For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
Expression Templating
Expression templates allow mixing literal text with one or more evaluation blocks. Each evaluation block is delimited with prefix and suffix characters that you can define. A common choice is to use #{ } as the delimiters, as the following example shows:spring-doc.cn
String randomPhrase = parser.parseExpression(
		"random number is #{T(java.lang.Math).random()}",
		new TemplateParserContext()).getValue(String.class);
// evaluates to "random number is 0.7038186818312008"
val randomPhrase = parser.parseExpression(
		TemplateParserContext()).getValue(String::class.java)
The string is evaluated by concatenating the literal text 'random number is ' with the result of evaluating the expression inside the { } delimiters (in this case, the result of calling that random() method). The second argument to the parseExpression() method is of the type ParserContext. The ParserContext interface is used to influence how the expression is parsed in order to support the expression templating functionality. The TemplateParserContext used in the previous example resides in the org.springframework.expression.common package and is an implementation of the ParserContext which by default configures the prefix and suffix to { and }, respectively.spring-doc.cn
