For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
Interception
Events provide notifications for the lifecycle of a STOMP connection but not for every client message. Applications can also register a ChannelInterceptor to intercept any message and in any part of the processing chain. The following example shows how to intercept inbound messages from clients:spring-doc.cn
@EnableWebSocketMessageBroker
public class WebSocketConfig implements WebSocketMessageBrokerConfigurer {
	public void configureClientInboundChannel(ChannelRegistration registration) {
		registration.interceptors(new MyChannelInterceptor());
A custom ChannelInterceptor can use StompHeaderAccessor or SimpMessageHeaderAccessor to access information about the message, as the following example shows:spring-doc.cn
public class MyChannelInterceptor implements ChannelInterceptor {
	public Message<?> preSend(Message<?> message, MessageChannel channel) {
		StompHeaderAccessor accessor = StompHeaderAccessor.wrap(message);
		StompCommand command = accessor.getStompCommand();
		return message;
Applications can also implement ExecutorChannelInterceptor, which is a sub-interface of ChannelInterceptor with callbacks in the thread in which the messages are handled. While a ChannelInterceptor is invoked once for each message sent to a channel, the ExecutorChannelInterceptor provides hooks in the thread of each MessageHandler subscribed to messages from the channel.spring-doc.cn
Note that, as with the SessionDisconnectEvent described earlier, a DISCONNECT message can be from the client or it can also be automatically generated when the WebSocket session is closed. In some cases, an interceptor may intercept this message more than once for each session. Components should be idempotent with regard to multiple disconnect events.spring-doc.cn
