For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
Logging
DEBUG-level logging in Spring MVC is designed to be compact, minimal, and human-friendly. It focuses on high-value bits of information that are useful over and over again versus others that are useful only when debugging a specific issue.spring-doc.cn
TRACE-level logging generally follows the same principles as DEBUG (and, for example, also should not be a fire hose) but can be used for debugging any issue. In addition, some log messages may show a different level of detail at TRACE versus DEBUG.spring-doc.cn
Good logging comes from the experience of using the logs. If you spot anything that does not meet the stated goals, please let us know.spring-doc.cn
Sensitive Data
DEBUG and TRACE logging may log sensitive information. This is why request parameters and headers are masked by default and their logging in full must be enabled explicitly through the enableLoggingRequestDetails property on DispatcherServlet.spring-doc.cn
The following example shows how to do so by using Java configuration:spring-doc.cn
public class MyInitializer
		extends AbstractAnnotationConfigDispatcherServletInitializer {
	protected Class<?>[] getRootConfigClasses() {
		return ... ;
	protected Class<?>[] getServletConfigClasses() {
		return ... ;
	protected String[] getServletMappings() {
		return ... ;
	protected void customizeRegistration(ServletRegistration.Dynamic registration) {
		registration.setInitParameter("enableLoggingRequestDetails", "true");
class MyInitializer : AbstractAnnotationConfigDispatcherServletInitializer() {
	override fun getRootConfigClasses(): Array<Class<*>>? {
		return ...
	override fun getServletConfigClasses(): Array<Class<*>>? {
		return ...
	override fun getServletMappings(): Array<String> {
		return ...
	override fun customizeRegistration(registration: ServletRegistration.Dynamic) {
