For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
<tx:advice/> Settings
This section summarizes the various transactional settings that you can specify by using the <tx:advice/> tag. The default <tx:advice/> settings are:spring-doc.cn
You can change these default settings. The following table summarizes the various attributes of the <tx:method/> tags that are nested within <tx:advice/> and <tx:attributes/> tags:spring-doc.cn
Table 1. <tx:method/> settings
Attribute Required? Default Description
namespring-doc.cn
Yesspring-doc.cn
Method names with which the transaction attributes are to be associated. The wildcard (*) character can be used to associate the same transaction attribute settings with a number of methods (for example, get*, handle*, on*Event, and so forth).spring-doc.cn
propagationspring-doc.cn
Nospring-doc.cn
REQUIREDspring-doc.cn
Transaction propagation behavior.spring-doc.cn
isolationspring-doc.cn
Nospring-doc.cn
DEFAULTspring-doc.cn
Transaction isolation level. Only applicable to propagation settings of REQUIRED or REQUIRES_NEW.spring-doc.cn
timeoutspring-doc.cn
Nospring-doc.cn
-1spring-doc.cn
Transaction timeout (seconds). Only applicable to propagation REQUIRED or REQUIRES_NEW.spring-doc.cn
read-onlyspring-doc.cn
Nospring-doc.cn
falsespring-doc.cn
Read-write versus read-only transaction. Applies only to REQUIRED or REQUIRES_NEW.spring-doc.cn
rollback-forspring-doc.cn
Nospring-doc.cn
Comma-delimited list of Exception instances that trigger rollback. For example, com.foo.MyBusinessException,ServletException.spring-doc.cn
no-rollback-forspring-doc.cn
Nospring-doc.cn
Comma-delimited list of Exception instances that do not trigger rollback. For example, com.foo.MyBusinessException,ServletException.spring-doc.cn
