For the latest stable version, please use Spring Framework 6.2.0! |
Bean Scopes
When you create a bean definition, you create a recipe for creating actual instances of the class defined by that bean definition. The idea that a bean definition is a recipe is important, because it means that, as with a class, you can create many object instances from a single recipe.
You can control not only the various dependencies and configuration values that are to
be plugged into an object that is created from a particular bean definition but also control
the scope of the objects created from a particular bean definition. This approach is
powerful and flexible, because you can choose the scope of the objects you create
through configuration instead of having to bake in the scope of an object at the Java
class level. Beans can be defined to be deployed in one of a number of scopes.
The Spring Framework supports six scopes, four of which are available only if
you use a web-aware ApplicationContext
. You can also create
a custom scope.
The following table describes the supported scopes:
Scope | Description |
(Default) Scopes a single bean definition to a single object instance for each Spring IoC container. |
Scopes a single bean definition to any number of object instances. |
Scopes a single bean definition to the lifecycle of a single HTTP request. That is,
each HTTP request has its own instance of a bean created off the back of a single bean
definition. Only valid in the context of a web-aware Spring |
Scopes a single bean definition to the lifecycle of an HTTP |
Scopes a single bean definition to the lifecycle of a |
A thread scope is available but is not registered by default. For more information,
see the documentation for
SimpleThreadScope .
For instructions on how to register this or any other custom scope, see
Using a Custom Scope.
The Singleton Scope
Only one shared instance of a singleton bean is managed, and all requests for beans with an ID or IDs that match that bean definition result in that one specific bean instance being returned by the Spring container.
To put it another way, when you define a bean definition and it is scoped as a singleton, the Spring IoC container creates exactly one instance of the object defined by that bean definition. This single instance is stored in a cache of such singleton beans, and all subsequent requests and references for that named bean return the cached object. The following image shows how the singleton scope works:
Spring’s concept of a singleton bean differs from the singleton pattern as defined in the Gang of Four (GoF) patterns book. The GoF singleton hard-codes the scope of an object such that one and only one instance of a particular class is created per ClassLoader. The scope of the Spring singleton is best described as being per-container and per-bean. This means that, if you define one bean for a particular class in a single Spring container, the Spring container creates one and only one instance of the class defined by that bean definition. The singleton scope is the default scope in Spring. To define a bean as a singleton in XML, you can define a bean as shown in the following example:
<bean id="accountService" class="com.something.DefaultAccountService"/>
<!-- the following is equivalent, though redundant (singleton scope is the default) -->
<bean id="accountService" class="com.something.DefaultAccountService" scope="singleton"/>
The Prototype Scope
The non-singleton prototype scope of bean deployment results in the creation of a new
bean instance every time a request for that specific bean is made. That is, the bean
is injected into another bean or you request it through a getBean()
method call on the
container. As a rule, you should use the prototype scope for all stateful beans and the
singleton scope for stateless beans.
The following diagram illustrates the Spring prototype scope:
(A data access object (DAO) is not typically configured as a prototype, because a typical DAO does not hold any conversational state. It was easier for us to reuse the core of the singleton diagram.)
The following example defines a bean as a prototype in XML:
<bean id="accountService" class="com.something.DefaultAccountService" scope="prototype"/>
In contrast to the other scopes, Spring does not manage the complete lifecycle of a prototype bean. The container instantiates, configures, and otherwise assembles a prototype object and hands it to the client, with no further record of that prototype instance. Thus, although initialization lifecycle callback methods are called on all objects regardless of scope, in the case of prototypes, configured destruction lifecycle callbacks are not called. The client code must clean up prototype-scoped objects and release expensive resources that the prototype beans hold. To get the Spring container to release resources held by prototype-scoped beans, try using a custom bean post-processor which holds a reference to beans that need to be cleaned up.
In some respects, the Spring container’s role in regard to a prototype-scoped bean is a
replacement for the Java new
operator. All lifecycle management past that point must
be handled by the client. (For details on the lifecycle of a bean in the Spring
container, see Lifecycle Callbacks.)
Singleton Beans with Prototype-bean Dependencies
When you use singleton-scoped beans with dependencies on prototype beans, be aware that dependencies are resolved at instantiation time. Thus, if you dependency-inject a prototype-scoped bean into a singleton-scoped bean, a new prototype bean is instantiated and then dependency-injected into the singleton bean. The prototype instance is the sole instance that is ever supplied to the singleton-scoped bean.
