For the latest stable version, please use Spring Framework 6.2.0! |
Composing Java-based Configurations
Spring’s Java-based configuration feature lets you compose annotations, which can reduce the complexity of your configuration.
Using the @Import
Annotation
Much as the <import/>
element is used within Spring XML files to aid in modularizing
configurations, the @Import
annotation allows for loading @Bean
definitions from
another configuration class, as the following example shows:
Java
Kotlin
public class ConfigA {
public A a() {
return new A();
@Import(ConfigA.class)
public class ConfigB {
public B b() {
return new B();
class ConfigA {
fun a() = A()
@Import(ConfigA::class)
class ConfigB {
fun b() = B()
Now, rather than needing to specify both ConfigA.class
and ConfigB.class
when
instantiating the context, only ConfigB
needs to be supplied explicitly, as the
Java
Kotlin
ApplicationContext ctx = new AnnotationConfigApplicationContext(ConfigB.class);
// now both beans A and B will be available...
A a = ctx.getBean(A.class);
B b = ctx.getBean(B.class);
import org.springframework.beans.factory.getBean
fun main() {
val ctx = AnnotationConfigApplicationContext(ConfigB::class.java)
val a = ctx.getBean<A>()
val b = ctx.getBean<B>()
This approach simplifies container instantiation, as only one class needs to be dealt
with, rather than requiring you to remember a potentially large number of
classes during construction.
As of Spring Framework 4.2, @Import also supports references to regular component
classes, analogous to the AnnotationConfigApplicationContext.register method.
This is particularly useful if you want to avoid component scanning, by using a few
configuration classes as entry points to explicitly define all your components.
Injecting Dependencies on Imported @Bean
Definitions
The preceding example works but is simplistic. In most practical scenarios, beans have
dependencies on one another across configuration classes. When using XML, this is not an
issue, because no compiler is involved, and you can declare
ref="someBean"
and trust Spring to work it out during container initialization.
When using @Configuration
classes, the Java compiler places constraints on
the configuration model, in that references to other beans must be valid Java syntax.
Fortunately, solving this problem is simple. As
we already discussed,
a @Bean
method can have an arbitrary number of parameters that describe the bean
dependencies. Consider the following more realistic scenario with several @Configuration
classes, each depending on beans declared in the others:
Java
Kotlin
public class ServiceConfig {
public TransferService transferService(AccountRepository accountRepository) {
return new TransferServiceImpl(accountRepository);
public class RepositoryConfig {
public AccountRepository accountRepository(DataSource dataSource) {
return new JdbcAccountRepository(dataSource);
@Import({ServiceConfig.class, RepositoryConfig.class})
public class SystemTestConfig {
public DataSource dataSource() {
// return new DataSource
ApplicationContext ctx = new AnnotationConfigApplicationContext(SystemTestConfig.class);
// everything wires up across configuration classes...
TransferService transferService = ctx.getBean(TransferService.class);
transferService.transfer(100.00, "A123", "C456");
fun transferService(accountRepository: AccountRepository): TransferService {
return TransferServiceImpl(accountRepository)
fun accountRepository(dataSource: DataSource): AccountRepository {
return JdbcAccountRepository(dataSource)
@Import(ServiceConfig::class, RepositoryConfig::class)
fun dataSource(): DataSource {
fun main() {
val ctx = AnnotationConfigApplicationContext(SystemTestConfig::class.java)
val transferService = ctx.getBean<TransferService>()
There is another way to achieve the same result. Remember that @Configuration
classes are
ultimately only another bean in the container: This means that they can take advantage of
@Autowired
and @Value
injection and other features the same as any other bean.
Make sure that the dependencies you inject that way are of the simplest kind only. Avoid access to locally defined beans within a Also, be particularly careful with |
The following example shows how one bean can be autowired to another bean:
Java
Kotlin
@Autowired
private AccountRepository accountRepository;
public TransferService transferService() {
private final DataSource dataSource;
public RepositoryConfig(DataSource dataSource) {
this.dataSource = dataSource;
public AccountRepository accountRepository() {
@Autowired
lateinit var accountRepository: AccountRepository
fun transferService(): TransferService {
class RepositoryConfig(private val dataSource: DataSource) {
fun accountRepository(): AccountRepository {
fun main() {
Constructor injection in @Configuration classes is only supported as of Spring
Framework 4.3. Note also that there is no need to specify @Autowired if the target
bean defines only one constructor.
