Quartz Scheduler
Spring Boot offers several conveniences for working with the Quartz scheduler, including the spring-boot-starter-quartz
starter.
If Quartz is available, a Scheduler
is auto-configured (through the SchedulerFactoryBean
abstraction).
Beans of the following types are automatically picked up and associated with the Scheduler
JobDetail
: defines a particular Job.JobDetail
instances can be built with theJobBuilder
API. -
Trigger
: defines when a particular job is triggered.
By default, an in-memory JobStore
is used.
However, it is possible to configure a JDBC-based store if a DataSource
bean is available in your application and if the spring.quartz.job-store-type
property is configured accordingly, as shown in the following example:
Properties
YAML
spring.quartz.job-store-type=jdbc
spring:
quartz:
job-store-type: "jdbc"
When the JDBC store is used, the schema can be initialized on startup, as shown in the following example:
Properties
YAML
spring.quartz.jdbc.initialize-schema=always
spring:
quartz:
jdbc:
initialize-schema: "always"
By default, the database is detected and initialized by using the standard scripts provided with the Quartz library.
These scripts drop existing tables, deleting all triggers on every restart.
It is also possible to provide a custom script by setting the spring.quartz.jdbc.schema property.
To have Quartz use a DataSource
other than the application’s main DataSource
, declare a DataSource
bean, annotating its @Bean
method with @QuartzDataSource
Doing so ensures that the Quartz-specific DataSource
is used by both the SchedulerFactoryBean
and for schema initialization.
Similarly, to have Quartz use a TransactionManager
other than the application’s main TransactionManager
declare a TransactionManager
method with @QuartzTransactionManager
By default, jobs created by configuration will not overwrite already registered jobs that have been read from a persistent job store.
To enable overwriting existing job definitions set the spring.quartz.overwrite-existing-jobs
property.
Quartz Scheduler configuration can be customized using spring.quartz
properties and SchedulerFactoryBeanCustomizer
beans, which allow programmatic SchedulerFactoryBean
customization.
Advanced Quartz configuration properties can be customized using spring.quartz.properties.*
In particular, an Executor bean is not associated with the scheduler as Quartz offers a way to configure the scheduler through spring.quartz.properties .
If you need to customize the task executor, consider implementing SchedulerFactoryBeanCustomizer .
Jobs can define setters to inject data map properties. Regular beans can also be injected in a similar manner, as shown in the following example:
Java
Kotlin
import org.quartz.JobExecutionContext;
import org.quartz.JobExecutionException;
import org.springframework.scheduling.quartz.QuartzJobBean;
public class MySampleJob extends QuartzJobBean {
// fields ...
private MyService myService;
private String name;
// Inject "MyService" bean
public void setMyService(MyService myService) {
this.myService = myService;
// Inject the "name" job data property
public void setName(String name) {
this.name = name;
protected void executeInternal(JobExecutionContext context) throws JobExecutionException {
this.myService.someMethod(context.getFireTime(), this.name);
class MySampleJob : QuartzJobBean() {
// fields ...
private var myService: MyService? = null
private var name: String? = null
fun setMyService(myService: MyService?) {
fun setName(name: String?) {
this.name = name
override fun executeInternal(context: JobExecutionContext) {
myService!!.someMethod(context.fireTime, name)
