For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
Variables
You can reference variables in an expression by using the #variableName syntax. Variables are set by using the setVariable() method in EvaluationContext implementations.spring-doc.cn
Variable names must be begin with a letter (as defined below), an underscore, or a dollar sign.spring-doc.cn
Variable names must be composed of one or more of the following supported types of characters.spring-doc.cn
  • letter: any character for which java.lang.Character.isLetter(char) returns truespring-doc.cn
    • This includes letters such as A to Z, a to z, ü, ñ, and é as well as letters from other character sets such as Chinese, Japanese, Cyrillic, etc.spring-doc.cn
  • digit: 0 to 9spring-doc.cn
  • underscore: _spring-doc.cn
  • dollar sign: $spring-doc.cn
When setting a variable or root context object in the EvaluationContext, it is advised that the type of the variable or root context object be public.spring-doc.cn
Otherwise, certain types of SpEL expressions involving a variable or root context object with a non-public type may fail to evaluate or compile.spring-doc.cn
Since variables share a common namespace with functions in the evaluation context, care must be taken to ensure that variable names and functions names do not overlap.spring-doc.cn
The following example shows how to use variables.spring-doc.cn
Inventor tesla = new Inventor("Nikola Tesla", "Serbian");
EvaluationContext context = SimpleEvaluationContext.forReadWriteDataBinding().build();
context.setVariable("newName", "Mike Tesla");
parser.parseExpression("name = #newName").getValue(context, tesla);
System.out.println(tesla.getName());  // "Mike Tesla"
val tesla = Inventor("Nikola Tesla", "Serbian")
val context = SimpleEvaluationContext.forReadWriteDataBinding().build()
println(tesla.name)  // "Mike Tesla"
The #this and #root Variables
The #this variable is always defined and refers to the current evaluation object (against which unqualified references are resolved). The #root variable is always defined and refers to the root context object. Although #this may vary as components of an expression are evaluated, #root always refers to the root.spring-doc.cn
The following example shows how to use the #this variable in conjunction with collection selection.spring-doc.cn
// Create a list of prime integers.
List<Integer> primes = List.of(2, 3, 5, 7, 11, 13, 17);
// Create parser and set variable 'primes' as the list of integers.
ExpressionParser parser = new SpelExpressionParser();
context.setVariable("primes", primes);
// Select all prime numbers > 10 from the list (using selection ?{...}).
String expression = "#primes.?[#this > 10]";
// Evaluates to a list containing [11, 13, 17].
List<Integer> primesGreaterThanTen =
		parser.parseExpression(expression).getValue(context, List.class);
val primes = listOf(2, 3, 5, 7, 11, 13, 17)
val parser = SpelExpressionParser()
val expression = "#primes.?[#this > 10]"
val primesGreaterThanTen = parser.parseExpression(expression)
		.getValue(context) as List<Int>
The following example shows how to use the #this and #root variables together in conjunction with collection projection.spring-doc.cn
// Create parser and evaluation context.
// Create an inventor to use as the root context object.
Inventor tesla = new Inventor("Nikola Tesla");
tesla.setInventions("Telephone repeater", "Tesla coil transformer");
// Iterate over all inventions of the Inventor referenced as the #root
// object, and generate a list of strings whose contents take the form
// "<inventor's name> invented the <invention>." (using projection !{...}).
String expression = "#root.inventions.![#root.name + ' invented the ' + #this + '.']";
// Evaluates to a list containing:
// "Nikola Tesla invented the Telephone repeater."
// "Nikola Tesla invented the Tesla coil transformer."
List<String> results = parser.parseExpression(expression)
		.getValue(context, tesla, List.class);
val tesla = Inventor("Nikola Tesla")
val expression = "#root.inventions.![#root.name + ' invented the ' + #this + '.']"
val results = parser.parseExpression(expression)
		.getValue(context, tesla, List::class.java)
