For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
Configuration Configuration with Context Customizers
A ContextCustomizer is responsible for customizing the supplied ConfigurableApplicationContext after bean definitions have been loaded into the context but before the context has been refreshed.spring-doc.cn
A ContextCustomizerFactory is responsible for creating a ContextCustomizer, based on some custom logic which determines if the ContextCustomizer is necessary for a given test class — for example, based on the presence of a certain annotation. Factories are invoked after ContextLoaders have processed context configuration attributes for a test class but before the MergedContextConfiguration is created.spring-doc.cn
For example, Spring Framework provides the following ContextCustomizerFactory implementation which is registered by default:spring-doc.cn
MockServerContainerContextCustomizerFactory
Creates a MockServerContainerContextCustomizer if WebSocket support is present in the classpath and the test class or one of its enclosing classes is annotated or meta-annotated with @WebAppConfiguration. MockServerContainerContextCustomizer instantiates a new MockServerContainer and stores it in the ServletContext under the attribute named jakarta.websocket.server.ServerContainer.spring-doc.cn
Registering ContextCustomizerFactory Implementations
You can register ContextCustomizerFactory implementations explicitly for a test class, its subclasses, and its nested classes by using the @ContextCustomizerFactories annotation. See annotation support and the javadoc for @ContextCustomizerFactories for details and examples.spring-doc.cn
Automatic Discovery of Default ContextCustomizerFactory Implementations
Registering ContextCustomizerFactory implementations by using @ContextCustomizerFactories is suitable for custom factories that are used in limited testing scenarios. However, it can become cumbersome if a custom factory needs to be used across an entire test suite. This issue is addressed through support for automatic discovery of default ContextCustomizerFactory implementations through the SpringFactoriesLoader mechanism.spring-doc.cn
For example, the modules that make up the testing support in Spring Framework and Spring Boot declare all core default ContextCustomizerFactory implementations under the org.springframework.test.context.ContextCustomizerFactory key in their META-INF/spring.factories properties files. The spring.factories file for the spring-test module can be viewed here. Third-party frameworks and developers can contribute their own ContextCustomizerFactory implementations to the list of default factories in the same manner through their own spring.factories files.spring-doc.cn
Merging ContextCustomizerFactory Implementations
If a custom ContextCustomizerFactory is registered via @ContextCustomizerFactories, it will be merged with the default factories that have been registered using the aforementioned automatic discovery mechanism.spring-doc.cn
The merging algorithm ensures that duplicates are removed from the list and that locally declared factories are appended to the list of default factories when merged.spring-doc.cn
To replace the default factories for a test class, its subclasses, and its nested classes, you can set the mergeMode attribute of @ContextCustomizerFactories to MergeMode.REPLACE_DEFAULTS.spring-doc.cn