Fully-qualifying imported beans for ease of navigation
In the preceding scenario, using @Autowired
works well and provides the desired
modularity, but determining exactly where the autowired bean definitions are declared is
still somewhat ambiguous. For example, as a developer looking at ServiceConfig
, how do
you know exactly where the @Autowired AccountRepository
bean is declared? It is not
explicit in the code, and this may be just fine. Remember that the
Spring Tools for Eclipse provides tooling that
can render graphs showing how everything is wired, which may be all you need. Also,
your Java IDE can easily find all declarations and uses of the AccountRepository
type
and quickly show you the location of @Bean
methods that return that type.
In cases where this ambiguity is not acceptable and you wish to have direct navigation
from within your IDE from one @Configuration
class to another, consider autowiring the
configuration classes themselves. The following example shows how to do so:
Java
Kotlin
@Autowired
private RepositoryConfig repositoryConfig;
// navigate 'through' the config class to the @Bean method!
return new TransferServiceImpl(repositoryConfig.accountRepository());
@Autowired
private lateinit var repositoryConfig: RepositoryConfig
return TransferServiceImpl(repositoryConfig.accountRepository())
In the preceding situation, where AccountRepository
is defined is completely explicit.
However, ServiceConfig
is now tightly coupled to RepositoryConfig
. That is the
tradeoff. This tight coupling can be somewhat mitigated by using interface-based or
abstract class-based @Configuration
classes. Consider the following example:
Java
Kotlin
@Autowired
public interface RepositoryConfig {
AccountRepository accountRepository();
public class DefaultRepositoryConfig implements RepositoryConfig {
return new JdbcAccountRepository(...);
@Import({ServiceConfig.class, DefaultRepositoryConfig.class}) // import the concrete config!
// return DataSource
@Autowired
class DefaultRepositoryConfig : RepositoryConfig {
return JdbcAccountRepository(...)
@Import(ServiceConfig::class, DefaultRepositoryConfig::class) // import the concrete config!
fun main() {
Now ServiceConfig
is loosely coupled with respect to the concrete
, and built-in IDE tooling is still useful: You can easily
get a type hierarchy of RepositoryConfig
implementations. In this
way, navigating @Configuration
classes and their dependencies becomes no different
than the usual process of navigating interface-based code.
If you want to influence the startup creation order of certain beans, consider
declaring some of them as @Lazy (for creation on first access instead of on startup)
or as @DependsOn certain other beans (making sure that specific other beans are
created before the current bean, beyond what the latter’s direct dependencies imply).
Conditionally Include @Configuration
Classes or @Bean
Methods
It is often useful to conditionally enable or disable a complete @Configuration
class
or even individual @Bean
methods, based on some arbitrary system state. One common
example of this is to use the @Profile
annotation to activate beans only when a specific
profile has been enabled in the Spring Environment
(see Bean Definition Profiles
for details).
The @Profile
annotation is actually implemented by using a much more flexible annotation
called @Conditional
The @Conditional
annotation indicates specific
org.springframework.context.annotation.Condition
implementations that should be
consulted before a @Bean
is registered.
Implementations of the Condition
interface provide a matches(…)
method that returns true
or false
. For example, the following listing shows the actual
Condition
implementation used for @Profile
Java
Kotlin
public boolean matches(ConditionContext context, AnnotatedTypeMetadata metadata) {
// Read the @Profile annotation attributes
MultiValueMap<String, Object> attrs = metadata.getAllAnnotationAttributes(Profile.class.getName());
if (attrs != null) {
for (Object value : attrs.get("value")) {
if (context.getEnvironment().matchesProfiles((String[]) value)) {
return true;
return false;
return true;
override fun matches(context: ConditionContext, metadata: AnnotatedTypeMetadata): Boolean {
val attrs = metadata.getAllAnnotationAttributes(Profile::class.java.name)
for (value in attrs["value"]!!) {
if (context.environment.matchesProfiles(*value as Array<String>)) {
return true
return false
return true
See the @Conditional
javadoc for more detail.
Combining Java and XML Configuration
Spring’s @Configuration
class support does not aim to be a 100% complete replacement
for Spring XML. Some facilities, such as Spring XML namespaces, remain an ideal way to
configure the container. In cases where XML is convenient or necessary, you have a
choice: either instantiate the container in an “XML-centric” way by using, for example,
ClassPathXmlApplicationContext
, or instantiate it in a “Java-centric” way by using
and the @ImportResource
annotation to import XML
as needed.
