Kotlin Support
Kotlin is a statically-typed language targeting the JVM (and other platforms) which allows writing concise and elegant code while providing interoperability with existing libraries written in Java.
Spring Boot provides Kotlin support by leveraging the support in other Spring projects such as Spring Framework, Spring Data, and Reactor. See the Spring Framework Kotlin support documentation for more information.
The easiest way to start with Spring Boot and Kotlin is to follow this comprehensive tutorial.
You can create new Kotlin projects by using start.spring.io.
Feel free to join the #spring channel of Kotlin Slack or ask a question with the spring
and kotlin
tags on Stack Overflow if you need support.
Requirements
Spring Boot requires at least Kotlin 1.7.x and manages a suitable Kotlin version through dependency management.
To use Kotlin, org.jetbrains.kotlin:kotlin-stdlib
and org.jetbrains.kotlin:kotlin-reflect
must be present on the classpath.
The kotlin-stdlib
variants kotlin-stdlib-jdk7
and kotlin-stdlib-jdk8
can also be used.
Since Kotlin classes are final by default, you are likely to want to configure kotlin-spring plugin in order to automatically open Spring-annotated classes so that they can be proxied.
Jackson’s Kotlin module is required for serializing / deserializing JSON data in Kotlin. It is automatically registered when found on the classpath. A warning message is logged if Jackson and Kotlin are present but the Jackson Kotlin module is not.
These dependencies and plugins are provided by default if one bootstraps a Kotlin project on start.spring.io. |
Null-safety
One of Kotlin’s key features is null-safety.
It deals with null
values at compile time rather than deferring the problem to runtime and encountering a NullPointerException
This helps to eliminate a common source of bugs without paying the cost of wrappers like Optional
Kotlin also allows using functional constructs with nullable values as described in this comprehensive guide to null-safety in Kotlin.
Although Java does not allow one to express null-safety in its type system, Spring Framework, Spring Data, and Reactor now provide null-safety of their API through tooling-friendly annotations. By default, types from Java APIs used in Kotlin are recognized as platform types for which null-checks are relaxed. Kotlin’s support for JSR 305 annotations combined with nullability annotations provide null-safety for the related Spring API in Kotlin.
The JSR 305 checks can be configured by adding the -Xjsr305
compiler flag with the following options: -Xjsr305={strict|warn|ignore}
The default behavior is the same as -Xjsr305=warn
The strict
value is required to have null-safety taken in account in Kotlin types inferred from Spring API but should be used with the knowledge that Spring API nullability declaration could evolve even between minor releases and more checks may be added in the future).
Generic type arguments, varargs and array elements nullability are not yet supported. See SPR-15942 for up-to-date information. Also be aware that Spring Boot’s own API is not yet annotated. |
Kotlin API
runApplication
Spring Boot provides an idiomatic way to run an application with runApplication<MyApplication>(*args)
as shown in the following example:
import org.springframework.boot.autoconfigure.SpringBootApplication
import org.springframework.boot.runApplication
@SpringBootApplication
class MyApplication
fun main(args: Array<String>) {
This is a drop-in replacement for SpringApplication.run(MyApplication::class.java, *args)
It also allows customization of the application as shown in the following example:
runApplication<MyApplication>(*args) {
setBannerMode(OFF)
Extensions
Kotlin extensions provide the ability to extend existing classes with additional functionality. The Spring Boot Kotlin API makes use of these extensions to add new Kotlin specific conveniences to existing APIs.
TestRestTemplate
extensions, similar to those provided by Spring Framework for RestOperations
in Spring Framework, are provided.
Among other things, the extensions make it possible to take advantage of Kotlin reified type parameters.
Dependency Management
In order to avoid mixing different versions of Kotlin dependencies on the classpath, Spring Boot imports the Kotlin BOM.
With Maven, the Kotlin version can be customized by setting the kotlin.version
property and plugin management is provided for kotlin-maven-plugin
With Gradle, the Spring Boot plugin automatically aligns the kotlin.version
with the version of the Kotlin plugin.
Spring Boot also manages the version of Coroutines dependencies by importing the Kotlin Coroutines BOM.
The version can be customized by setting the kotlin-coroutines.version
property.
org.jetbrains.kotlinx:kotlinx-coroutines-reactor dependency is provided by default if one bootstraps a Kotlin project with at least one reactive dependency on start.spring.io.
@ConfigurationProperties
when used in combination with constructor binding supports data classes with immutable val
properties as shown in the following example:
@ConfigurationProperties("example.kotlin")
data class KotlinExampleProperties(
val name: String,
val description: String,
val myService: MyService) {
data class MyService(
val apiToken: String,
val uri: URI
Due to the limitations of their interoperability with Java, support for value classes is limited. In particular, relying upon a value class’s default value will not work with configuration property binding. In such cases, a data class should be used instead.
To generate your own metadata using the annotation processor, kapt should be configured with the spring-boot-configuration-processor dependency.
Note that some features (such as detecting the default value or deprecated items) are not working due to limitations in the model kapt provides.
Testing
While it is possible to use JUnit 4 to test Kotlin code, JUnit 5 is provided by default and is recommended.
JUnit 5 enables a test class to be instantiated once and reused for all of the class’s tests.
This makes it possible to use @BeforeAll
and @AfterAll
annotations on non-static methods, which is a good fit for Kotlin.
To mock Kotlin classes, MockK is recommended.
If you need the MockK
equivalent of the Mockito specific @MockitoBean
and @MockitoSpyBean
annotations, you can use SpringMockK which provides similar @MockkBean
and @SpykBean
annotations.
Resources
Further Reading
Kotlin Slack (with a dedicated #spring channel)
Tutorial: building web applications with Spring Boot and Kotlin
A Geospatial Messenger with Kotlin, Spring Boot and PostgreSQL
Examples
spring-boot-kotlin-demo: regular Spring Boot + Spring Data JPA project
mixit: Spring Boot 2 + WebFlux + Reactive Spring Data MongoDB
spring-kotlin-fullstack: WebFlux Kotlin fullstack example with Kotlin2js for frontend instead of JavaScript or TypeScript
spring-petclinic-kotlin: Kotlin version of the Spring PetClinic Sample Application
spring-kotlin-deepdive: a step by step migration for Boot 1.0 + Java to Boot 2.0 + Kotlin
spring-boot-coroutines-demo: Coroutines sample project
