Getting Started
To get started with the plugin it needs to be applied to your project.
The plugin is published to Gradle’s plugin portal and can be applied using the plugins
block:
Groovy
Kotlin
plugins {
id 'org.springframework.boot' version '3.4.0'
plugins {
id("org.springframework.boot") version "3.4.0"
Applied in isolation the plugin makes few changes to a project.
Instead, the plugin detects when certain other plugins are applied and reacts accordingly.
For example, when the java
plugin is applied a task for building an executable jar is automatically configured.
A typical Spring Boot project will apply the groovy
, java
, or org.jetbrains.kotlin.jvm
plugin as a minimum and also use the io.spring.dependency-management
plugin or Gradle’s native bom support for dependency management.
For example:
Groovy
Kotlin
plugins {
id 'java'
apply plugin: 'io.spring.dependency-management'
plugins {
java
apply(plugin = "io.spring.dependency-management")
To learn more about how the Spring Boot plugin behaves when other plugins are applied please see the section on reacting to other plugins.