However, suppose you want the singleton-scoped bean to acquire a new instance of the prototype-scoped bean repeatedly at runtime. You cannot dependency-inject a prototype-scoped bean into your singleton bean, because that injection occurs only once, when the Spring container instantiates the singleton bean and resolves and injects its dependencies. If you need a new instance of a prototype bean at runtime more than once, see Method Injection.
Request, Session, Application, and WebSocket Scopes
The request
, session
, application
, and websocket
scopes are available only
if you use a web-aware Spring ApplicationContext
implementation (such as
XmlWebApplicationContext
). If you use these scopes with regular Spring IoC containers,
such as the ClassPathXmlApplicationContext
, an IllegalStateException
that complains
about an unknown bean scope is thrown.
Initial Web Configuration
To support the scoping of beans at the request
, session
, application
, and
websocket
levels (web-scoped beans), some minor initial configuration is
required before you define your beans. (This initial setup is not required
for the standard scopes: singleton
and prototype
How you accomplish this initial setup depends on your particular Servlet environment.
If you access scoped beans within Spring Web MVC, in effect, within a request that is
processed by the Spring DispatcherServlet
, no special setup is necessary.
DispatcherServlet
already exposes all relevant state.
If you use a Servlet web container, with requests processed outside of Spring’s
DispatcherServlet
(for example, when using JSF), you need to register the
org.springframework.web.context.request.RequestContextListener
ServletRequestListener
This can be done programmatically by using the WebApplicationInitializer
interface.
Alternatively, add the following declaration to your web application’s web.xml
file:
<web-app>
<listener>
<listener-class>
</listener-class>
</listener>
</web-app>
Alternatively, if there are issues with your listener setup, consider using Spring’s
RequestContextFilter
. The filter mapping depends on the surrounding web
application configuration, so you have to change it as appropriate. The following listing
shows the filter part of a web application:
<web-app>
<filter>
<filter-name>requestContextFilter</filter-name>
<filter-class>org.springframework.web.filter.RequestContextFilter</filter-class>
</filter>
<filter-mapping>
<url-pattern>/*</url-pattern>
</filter-mapping>
</web-app>
DispatcherServlet
, RequestContextListener
, and RequestContextFilter
all do exactly
the same thing, namely bind the HTTP request object to the Thread
that is servicing
that request. This makes beans that are request- and session-scoped available further
down the call chain.
Request scope
Consider the following XML configuration for a bean definition:
<bean id="loginAction" class="com.something.LoginAction" scope="request"/>
The Spring container creates a new instance of the LoginAction
bean by using the
loginAction
bean definition for each and every HTTP request. That is, the
loginAction
bean is scoped at the HTTP request level. You can change the internal
state of the instance that is created as much as you want, because other instances
created from the same loginAction
bean definition do not see these changes in state.
They are particular to an individual request. When the request completes processing, the
bean that is scoped to the request is discarded.
When using annotation-driven components or Java configuration, the @RequestScope
annotation
can be used to assign a component to the request
scope. The following example shows how
to do so:
Java
Kotlin
@RequestScope
@Component
public class LoginAction {
@RequestScope
@Component
class LoginAction {
Session Scope
<bean id="userPreferences" class="com.something.UserPreferences" scope="session"/>
The Spring container creates a new instance of the UserPreferences
bean by using the
userPreferences
bean definition for the lifetime of a single HTTP Session
. In other
words, the userPreferences
bean is effectively scoped at the HTTP Session
level. As
with request-scoped beans, you can change the internal state of the instance that is
created as much as you want, knowing that other HTTP Session
instances that are also
using instances created from the same userPreferences
changes in state, because they are particular to an individual HTTP Session
. When the
HTTP Session
is eventually discarded, the bean that is scoped to that particular HTTP
Session
is also discarded.
When using annotation-driven components or Java configuration, you can use the
@SessionScope
annotation to assign a component to the session
scope.
Java
Kotlin
@SessionScope
@Component
public class UserPreferences {
@SessionScope
@Component
Application Scope
<bean id="appPreferences" class="com.something.AppPreferences" scope="application"/>
The Spring container creates a new instance of the AppPreferences
bean by using the
appPreferences
bean definition once for the entire web application. That is, the
appPreferences
bean is scoped at the ServletContext
level and stored as a regular
ServletContext
attribute. This is somewhat similar to a Spring singleton bean but
differs in two important ways: It is a singleton per ServletContext
, not per Spring
ApplicationContext
(for which there may be several in any given web application),
and it is actually exposed and therefore visible as a ServletContext
attribute.
@ApplicationScope
annotation to assign a component to the application
scope. The
following example shows how to do so:
Java
Kotlin
@ApplicationScope
@Component
public class AppPreferences {
@ApplicationScope
@Component
WebSocket Scope
WebSocket scope is associated with the lifecycle of a WebSocket session and applies to STOMP over WebSocket applications, see WebSocket scope for more details.
