For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
Bean References
If the evaluation context has been configured with a bean resolver, you can look up beans from an expression by using the @ symbol. The following example shows how to do so:spring-doc.cn
ExpressionParser parser = new SpelExpressionParser();
StandardEvaluationContext context = new StandardEvaluationContext();
context.setBeanResolver(new MyBeanResolver());
// This will end up calling resolve(context,"something") on MyBeanResolver during evaluation
Object bean = parser.parseExpression("@something").getValue(context);
val parser = SpelExpressionParser()
val context = StandardEvaluationContext()
context.setBeanResolver(MyBeanResolver())
val bean = parser.parseExpression("@something").getValue(context)
To access a factory bean itself, you should instead prefix the bean name with an & symbol. The following example shows how to do so:spring-doc.cn
// This will end up calling resolve(context,"&foo") on MyBeanResolver during evaluation
Object bean = parser.parseExpression("&foo").getValue(context);
val bean = parser.parseExpression("&foo").getValue(context)
