For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
Array Construction
You can build arrays by using the familiar Java syntax, optionally supplying an initializer to have the array populated at construction time. The following example shows how to do so:spring-doc.cn
int[] numbers1 = (int[]) parser.parseExpression("new int[4]").getValue(context);
// Array with initializer
int[] numbers2 = (int[]) parser.parseExpression("new int[] {1, 2, 3}").getValue(context);
// Multi dimensional array
int[][] numbers3 = (int[][]) parser.parseExpression("new int[4][5]").getValue(context);
val numbers1 = parser.parseExpression("new int[4]").getValue(context) as IntArray
val numbers2 = parser.parseExpression("new int[] {1, 2, 3}").getValue(context) as IntArray
val numbers3 = parser.parseExpression("new int[4][5]").getValue(context) as Array<IntArray>
You cannot currently supply an initializer when you construct a multi-dimensional array.spring-doc.cn
Any expression that constructs an array – for example, via new int[4] or new int[] {1, 2, 3} – cannot be compiled. See Compiler Limitations for details.spring-doc.cn