Scoped Beans as Dependencies
The Spring IoC container manages not only the instantiation of your objects (beans), but also the wiring up of collaborators (or dependencies). If you want to inject (for example) an HTTP request-scoped bean into another bean of a longer-lived scope, you may choose to inject an AOP proxy in place of the scoped bean. That is, you need to inject a proxy object that exposes the same public interface as the scoped object but that can also retrieve the real target object from the relevant scope (such as an HTTP request) and delegate method calls onto the real object.
You may also use When declaring Also, scoped proxies are not the only way to access beans from shorter scopes in a
lifecycle-safe fashion. You may also declare your injection point (that is, the
constructor or setter argument or autowired field) as As an extended variant, you may declare The JSR-330 variant of this is called |
The configuration in the following example is only one line, but it is important to understand the “why” as well as the “how” behind it:
xmlns:aop="http://www.springframework.org/schema/aop"
https://www.springframework.org/schema/aop/spring-aop.xsd">
<!-- an HTTP Session-scoped bean exposed as a proxy -->
<bean id="userPreferences" class="com.something.UserPreferences" scope="session">
<!-- instructs the container to proxy the surrounding bean -->
<aop:scoped-proxy/> (1)
</bean>
<!-- a singleton-scoped bean injected with a proxy to the above bean -->
<bean id="userService" class="com.something.SimpleUserService">
<!-- a reference to the proxied userPreferences bean -->
<property name="userPreferences" ref="userPreferences"/>
</bean>
</beans>
1 | The line that defines the proxy. |
To create such a proxy, you insert a child <aop:scoped-proxy/>
element into a
scoped bean definition (see
Choosing the Type of Proxy to Create
and XML Schema-based configuration).
Why do definitions of beans scoped at the request
, session
and custom-scope
levels require the <aop:scoped-proxy/>
element in common scenarios?
Consider the following singleton bean definition and contrast it with
what you need to define for the aforementioned scopes (note that the following
userPreferences
bean definition as it stands is incomplete):
<bean id="userManager" class="com.something.UserManager">
</bean>
In the preceding example, the singleton bean (userManager
) is injected with a reference
to the HTTP Session
-scoped bean (userPreferences
). The salient point here is that the
userManager
bean is a singleton: it is instantiated exactly once per
container, and its dependencies (in this case only one, the userPreferences
bean) are
also injected only once. This means that the userManager
bean operates only on the
exact same userPreferences
object (that is, the one with which it was originally injected).
This is not the behavior you want when injecting a shorter-lived scoped bean into a
longer-lived scoped bean (for example, injecting an HTTP Session
-scoped collaborating
bean as a dependency into singleton bean). Rather, you need a single userManager
object, and, for the lifetime of an HTTP Session
, you need a userPreferences
object
that is specific to the HTTP Session
. Thus, the container creates an object that
exposes the exact same public interface as the UserPreferences
class (ideally an
object that is a UserPreferences
instance), which can fetch the real
UserPreferences
object from the scoping mechanism (HTTP request, Session
, and so
forth). The container injects this proxy object into the userManager
bean, which is
unaware that this UserPreferences
reference is a proxy. In this example, when a
UserManager
instance invokes a method on the dependency-injected UserPreferences
object, it is actually invoking a method on the proxy. The proxy then fetches the real
UserPreferences
object from (in this case) the HTTP Session
and delegates the
method invocation onto the retrieved real UserPreferences
object.
Thus, you need the following (correct and complete) configuration when injecting
request-
and session-scoped
beans into collaborating objects, as the following example
shows:
<aop:scoped-proxy/>
</bean>
</bean>
By default, when the Spring container creates a proxy for a bean that is marked up with
element, a CGLIB-based class proxy is created.
CGLIB proxies do not intercept private methods. Attempting to call a private method on such a proxy will not delegate to the actual scoped target object. |
Alternatively, you can configure the Spring container to create standard JDK
interface-based proxies for such scoped beans, by specifying false
for the value of
the proxy-target-class
attribute of the <aop:scoped-proxy/>
element. Using JDK
interface-based proxies means that you do not need additional libraries in your
application classpath to affect such proxying. However, it also means that the class of
the scoped bean must implement at least one interface and that all collaborators
into which the scoped bean is injected must reference the bean through one of its
interfaces. The following example shows a proxy based on an interface:
<!-- DefaultUserPreferences implements the UserPreferences interface -->
<bean id="userPreferences" class="com.stuff.DefaultUserPreferences" scope="session">
<aop:scoped-proxy proxy-target-class="false"/>
</bean>
<bean id="userManager" class="com.stuff.UserManager">
</bean>
For more detailed information about choosing class-based or interface-based proxying, see Proxying Mechanisms.
