For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
Using CustomAutowireConfigurer
CustomAutowireConfigurer is a BeanFactoryPostProcessor that lets you register your own custom qualifier annotation types, even if they are not annotated with Spring’s @Qualifier annotation. The following example shows how to use CustomAutowireConfigurer:spring-doc.cn
<bean id="customAutowireConfigurer"
		class="org.springframework.beans.factory.annotation.CustomAutowireConfigurer">
	<property name="customQualifierTypes">
		<set>
			<value>example.CustomQualifier</value>
		</set>
	</property>
</bean>
The AutowireCandidateResolver determines autowire candidates by:spring-doc.cn
  • The autowire-candidate value of each bean definitionspring-doc.cn
  • Any default-autowire-candidates patterns available on the <beans/> elementspring-doc.cn
  • The presence of @Qualifier annotations and any custom annotations registered with the CustomAutowireConfigurerspring-doc.cn
When multiple beans qualify as autowire candidates, the determination of a “primary” is as follows: If exactly one bean definition among the candidates has a primary attribute set to true, it is selected.spring-doc.cn
