is equivalent to the following Java code:spring-doc.cn
exampleBean.setEmail("");
exampleBean.email = ""
The <null/> element handles null values. The following listing shows an example:spring-doc.cn
	<property name="email">
		<null/>
	</property>
</bean>
The preceding configuration is equivalent to the following Java code:spring-doc.cn
exampleBean.setEmail(null);
exampleBean.email = null
XML Shortcut with the p-namespace
The p-namespace lets you use the bean element’s attributes (instead of nested <property/> elements) to describe your property values collaborating beans, or both.spring-doc.cn
Spring supports extensible configuration formats with namespaces, which are based on an XML Schema definition. The beans configuration format discussed in this chapter is defined in an XML Schema document. However, the p-namespace is not defined in an XSD file and exists only in the core of Spring.spring-doc.cn
The following example shows two XML snippets (the first uses standard XML format and the second uses the p-namespace) that resolve to the same result:spring-doc.cn
	<bean name="classic" class="com.example.ExampleBean">
		<property name="email" value="[email protected]"/>
	</bean>
	<bean name="p-namespace" class="com.example.ExampleBean"
		p:email="[email protected]"/>
</beans>
The example shows an attribute in the p-namespace called email in the bean definition. This tells Spring to include a property declaration. As previously mentioned, the p-namespace does not have a schema definition, so you can set the name of the attribute to the property name.spring-doc.cn
This next example includes two more bean definitions that both have a reference to another bean:spring-doc.cn
	<bean name="john-classic" class="com.example.Person">
		<property name="name" value="John Doe"/>
		<property name="spouse" ref="jane"/>
	</bean>
	<bean name="john-modern"
		p:name="John Doe"
		p:spouse-ref="jane"/>
	<bean name="jane" class="com.example.Person">
		<property name="name" value="Jane Doe"/>
	</bean>
</beans>
This example includes not only a property value using the p-namespace but also uses a special format to declare property references. Whereas the first bean definition uses <property name="spouse" ref="jane"/> to create a reference from bean john to bean jane, the second bean definition uses p:spouse-ref="jane" as an attribute to do the exact same thing. In this case, spouse is the property name, whereas the -ref part indicates that this is not a straight value but rather a reference to another bean.spring-doc.cn
The p-namespace is not as flexible as the standard XML format. For example, the format for declaring property references clashes with properties that end in Ref, whereas the standard XML format does not. We recommend that you choose your approach carefully and communicate this to your team members to avoid producing XML documents that use all three approaches at the same time.
XML Shortcut with the c-namespace
Similar to the XML Shortcut with the p-namespace, the c-namespace, introduced in Spring 3.1, allows inlined attributes for configuring the constructor arguments rather then nested constructor-arg elements.spring-doc.cn
The following example uses the c: namespace to do the same thing as the from Constructor-based Dependency Injection:spring-doc.cn
	xmlns:c="http://www.springframework.org/schema/c"
	<bean id="beanTwo" class="x.y.ThingTwo"/>
	<bean id="beanThree" class="x.y.ThingThree"/>
	<!-- traditional declaration with optional argument names -->
	<bean id="beanOne" class="x.y.ThingOne">
		<constructor-arg name="thingTwo" ref="beanTwo"/>
		<constructor-arg name="thingThree" ref="beanThree"/>
		<constructor-arg name="email" value="[email protected]"/>
	</bean>
	<!-- c-namespace declaration with argument names -->
	<bean id="beanOne" class="x.y.ThingOne" c:thingTwo-ref="beanTwo"
		c:thingThree-ref="beanThree" c:email="[email protected]"/>
</beans>
The c: namespace uses the same conventions as the p: one (a trailing -ref for bean references) for setting the constructor arguments by their names. Similarly, it needs to be declared in the XML file even though it is not defined in an XSD schema (it exists inside the Spring core).spring-doc.cn
For the rare cases where the constructor argument names are not available (usually if the bytecode was compiled without the -parameters flag), you can fall back to the argument indexes, as follows:spring-doc.cn
<!-- c-namespace index declaration -->
<bean id="beanOne" class="x.y.ThingOne" c:_0-ref="beanTwo" c:_1-ref="beanThree"
	c:_2="[email protected]"/>
Due to the XML grammar, the index notation requires the presence of the leading _, as XML attribute names cannot start with a number (even though some IDEs allow it). A corresponding index notation is also available for <constructor-arg> elements but not commonly used since the plain order of declaration is usually sufficient there.
In practice, the constructor resolution mechanism is quite efficient in matching arguments, so unless you really need to, we recommend using the name notation throughout your configuration.spring-doc.cn
Compound Property Names
You can use compound or nested property names when you set bean properties, as long as all components of the path except the final property name are not null. Consider the following bean definition:spring-doc.cn
<bean id="something" class="things.ThingOne">
	<property name="fred.bob.sammy" value="123" />
</bean>
The something bean has a fred property, which has a bob property, which has a sammy property, and that final sammy property is being set to a value of 123. In order for this to work, the fred property of something and the bob property of fred must not be null after the bean is constructed. Otherwise, a NullPointerException is thrown.spring-doc.cn