Injecting Request/Session References Directly
As an alternative to factory scopes, a Spring WebApplicationContext
also supports
the injection of HttpServletRequest
, HttpServletResponse
, HttpSession
WebRequest
and (if JSF is present) FacesContext
and ExternalContext
into
Spring-managed beans, simply through type-based autowiring next to regular injection
points for other beans. Spring generally injects proxies for such request and session
objects which has the advantage of working in singleton beans and serializable beans
as well, similar to scoped proxies for factory-scoped beans.
Custom Scopes
The bean scoping mechanism is extensible. You can define your own
scopes or even redefine existing scopes, although the latter is considered bad practice
and you cannot override the built-in singleton
and prototype
scopes.
Creating a Custom Scope
To integrate your custom scopes into the Spring container, you need to implement the
org.springframework.beans.factory.config.Scope
interface, which is described in this
section. For an idea of how to implement your own scopes, see the Scope
implementations that are supplied with the Spring Framework itself and the
Scope
javadoc,
which explains the methods you need to implement in more detail.
The Scope
interface has four methods to get objects from the scope, remove them from
the scope, and let them be destroyed.
The session scope implementation, for example, returns the session-scoped bean (if it does not exist, the method returns a new instance of the bean, after having bound it to the session for future reference). The following method returns the object from the underlying scope:
Java
Kotlin
Object get(String name, ObjectFactory<?> objectFactory)
fun get(name: String, objectFactory: ObjectFactory<*>): Any
The session scope implementation, for example, removes the session-scoped bean from the
underlying session. The object should be returned, but you can return null
if the
object with the specified name is not found. The following method removes the object from
Java
Kotlin
Object remove(String name)
fun remove(name: String): Any
The following method registers a callback that the scope should invoke when it is destroyed or when the specified object in the scope is destroyed:
Java
Kotlin
void registerDestructionCallback(String name, Runnable destructionCallback)
fun registerDestructionCallback(name: String, destructionCallback: Runnable)
See the javadoc or a Spring scope implementation for more information on destruction callbacks.
The following method obtains the conversation identifier for the underlying scope:
Java
Kotlin
String getConversationId()
fun getConversationId(): String
This identifier is different for each scope. For a session scoped implementation, this identifier can be the session identifier.
After you write and test one or more custom Scope
implementations, you need to make
the Spring container aware of your new scopes. The following method is the central
method to register a new Scope
with the Spring container:
Java
Kotlin
void registerScope(String scopeName, Scope scope);
fun registerScope(scopeName: String, scope: Scope)
This method is declared on the ConfigurableBeanFactory
interface, which is available
through the BeanFactory
property on most of the concrete ApplicationContext
implementations that ship with Spring.
The first argument to the registerScope(..)
method is the unique name associated with
a scope. Examples of such names in the Spring container itself are singleton
and
prototype
. The second argument to the registerScope(..)
method is an actual instance
of the custom Scope
implementation that you wish to register and use.
Suppose that you write your custom Scope
implementation, and then register it as shown
in the next example.
The next example uses SimpleThreadScope , which is included with Spring but is not
registered by default. The instructions would be the same for your own custom Scope
implementations.
Java
Kotlin
Scope threadScope = new SimpleThreadScope();
beanFactory.registerScope("thread", threadScope);
val threadScope = SimpleThreadScope()
You can then create bean definitions that adhere to the scoping rules of your custom
Scope
, as follows:
<bean id="..." class="..." scope="thread">
With a custom Scope
implementation, you are not limited to programmatic registration
of the scope. You can also do the Scope
registration declaratively, by using the
CustomScopeConfigurer
class, as the following example shows:
<bean class="org.springframework.beans.factory.config.CustomScopeConfigurer">
<property name="scopes">
<map>
<entry key="thread">
<bean class="org.springframework.context.support.SimpleThreadScope"/>
</entry>
</map>
</property>
</bean>
<bean id="thing2" class="x.y.Thing2" scope="thread">
<property name="name" value="Rick"/>
<aop:scoped-proxy/>
</bean>
<bean id="thing1" class="x.y.Thing1">
<property name="thing2" ref="thing2"/>
</bean>
</beans>
When you place <aop:scoped-proxy/> within a <bean> declaration for a
FactoryBean implementation, it is the factory bean itself that is scoped, not the object
returned from getObject() .
