For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
Declaration
You can define controller beans by using a standard Spring bean definition in the Servlet’s WebApplicationContext. The @Controller stereotype allows for auto-detection, aligned with Spring general support for detecting @Component classes in the classpath and auto-registering bean definitions for them. It also acts as a stereotype for the annotated class, indicating its role as a web component.spring-doc.cn
To enable auto-detection of such @Controller beans, you can add component scanning to your Java configuration, as the following example shows:spring-doc.cn
@ComponentScan("org.example.web")
public class WebConfig {
class WebConfig {
The following example shows the XML configuration equivalent of the preceding example:spring-doc.cn
	xmlns:p="http://www.springframework.org/schema/p"
	xmlns:context="http://www.springframework.org/schema/context"
	xsi:schemaLocation="
		https://www.springframework.org/schema/context/spring-context.xsd">
	<context:component-scan base-package="org.example.web"/>
</beans>
@RestController is a composed annotation that is itself meta-annotated with @Controller and @ResponseBody to indicate a controller whose every method inherits the type-level @ResponseBody annotation and, therefore, writes directly to the response body versus view resolution and rendering with an HTML template.spring-doc.cn
AOP Proxies
In some cases, you may need to decorate a controller with an AOP proxy at runtime. One example is if you choose to have @Transactional annotations directly on the controller. When this is the case, for controllers specifically, we recommend using class-based proxying. This is automatically the case with such annotations directly on the controller.spring-doc.cn
If the controller implements an interface, and needs AOP proxying, you may need to explicitly configure class-based proxying. For example, with @EnableTransactionManagement you can change to @EnableTransactionManagement(proxyTargetClass = true), and with <tx:annotation-driven/> you can change to <tx:annotation-driven proxy-target-class="true"/>.spring-doc.cn
Keep in mind that as of 6.0, with interface proxying, Spring MVC no longer detects controllers based solely on a type-level @RequestMapping annotation on the interface. Please, enable class based proxying, or otherwise the interface must also have an @Controller annotation.