XML-centric Use of @Configuration
Classes
It may be preferable to bootstrap the Spring container from XML and include
classes in an ad-hoc fashion. For example, in a large existing codebase
that uses Spring XML, it is easier to create @Configuration
classes on an
as-needed basis and include them from the existing XML files. Later in this section, we cover the
options for using @Configuration
classes in this kind of “XML-centric” situation.
Declaring @Configuration
classes as plain Spring <bean/>
elements
classes are ultimately bean definitions in the container.
In this series of examples, we create a @Configuration
class named AppConfig
and
include it within system-test-config.xml
as a <bean/>
definition. Because
<context:annotation-config/>
is switched on, the container recognizes the
annotation and processes the @Bean
methods declared in AppConfig
properly.
The following example shows the AppConfig
configuration class in Java and Kotlin:
Java
Kotlin
public class AppConfig {
@Autowired
private DataSource dataSource;
return new TransferServiceImpl(accountRepository());
class AppConfig {
@Autowired
private lateinit var dataSource: DataSource
fun transferService() = TransferService(accountRepository())
The following example shows part of a sample system-test-config.xml
file:
<beans>
<!-- enable processing of annotations such as @Autowired and @Configuration -->
<context:property-placeholder location="classpath:/com/acme/jdbc.properties"/>
<bean class="com.acme.AppConfig"/>
<bean class="org.springframework.jdbc.datasource.DriverManagerDataSource">
<property name="url" value="${jdbc.url}"/>
<property name="username" value="${jdbc.username}"/>
<property name="password" value="${jdbc.password}"/>
</bean>
</beans>
The following example shows a possible jdbc.properties
file:
jdbc.url=jdbc:hsqldb:hsql://localhost/xdb jdbc.username=sa jdbc.password=
Java
Kotlin
ApplicationContext ctx = new ClassPathXmlApplicationContext("classpath:/com/acme/system-test-config.xml");
fun main() {
val ctx = ClassPathXmlApplicationContext("classpath:/com/acme/system-test-config.xml")
In the system-test-config.xml file, the AppConfig <bean/> does not declare an id
attribute. While it would be acceptable to do so, it is unnecessary, given that no other bean
ever refers to it, and it is unlikely to be explicitly fetched from the container by name.
Similarly, the DataSource bean is only ever autowired by type, so an explicit bean id
is not strictly required.
Using <context:component-scan/> to pick up @Configuration
classes
Because @Configuration
is meta-annotated with @Component
, @Configuration
-annotated
classes are automatically candidates for component scanning. Using the same scenario as
described in the previous example, we can redefine system-test-config.xml
to take
advantage of component-scanning. Note that, in this case, we need not explicitly declare
, because <context:component-scan/>
enables the same
functionality.
The following example shows the modified system-test-config.xml
file:
<beans>
<!-- picks up and registers AppConfig as a bean definition -->
<context:component-scan base-package="com.acme"/>
</bean>
</beans>
Class-centric Use of XML with @ImportResource
In applications where @Configuration
classes are the primary mechanism for configuring
the container, it may still be necessary to use at least some XML. In such scenarios, you
can use @ImportResource
and define only as much XML as you need. Doing so achieves a
“Java-centric” approach to configuring the container and keeps XML to a bare minimum.
The following example (which includes a configuration class, an XML file that defines a
bean, a properties file, and the main()
method) shows how to use the @ImportResource
annotation to achieve “Java-centric” configuration that uses XML as needed:
Java
Kotlin
@ImportResource("classpath:/com/acme/properties-config.xml")
@Value("${jdbc.url}")
private String url;
@Value("${jdbc.username}")
private String username;
@Value("${jdbc.password}")
private String password;
return new DriverManagerDataSource(url, username, password);
class AppConfig {
@Value("\${jdbc.url}")
private lateinit var url: String
@Value("\${jdbc.username}")
private lateinit var username: String
@Value("\${jdbc.password}")
private lateinit var password: String
return DriverManagerDataSource(url, username, password)
<beans>
</beans>
Java
Kotlin
ApplicationContext ctx = new AnnotationConfigApplicationContext(AppConfig.class);
fun main() {
val ctx = AnnotationConfigApplicationContext(AppConfig::class.java)
